Mad Professor Simble
Postby ipm » 27 May 2014, 22:36
Anyone?
I would really like to know what is it all about!
ipm
Re: Mad Professor Simble
Postby Jone the Bone » 01 Jun 2014, 07:30
Simble is a new Dumble-amp sounding overdrive pedal, originally designed by Finnish audio engineer, Lassi Ukkonen.
http://www.simbletone.com/
Lassi made the first versions by himself, but now the Simble belongs to Mad Professor's pedal range. Price about 200,- eur.
Controls corresponds to the Hermida Audio Zendrive's pots, differently named. So, my loose guess is, that the Simble is very close cousin to Zendrive.
Jone the Bone
Have thanks: 2 times
Postby triplesevener » 01 Jun 2014, 14:49
Not just that, given the one gutshot we've seen (of the back of the board), 3 of the 4 pots are the same value as a Zendrive, the one difference being a 1M gain pot.
triplesevener
Have thanks: 7 times
Postby andregarcia57 » 01 Jun 2014, 15:25
great sound....
Link
andregarcia57
Have thanks: 87 times
Postby Ripdivot » 01 Jun 2014, 17:59
It does sound nice. Seems to have more mids than a Zen. The type of mids that want to transition to controlled feedback very easily.
Ripdivot
Have thanks: 66 times
Postby roseblood11 » 01 Jun 2014, 21:55
Maybe he changed the direction of the mosfets? The zendrive just uses the clipping of the body diode... if you turn them around, you get a better bass response, and a little less distortion, so a 1M gain pot would make sense.
roseblood11
Has thanked: 350 times
Have thanks: 310 times
Postby micromegas » 04 Jun 2014, 23:20
Comparision clip:
Link
micromegas
Postby Ripdivot » 05 Jun 2014, 03:19
That's a great demo. Thanks for posting. During the part played over the backing track it's not quite fair because the zen is slightly quieter. The zen is a little dirtier and more compressed.
At the end where the pedals are compared without the backing track they sound very similar. The Simble is a little more open sounding and has better bottom end which you can hear when he plays the G chord.
Ripdivot
Postby Ripdivot » 05 Jun 2014, 03:21
I'll add that the demo makes me feel more content with my zen. The gas is going away.
Ripdivot
Postby roseblood11 » 06 Jun 2014, 01:22
Try this on the zendrive, I guess it's the "Simble Mod"...
For this message the author roseblood11 has received thanks: 4
HENK (06 Jun 2014, 11:44), Manfred (06 Jun 2014, 02:10), rcustoms (06 Jun 2014, 05:20), rocklander (06 Jun 2014, 02:00)
roseblood11
Postby rs » 08 Jun 2014, 14:27
Over here there are some demos and some info aswell as gutshots.
http://d.hatena.ne.jp/toy_love/20140503/1399127207
Cheers.
rs
Has thanked: 88 times
Have thanks: 6 times
Postby 1oldsidewinder » 08 Jun 2014, 16:55
That shot of the corner of the board with the transistor and diodes is interesting. Looks like a series resistor combined with a diode (D1) and the transistor. The other diode looks to be labeled D8 and may serve a different purpose. So what are we looking at; a buffer w/ protection diode or maybe half of the clipping diode array? Kind of curious that it's not gooped there if it is part of the array.
1oldsidewinder
Has thanked: 19 times
Have thanks: 5 times
Postby John G » 08 Jun 2014, 23:16
Just a thought................could that transistor and diodes etc be part of the LED control cct concidering there is only a DPDT stomp switch fitted.
This may also explain the latency with the LED when switcihed.
John
John G
Have thanks: 9 times
Postby alkuz1961 » 10 Jun 2014, 17:18
I think it's just Millennium Bypass
For this message the author alkuz1961 has received thanks:
1oldsidewinder (11 Jun 2014, 07:15)
alkuz1961
MP Simble OD with weird surface mod (from factory)
Postby Richard Lainegard » 12 Jun 2014, 07:54
Hey guys, registered a new user (since I've changed my surname since last).
ANyways, I posted a pic of this Simble PCB on my FB-page, and Delaney (Effects) suggested
I also post it here, since there was apparently a reverse engineering going down on this pedal.
So here is the pic in question. Any idea what this mod is?
Was is a last minute revision to the V.1.1 board and they wanted them
to go out, and didn't want to wait for a V.1.2 board (There has after all been
quite a buzz around these). Delaney's guess was a iltering sub circuit of some kind,
such as a bleed fix or a noise filter.
For this message the author Richard Lainegard has received thanks:
modman (27 Feb 2015, 16:30)
Richard Lainegard
Re: MP Simble OD with weird surface mod (from factory)
Postby JOHNO » 12 Jun 2014, 09:02
Looks like it might be for the lighting led when the pedal is switched on. Rat style or millenium bypass?
JOHNO
Has thanked: 52 times
Have thanks: 62 times
Postby okgb » 12 Jun 2014, 20:32
I'd love to see , circuit wise what the difference is , whether level differences or circuit values
I thought the simby sounded fuller while the zen was brighter [ by a little ]
okgb
Has thanked: 202 times
Have thanks: 41 times
Postby lead2203 » 13 Jun 2014, 01:03
JOHNO wrote:Looks like it might be for the lighting led when the pedal is switched on. Rat style or millenium bypass?
Yes..You can see the FET on the board is removed. Its just a quick fix for the bypass LED.
lead2203
Postby Jone the Bone » 15 Jun 2014, 09:03
There is a pic of Simble's pcb, found from the net. I'd like to see more pics, component side too.
For this message the author Jone the Bone has received thanks: 2
modman (27 Feb 2015, 16:30), rocklander (16 Jun 2014, 06:15)
Jone the Bone
Postby MoonWatcher » 17 Jun 2014, 12:39
Jone the Bone wrote:There is a pic of Simble's pcb, found from the net. I'd like to see more pics, component side too.
It looks like there's a DIP8 config for an op amp sort of in the middle there - looks like pin 4 connects to what is probably ground.
I don't see what appear to be any other possibilities for an op amp, but uniform resistor spacing can make that hard to tell. Still, those who said something along the lines of Zendrive-like are probably correct, or at least something on the simpler side with an op amp as opposed to discrete transistors.
Should be a quick trace after someone pulls it from the box, assuming no goop. Does Mad Professor goop their stuff any longer? Even if so, that would probably just slow things down a little.
MoonWatcher
Has thanked: 43 times
Have thanks: 65 times
Next
Users browsing this forum: athdimitris, eric_obrien, pietro_moog and 5 guests
