Secretefx - Secret-1 STD overdrive  [traced]
Re: Secretefx - Secret-1 STD overdrive
Postby modman » 01 Apr 2018, 11:53
Saw this a bit late -- still, YuGi got promoted to Degoop Doctor...
For this message the author modman has received thanks:
deltafred (01 Apr 2018, 12:31)
Has thanked: 3110 times
Have thanks: 559 times
Postby Manfred » 03 Apr 2018, 00:14
Here the PCB-Layout clone, I plan to convert it to a single side version.
Secret1PCB_Components.pdf
Secret1PCB_ComponentSide.pdf
Secret1PCB_ComponentSideMirrored.pdf
Secret1PCB_SolderSide.pdf
Secret1PCB_SolderSideMirrored.pdf
Manfred
Has thanked: 976 times
Have thanks: 523 times
Postby Frabbio » 03 Apr 2018, 09:41
Single sided layout with pcb mount pots, board dimensions are 5.5x4.5 cm.
My suggestion for the opamp is the OP275.
Good Diy
For this message the author Frabbio has received thanks:
Manfred (03 Apr 2018, 12:46)
Frabbio
Has thanked: 10 times
Have thanks: 76 times
Postby Manfred » 03 Apr 2018, 13:02
Hi Frabbio,
ok, is already done.
Thanks for sharing.
Manfred
Postby roseblood11 » 05 Apr 2018, 22:15
@Manfred: Publishing a cloned version of the original pcb layout is a copyright infringement
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby Manfred » 05 Apr 2018, 23:55
roseblood11 wrote:@Manfred: Publishing a cloned version of the original pcb layout is a copyright infringement
O.k, If it harms the forum, then the Admin should delete my post.
BTW, all drawn schematic found by tracing are copyright infringements too.
I just asked the Administrator to delete my post:
http://freestompboxes.org/viewtopic.php?f=7&t=24020&start=20#p269820
Manfred
Postby marshmellow » 06 Apr 2018, 15:50
Manfred wrote:BTW, all drawn schematic found by tracing are copyright infringements too.
No, they are not. It's your own artwork, you created it.
For this message the author marshmellow has received thanks:
Manfred (06 Apr 2018, 20:54)
marshmellow
Have thanks: 122 times
Postby modman » 09 Apr 2018, 13:18
Roseblood: who are you and what are you doing on this forum?
And that's really all there is to it...
EDIT:
I cannot think of any copyright issues that would matter. At least really none apply. I moved the forum from US servers which cost us about $95/year to a Swedish server which costs about 4 times as much. Hosted in the USA, Lance Keltner and Klon clown Finnegan could just send a mail to the hosting company simply stating that we were infringing copyright, without having to prove anything. In order to defend the forum against this false claims, I would have had to hire a US attorney to fight the complaint.
Right now the situation is the inverse: anybody who feels their copyright is infringed upon can file a complaint with the
Stockholm District court:
Scheelegatan 7, 112 28 Stockholm, Sweden
For this message the author modman has received thanks: 3
Broadcaster (09 Apr 2018, 20:55), dv8r601 (26 Apr 2018, 23:03), Shango (09 Apr 2018, 16:59)
Previous
Users browsing this forum: dikenn, FlyingWild, jt, julessouren, Manfred, medve, theehman and 12 guests
