Ramble FX - Marvel Drive 1.0  [traced]
Re: Ramble FX - Marvel Drive 1.0
Postby POTL » 23 Feb 2018, 23:45
Hello everyone, I am confused by the power switching scheme, or am I mistaken, or does the voltage change only in the second half of the VB circuit, explain how in fact the voltage changes, on the whole circuit or only the second part of it?
POTL
Has thanked: 64 times
Have thanks: 54 times
Postby Nocentelli » 24 Feb 2018, 11:23
VA and VB are both switched between 9v and 18v - They are connected at the node that links to the two 47ohm resistors that feed these points,so both VA and VB will either provide 9v direct from the supply, or 18v from the charge pump. The only difference between VA/VB is that they have separate power filter caps and resistors.
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
POTL (24 Feb 2018, 14:20)
Nocentelli
Has thanked: 857 times
Have thanks: 836 times
Postby POTL » 24 Feb 2018, 14:20
Nocentelli wrote:VA and VB are both switched between 9v and 18v - They are connected at the node that links to the two 47ohm resistors that feed these points,so both VA and VB will either provide 9v direct from the supply, or 18v from the charge pump. The only difference between VA/VB is that they have separate power filter caps and resistors.
Thanks. :thumbsup
POTL
Postby mr coffee » 27 Feb 2018, 02:10
OK,
Here's the (I hope) last post in this thread, so folks can find the correct schematic without going through all kinds of confusion getting the correct schematic.
I made it a bit easier to read and cleaner, the last schematic was already correct.
mr coffee
For this message the author mr coffee has received thanks:
Manfred (29 May 2018, 06:26)
mr coffee
Has thanked: 45 times
Have thanks: 12 times
Postby JabboWookie » 29 May 2018, 01:54
Long time listener, first time caller...
I built this off of Bugg's PedalPCB Marble Drive, which I'm assuming is based off of this schematic. I'm getting a whine from the TC1044S when I'm in 9V mode. Everything's good in the 18V mode. I've tried two different chips with the same result. Any ideas why this might be happening? Obviously it goes away when I pull the chip.
https://www.pedalpcb.com/product/marbledrive/
Any help would be appreciated, thanks!
JabboWookie
Postby Manfred » 29 May 2018, 06:50
I think that the whine is not caused by the TC1044S in the 9V mode, but rather by means of bias point shifting on the FET stages.
Remove the chip and run the circuit using a 9V battery to see if the whine is still there.
Manfred
Has thanked: 943 times
Have thanks: 494 times
Postby JabboWookie » 29 May 2018, 11:16
The whine is gone when I pull the chip and run it at 9V (with my PP2+, no battery).
JabboWookie
Postby PedalPCB » 16 Jul 2018, 19:26
JabboWookie wrote:I built this off of Bugg's PedalPCB Marble Drive, which I'm assuming is based off of this schematic. I'm getting a whine from the TC1044S when I'm in 9V mode. Everything's good in the 18V mode. I've tried two different chips with the same result. Any ideas why this might be happening? Obviously it goes away when I pull the chip.
Add a 10K resistor from the bottom lug of the SPDT to ground, should clear up the whine. This is happening with some charge pumps.
For this message the author PedalPCB has received thanks: 3
JabboWookie (16 Jul 2018, 20:03), Manfred (17 Jul 2018, 16:23), nenecarrizo83 (20 Jul 2018, 01:58)
PedalPCB
Have thanks: 29 times
Previous
