Bondi Effects - Sick As Overdrive
Postby beedotman » 14 Apr 2014, 10:09
Any body got it? Have some gutshots? I saw it once and think this is modified Klon. Reviews are great.
beedotman
Has thanked: 428 times
Have thanks: 410 times
Re: Bondi Effects - Sick As Overdrive
Postby pappasmurfsharem » 14 Apr 2014, 21:58
beedotman wrote:[ Image ]
*In before it's a Timmy*
For this message the author pappasmurfsharem has received thanks:
Nocentelli (14 Apr 2014, 22:20)
pappasmurfsharem
Have thanks: 22 times
Postby commathe » 15 Apr 2014, 06:15
I like the graphics. It's nice to see something that is aesthetically pleasing for once.
commathe
Have thanks: 8 times
Postby joe_pineapple » 17 Apr 2014, 17:53
commathe wrote:I like the graphics. It's nice to see something that is aesthetically pleasing for once.
looks like a Frantone :!:
"..the finished product is just the garbage left over from the work." R.G. Keen
joe_pineapple
Has thanked: 107 times
Have thanks: 5 times
Postby beedotman » 18 Apr 2014, 10:59
gutshot, very nice and clean
For this message the author beedotman has received thanks: 3
Desdog (20 Mar 2015, 00:33), modman (21 Mar 2015, 14:31), rocklander (19 Apr 2014, 10:29)
beedotman
Postby pappasmurfsharem » 18 Apr 2014, 20:07
atreidesheir wrote:nice bypass.
not a Timmy.
Hmm "Powerful Active EQ"
So what then a tube screamer with a baxandal?
I am a little confused with the dual gang pot. I assume the switch either changes the diodes or moves the gangs in and out of series or a combo of both.
Probably not why bother with a dual gang pot then?
The Description on the site says alot:
Features
· Hand-selected audiophile components (Probably a BurrBrown Chip)
· Two unique voices of natural tube-like overdrive (Switches clipping diodes or resistance)
· Ultra-transparent clean boost (Whatever)
· Powerful active EQ controls capable of up to 15dB of boost or cut. (Active Baxandall)
· Can operate as a clean boost, overdrive, or a blend of the two.
· Voltage boosted internally to an 18 volt spread for increased headroom and clarity. (Charge Pump)
· Soft-Touch True Bypass (Relay)
pappasmurfsharem
Postby skywise » 19 Apr 2014, 19:42
That's exactly what I was thinking. That thing screams "Frantone".
skywise
Has thanked: 47 times
Have thanks: 20 times
Postby Mbas974 » 19 Apr 2014, 20:32
Is it a relay bypass ?
what are the op-amp used ? Ican't read from pics.
Mbas974
Has thanked: 40 times
Have thanks: 41 times
Postby triplesevener » 20 Apr 2014, 01:00
Mbas974 wrote:Is it a relay bypass ?
Definitely Burr Brown, so I'm going to guess OPA2134. Look at the silkscreen for the dual gang (CLEAN/GAIN). That screams Klon based.
triplesevener
Have thanks: 7 times
Postby bondieffects » 13 May 2014, 03:00
Hey guys,
First off let me just say I'm seriously flattered that you guys are curious, I started out in DIY, as just about everyone does.
My design really isn't that complex or impressive so I figure if you want to figure it out I'm sure you guys will really quickly. That said I do make a living off of this and contrary to popular belief we builders are not all bajilionaires. You guys may feel differently but as flattered as I am and i sincerely appreciate the kind words about build quality and aesthetics, I do have a family to feed and would appreciate if you can wait until I am a bajilionaire before you start posting schematics and building clones.
Sorry if this is adding to the noise, I know I'm sort of the opposition in this case.
Thanks regardless!
bondieffects
Have thanks: 3 times
Postby rocklander » 13 May 2014, 03:36
welcome to the forum bondieffects.
have a nosey round this place, it's a wealth of knowledge, you'll also find several pleas from various builders with the same concern. the response is overwhelmingly "if a hobby site posting schematics is going to stop you feeding your family, you're in the wrong business". there's no malice here, only a thirst for knowledge and the type of person who'll build a clone of your pedal is the type of person who'd buy yours anyway (out of respect) or would never have bought one in the first place.
feel free to post the schematics yourself though.. you'll get credit where it's due :thumbsup ...
rocklander
Has thanked: 1580 times
Have thanks: 290 times
Postby coldcraft » 13 May 2014, 04:04
I've found that the best way to prevent the community here from actually reversing your designs is to be as open as possible, ie describe the design as a block diagram. Most people just want to know what/how its done, not necessarily to make themselves one. Wampler does this a lot, drops hints and explains the block diagram picture.
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby bondieffects » 13 May 2014, 04:25
you'll also find several pleas from various builders with the same concern. the response is overwhelmingly "if a hobby site posting schematics is going to stop you feeding your family, you're in the wrong business". there's no malice here, only a thirst for knowledge and the type of person who'll build a clone of your pedal is the type of person who'd buy yours anyway (out of respect) or would nave have bought one in the first place.
I can appreciate that, and for the most part I agree. I really do see where your coming from, since I myself was in that position not too long ago. I could plead my case further but I doubt that would do any good. This is a DIY forum and not a builders one after all.
If it's block diagrams your after pappasmurfsharem has basically got it. Nothing fancy, just a unique incorporation of old ideas. It's pretty tough to come up with an original way to clip a diode, my intent was more just to put together some ideas that hadnt been done in this configuration if that makes sense.
Thanks guys!
For this message the author bondieffects has received thanks: 3
FiveseveN (13 May 2014, 11:31), gabiru (08 Jul 2015, 14:27), skywise (13 May 2014, 05:10)
bondieffects
Postby ubersam » 14 May 2014, 18:34
not a Timmy.
I'm guessing that the dual gang is wired similarly to the way a blend pot in a bass is wired up. When in blend mode, you get more of the gain sound and less clean going CW, and the reverse going CCW.
ubersam
Postby newly » 16 May 2014, 16:17
softclick sw...nice
newly
Have thanks: 2 times
Postby lukatosh » 17 Sep 2014, 05:52
- BurrBrown Chip is in there... and the other IC looks like a sort of texas instruments (excuse my bad english)
- What about the Diodes used at the charge pump or polarity protection?
- It looks like the HILO Switch involves some capactior change besides the clipping Diodes
For this message the author lukatosh has received thanks: 4
jighead81 (04 Oct 2014, 05:08), modman (03 Oct 2016, 20:26), rocklander (17 Sep 2014, 07:55), rs (17 Sep 2014, 13:22)
lukatosh
Has thanked: 33 times
Have thanks: 180 times
Postby JustJeff » 19 Mar 2015, 21:44
bondieffects wrote:I can appreciate that, and for the most part I agree. I really do see where your coming from, since I myself was in that position not too long ago. I could plead my case further but I doubt that would do any good. This is a DIY forum and not a builders one after all.
Thanks guys!
Hey Bondi
I'm not a builder. I'm not a tinkerer nor a DIYer. I come here to read about how guys are doing things. When a pedal is getting a lot of run in forums, I come here to see what is making it tick. If it is just another TubeScreamer, I no longer need to hear it. Sometimes it's a pedal that is commanding crazy money and it is nothing more than two Marshall Guv'nors in one box, I find it novel but lose interest.
I tell you that because the Sick As has been getting a lot of good comments and I came here to see if it is another over-hyped repackage. Apparently you're doing something a little different. I'll be buying one. For the record: these guys sold it.
JustJeff
Postby lukatosh » 02 Sep 2016, 22:50
Found this on google...
It uses BB OPA 2134, blue diodes are BAT 46...
modman (05 Sep 2016, 11:09)
lukatosh
Postby roseblood11 » 03 Sep 2016, 00:18
Just a guess:
A clean boost and an overdrive circuit that combines zendrive clipping with timmy tone controls, followed by a summing amp
roseblood11
Has thanked: 352 times
Have thanks: 315 times
Postby newly » 17 Sep 2016, 16:40
Thot it is a klon genere?
newly
Next
Users browsing this forum: boby6kiler and 9 guests
