Mad Professor Simble
Re: Mad Professor Simble
Postby jfk1063 » 16 Jul 2014, 21:04
roseblood11 wrote:Try this on the zendrive, I guess it's the "Simble Mod"...
Still use the asym bat41's then?
jfk1063
Re: Mad Professor Simble - Goop Alert
Postby mirosol » 20 Jul 2014, 10:11
Noticed that a friend had one for sale, so being an unemployed broke ass f**k that i am, i first tried to trade it in. I made my intentions clear in the first message i sent him, so he agreed to lend it to me for a few hours. He sold his unit already and he'll be shipping it away tomorrow, so i only had two hours and i drove ~65km to get it. As soon as i was on my desk with the pedal, i opened it up. Damn. All this to see a board with goop + sanded semiconductors.
So here are some photos i managed to get. Could be enough to determine the topology, but not nearly enough to do a full trace. Like i said. It's a friend's unit and he sold it to someone else already. So yeah. I'm not going to even try to degoop it. Guess it's time to drive another 65km to take it back.
For this message the author mirosol has received thanks: 4
bloomz (24 Jul 2014, 16:08), IvIark (20 Jul 2014, 10:51), modman (27 Feb 2015, 16:30), rocklander (20 Jul 2014, 11:06)
mirosol
Has thanked: 156 times
Have thanks: 359 times
Postby IvIark » 20 Jul 2014, 10:58
Oh no! Unlucky man. I bet someone here will still be able to see what it is (with a bit of luck).
IvIark
Has thanked: 668 times
Have thanks: 678 times
Postby mirosol » 20 Jul 2014, 11:25
Due to goop (and the sound), i'm hopping into the bandwagon guessing it's slightly modified Zen. Or why else would they try to cover it up..
mirosol
Postby Ice-9 » 20 Jul 2014, 15:27
Yeah next to pin 1 and 2 is a small cap probs around 100p and 2 transistors which are quite possibly 2N7000 in the feedback loop for clipping. I will have to have a closer look to see what I can see, but it definitely looks quite zen like at the moment. Mad professor usually has something quite unusual in there circuits though so it would be good to get the goop off and have a better look.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby BJF » 20 Jul 2014, 18:32
[quote="MoonWatcher"][quote="J
Does Mad Professor goop their stuff any longer?
Hi
I have suggested no goop on the Mad Professor pcb series and none of my designs therefore have that. On the HW series there was a problem with the neoprane they used being too thin and so factory suggested they'd use a rubber housing which I think is good since it makes any short circuit impossible. I will say it does make a little pain to set bias precisely exactly nice on the HW MYT and also bias on TOP-setting either of those perfectly is easiest by ear while not so easy instruction for someone to set on a scope. This means MP pcb designed by me have no goop and no sanded parts, MP HW series designed by me if older edition is wrapped in neoprane and rubberband and later editions have a plastic container that the pcb rests in. Generally pcb models have the latest upgrades since changes can only be done when pcb is remade.
So actually when asked by MP crew if I'd like pcb or part of pcb gooped I have asked them not to do so :wink:
Simble is designed by a Finn and is manufactured and marketed by Mad Professor Ltd, while per definition it cannot be a Mad Professor pedal since Mad professor Ltd a while ago elected to not have BJF-design printed on the pedals as it anyway would be evident that all Mad Professor products are designed by BJF, the Mad Professor himself. :horsey:
I did play the Simble at NAMM and thought it sounded like something lots of people would like. Subconsiously and soundwise it reminded me of a Zendrive but it did not do the fluff at the end of notes that the hardcore Zendrive guys swear by.
:hmmm:
At your service
BJ
BJF Design
Aka Mad Professor himself
For this message the author BJF has received thanks: 5
bloomz (24 Jul 2014, 16:13), IvIark (02 Sep 2016, 00:04), jsaily (07 Oct 2014, 17:50), kaeisy (24 Jul 2014, 17:40), shagga (22 Jul 2014, 14:44)
BJF
Have thanks: 55 times
Postby modman » 02 Apr 2015, 20:53
For this message the author modman has received thanks: 3
dv8r601 (08 Jul 2017, 02:53), IvIark (02 Sep 2016, 00:04), rocklander (03 Apr 2015, 10:47)
Has thanked: 3110 times
Have thanks: 560 times
Postby BJF » 27 Jul 2016, 16:16
Hi There,
Indeed this is a a Lassi Ukkonen design and in that it is a Simble and not really a Mad Professor pedal.
I'd say I know nothing of this pedal other than I have played one- Simble.com would not share the schematic with the designer of MP Amplifications
So this is a major non understanding issue and in afact I have no idea if MP shares my schematics with Lassi at Simble
You might then ask why I'd still design for MP and the answer would be they owe me years of investments.
At your sincere service
BJ
In no way affiliated with Simble
Greg (17 Feb 2018, 02:46)
BJF
Postby swt » 31 Aug 2016, 20:57
just a glance at it and it has 8 poly caps...aside from the usual feedback loop and electros...zendrive has only 4. there's something else going on here...
swt
Have thanks: 9 times
Postby swt » 04 Sep 2016, 13:49
i suspect this is similar to the barber tone pump without presets for mids or bass...and mosfet clipping.
swt
Postby mirosol » 07 Jul 2017, 20:22
This needs to be degooped. Sadly the price of even beat, used units is a bit steep for me.
Wonder if MP owes still a lot to Björn...
+m
mirosol
Postby swt » 04 Oct 2017, 12:34
+1 on decoding this one...
swt
Postby matt239 » 13 Feb 2018, 05:58
I'd also like to know..
matt239
Has thanked: 62 times
Have thanks: 5 times
Postby cbriere » 15 Nov 2018, 04:04
tried one today, wow.
is there a schematics?
cbriere
Have thanks: 6 times
Postby swt » 18 Nov 2018, 03:17
Wow this one wins the prize for longest time without reversing in fsb!
swt
Previous
Users browsing this forum: fentemple, rockgod666, theehman, Visualdistortion, Zoom and 6 guests
