Ramble FX - Marvel Drive 1.0  [traced]
Postby PedalBlotter » 08 Jul 2014, 13:54
The Ramble FX Marvel Drive is a nice sounding Plexi Pedal with parallel blending inputs, like a real amp.
It sounds amazing !!, i have one here (V1.0) borrowed and make a schematic.
That´s the first time i analyze a pedal and make a schematic.
So consider me, and check the schematic, if there are any errors in it.
If someone can make a verolayout, that would be great :hug:
download this schematic
For this message the author PedalBlotter has received thanks: 4
ggedamed (10 Jul 2014, 08:54), Greg (11 Jul 2014, 06:41), Intripped (10 Jul 2014, 19:13), modman (15 Nov 2014, 11:35)
PedalBlotter
Have thanks: 8 times
Re: Ramble FX Marvel Drive 1.0 [Schematic Inside]
Postby Frank_NH » 08 Jul 2014, 14:20
Nice! I just listened to some of the online demos of the Marvel Drive and it's probably one the best Plexi pedals I've ever heard - just awesome. Bring on the vero! :D
Frank_NH
Has thanked: 18 times
Have thanks: 66 times
Postby PedalBlotter » 08 Jul 2014, 14:30
yes, please someone make a vero ! :D
PedalBlotter
Postby coldcraft » 08 Jul 2014, 15:14
the pin connections on the FETs are incorrect. compare to another JFET overdrive to see what i mean. could you post a higher resolution image?
coldcraft
Has thanked: 42 times
Have thanks: 83 times
Postby PedalBlotter » 08 Jul 2014, 15:25
click on "download this schematic" under that image for a high resolution.
what u mean with incorrect pin connection ?
ah shit, did i mistake gate and source ?
PedalBlotter
Postby mirosol » 08 Jul 2014, 15:55
Yup. Gates and sources are in reverse.
+m
mirosol
Has thanked: 156 times
Have thanks: 361 times
Postby PedalBlotter » 08 Jul 2014, 16:01
Ok i changed it:
Manfred (14 Dec 2014, 13:54)
PedalBlotter
Postby tictac » 08 Jul 2014, 17:16
That 820 ohm source resistor on the first gain stage isn't grounded; doesn't look right.....
:hmmm:
TT
For this message the author tictac has received thanks:
Manfred (08 Jul 2014, 17:34)
tictac
Have thanks: 10 times
Postby PedalBlotter » 08 Jul 2014, 18:38
Yes, u are right.
Fixed it, and the one 1M at Q4 Drain was wrong too :oops:
Actually schematic:
https://dl.dropboxusercontent.com/u/35754713/Ramble/MarvelBlotter3.png
PedalBlotter
Postby PedalBlotter » 09 Jul 2014, 10:25
Some Pics:
There is a Wima 4700p cap in, on the pcb it says 470pf...
Under that 180pf Micas, the board says 220pf
For this message the author PedalBlotter has received thanks: 2
ggedamed (10 Jul 2014, 08:54), Intripped (10 Jul 2014, 19:13)
PedalBlotter
Postby PedalBlotter » 09 Jul 2014, 11:00
Ah sry again.
The 470pf is right, my false...
Wima is a 470pf/100 cap
PedalBlotter
Postby PedalBlotter » 09 Jul 2014, 11:16
Damn, isn't here a edit funktion ?
Anyway, the resistor below the Styroflex is for the LED (+)
PedalBlotter
Postby RambleFX » 10 Jul 2014, 07:05
Looks good :thumbsup
It's basically the input triode stages of a 1987x Marshall (in JFET form) into a mini-booster, into another JFET stage. That's one of the very first Marvel Drives. The ones built now have relay bypass switching, a presence control, and several tweaks. They're much cleaner builds too :oops:
For this message the author RambleFX has received thanks: 3
ggedamed (10 Jul 2014, 08:54), Intripped (10 Jul 2014, 19:13), Nocentelli (10 Jul 2014, 07:16)
RambleFX
Have thanks: 11 times
Postby PedalBlotter » 10 Jul 2014, 09:31
Thank you RambleFX for verify my amateur work :oops:
PedalBlotter
Postby IvIark » 10 Jul 2014, 11:22
Q4 still doesn't look right to me:
Code: Select all
Q3 drain > Q4 emitter > 100n > 100K > Q5 gate
                 V
                1u > Q4 gate
IvIark
Has thanked: 668 times
Have thanks: 679 times
Postby PedalBlotter » 10 Jul 2014, 13:22
Hmm, i checked the circuit a hundred times i think. :scratch:
it must be right like on the schematic ? :hmmm: :
Actually Version V3
Pics from Q3 and Q4:
PedalBlotter
Postby jubal81 » 10 Jul 2014, 14:26
I redrew for clarity. Looks pretty reasonable. The only thing I see as weird are the parallel 220uF & 100uF caps on the source of the 'normal' j201 input.
Here's a link to the full image
For this message the author jubal81 has received thanks: 4
Greg (11 Jul 2014, 06:40), Intripped (10 Jul 2014, 19:14), johnk (14 Jul 2014, 11:58), Manfred (10 Jul 2014, 16:05)
jubal81
Has thanked: 48 times
Have thanks: 32 times
Postby IvIark » 10 Jul 2014, 14:39
Aaah muamp! I couldn't see the wood for the trees
IvIark
Postby IvIark » 10 Jul 2014, 14:45
jubal81 wrote:I redrew for clarity. Looks pretty reasonable. The only thing I see as weird are the parallel 220uF & 100uF caps on the source of the 'normal' j201 input.
The 1987X has 330u from source to ground in that position.
IvIark
Postby PedalBlotter » 10 Jul 2014, 15:35
Nice work jubal81.
Looks clearer and cleaner than my experiment :oops:
i see, the treble/normal pots are backwards on my drawing :|
C10 is a polarized 1uF 50 Volt + to Gate Q4
C6 is a polarized 0,68uf 100 Volt
if this is necessary ?
PedalBlotter
Next
Users browsing this forum: aab0mb and 12 guests
