Way Huge...
Re: Way Huge...
Postby puppiesonacid » 29 May 2008, 14:17
aqua puss opamps revealed... :secret:
"Donner approached Mr. Huge about doing a Way Huge pedal for the Tsunami Relief Project, and Mr. Huge thought it would be fun. Mr. Huge rummaged around in his garage and found a prototype PCB for the AP-2 revA Aqua-Puss. Donner supplied the BBD and clock IC's (Panasonic MN3005 & MN3101) as well as the lovely painted box.
This Aqua-Puss has it all: Analog Devices OP275 op amp, Wima & Nichicon Muse capacitors, IRC 0.1% resistors (except for the first input and last output resistors, they're carbon composite), Matched Motorola transistors, Philips SA571 compander, 2 multi turn trimmer pots for bias & clock, Lots of extra RF filtering and of course a Fujisoku 3PDT foot switch."
puppiesonacid
Have thanks: 5 times
Re: Way Huge...
Postby puppiesonacid » 06 Jun 2008, 14:40
btw that way huge camel toe # 1 sold for over 1500$ :shock:
puppiesonacid
Re: Way Huge...
Postby The Rotagilla » 06 Jun 2008, 15:23
Does anyone have a theory as to how the series/parallel switching might be accomplished?
:scratch:
Someone pointed out to me the third small PCB located between the two footswitches.
The Rotagilla
Have thanks: 57 times
Re: Way Huge...
Postby roseblood11 » 02 Sep 2018, 09:54
Looking for a Blue Hippo schematic. It's supposed to be just a variation of the CE-2 or CE-3, but a good one!
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Previous
Users browsing this forum: LucasStrat and 12 guests
