TC Electronic - Spark Booster  [traced]
Re: TC Electronic - Spark Booster
Postby alexradium » 11 Mar 2014, 16:51
miklax wrote:By the way..
What do you think about the active filter section?
Any Idea on how to calculate the corner frequency for each of the switch positions?
https://www.dropbox.com/s/l1p41wjfl27o8zq/Untitled.jpg
Cheers!
http://www.muzique.com/schem/filter.htm
alexradium
Has thanked: 53 times
Have thanks: 60 times
Postby coldcraft » 11 Mar 2014, 21:11
185Hz and 408Hz
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby miklax » 12 Mar 2014, 01:34
coldcraft wrote:185Hz and 408Hz
Could you explain, or show the math?
Cheers!
miklax
Have thanks: 18 times
Postby johnk » 12 Mar 2014, 03:58
just plug the resistor and cap values into this calculator:
3K9/.22uf= 185.6
3K9/.1uf= 408.3
johnk
Has thanked: 31 times
Have thanks: 270 times
Postby johnk » 12 Mar 2014, 04:00
BTW, I drew up a veroboard layout for it, but it's huge at 33x18 so it won't fit in a 1590B. I would probably fit in a 125 but i'm just going to use a 1590B.
if anyone is interested, i'll post the layout after I build and verify it.
johnk
Postby johnk » 12 Mar 2014, 20:37
I got the vero version built and it sounds great! thanks for posting the schematic.
johnk
Postby johnk » 12 Mar 2014, 21:53
my vero is pretty huge at 33 x 18, but at least it's verified. :wink:
I preferred mine to have a more open top end so I removed C2 (1n cap from miklax's schematic), but it still shown on my vero (second 1n cap from the left).
For this message the author johnk has received thanks: 3
IvIark (12 Mar 2014, 23:01), miklax (14 Mar 2014, 05:02), modman (12 Nov 2017, 22:58)
johnk
Postby miklax » 14 Mar 2014, 01:09
Great Work!!
I'm glad to finally contribute to this community, that helped me so many times!
When I built mine.. and despite the fact it already has 1M resistor on the Input, and 100K on the output.. It still makes a very loud Pop noise using a regular truebypass wiring..
Any ideas?
Cheers!
miklax
Postby johnk » 14 Mar 2014, 05:47
that's strange. mine makes no pop at all when using a true bypass.
thanks for posting the schemo!
if yours is popping, i'd first make sure that the VR+ connections are going to the right places, otherwise it it'll put DC on the output and cause huge popping.
johnk
Postby miklax » 15 Mar 2014, 01:16
I'll look for it... but i'm using a PCB, designed directly from the schematic.
I'll analyse it further! :)
thanks for the input.
miklax
Postby fixxe » 28 Apr 2014, 00:49
Quick question: On the pictures the chip is mc33178 and on your vero layout it is 33172. Are they the same?
Also miclax named them OPA2134PA. So what's going on there? :cry:
fixxe
Postby johnk » 28 Apr 2014, 01:37
I would think that any dual low noise opamp will work in it.
i'll order some 33178's to try in it and see if it makes any difference but I doubt that it will.
johnk
Postby fixxe » 28 Apr 2014, 14:48
Thanks for checking that out! :thumbsup
Should't the IC still be changed on the vero layout though?
fixxe
Postby johnk » 28 Apr 2014, 17:37
IMO, it really doesn't matter but here you go:
johnk
Postby fixxe » 25 May 2014, 21:20
johnk wrote:I would think that any dual low noise opamp will work in it.
Any updates?
fixxe
Postby johnk » 25 May 2014, 23:15
I finally just got them so i'll try the 33178's in it soon.
johnk
Postby fixxe » 05 Jul 2014, 15:27
johnk wrote:I finally just got them so i'll try the 33178's in it soon.
What's the verdict? :)
fixxe
Postby johnk » 15 Jul 2014, 00:05
sorry it took so long but I finally got around to trying the 33178's and it sounds the same as the 33172's so i'll just leave them in there since that's what the original has in it.
fixxe (18 Jul 2014, 17:06)
johnk
Postby fixxe » 18 Jul 2014, 17:05
Cool! Thanks for taking the time to compare them!
fixxe
Postby copachino » 20 Jul 2014, 15:41
johnk wrote:IMO, it really doesn't matter but here you go:
[ Image ]
thanks, would be amazing to have a pcb layout, or maybe and OSH park shared projecto fot this little big monster
copachino
Have thanks: 6 times
Users browsing this forum: overplay, Pyra and 14 guests
