Lovetone - Meatball  [traced]
Postby modman » 25 Jul 2007, 14:24
The schematic used to be at moosapotamus.net, but now gone. Only two projects based on the schematic survived:
http://home.planet.nl/~joep.remkes/mcmeat.html
http://pisotones.com/Meatball/psst/meatball-psst.html
Did someone save the schemo?
Has thanked: 3053 times
Have thanks: 526 times
Gutshots
Postby p.eat » 16 Feb 2008, 16:30
anybody have some gutshots of an original? I'd like to have a look at the layout.
thanks,
Peter
p.eat
Has thanked: 51 times
Have thanks: 15 times
Postby the tourist » 16 Feb 2008, 18:35
You can see the solder side here - http://filters.muziq.be/model/lovetone/meatball
the tourist
Re: Lovetone - Meatball
Postby puppiesonacid » 25 Jul 2008, 15:22
any confirmed builds from the McMeat pdf yet?
puppiesonacid
Have thanks: 5 times
Postby Bernardduur » 25 Jul 2008, 16:25
puppiesonacid wrote:any confirmed builds from the McMeat pdf yet?
Yes, I build one...... nice project!
For this message the author Bernardduur has received thanks:
modman (17 Nov 2014, 23:56)
Bernardduur
Has thanked: 85 times
Have thanks: 473 times
Postby lohstah » 25 Jul 2008, 21:39
yep, cool project, xspecially for bass players. i actually built mine before i started etching, so i perfed it.
cheers,
lohstah
lohstah
Has thanked: 196 times
Have thanks: 97 times
Postby soulsonic » 25 Jul 2008, 22:30
I'm into cool bass effects. What does it do exactly?
Has thanked: 53 times
Have thanks: 263 times
Postby puppiesonacid » 26 Jul 2008, 00:48
puppiesonacid
Postby soulsonic » 26 Jul 2008, 01:07
Sure has alot of freakin' knobs!
Postby Alex Frias » 28 Jul 2008, 17:11
I built a McMeat two years ago. A monster of a filter! Very pleased with the results.
I also did some mod's but I don't remember exactly how they was done, one made the "Color" control much more responsive along the way. The other was about to add the Tremulus Lune LFO to the center frequency of the filter, kind of cycling wahwah.
I didn't use the proper already made optocouplers, so I did them with LED + LDR covered with some thermo-retractil tube.
The looping chain is a very useful thing too as you can use some dynamics-killing effect (like a fuzz or a compressor) and the McMeat envelope detector will follow the unprocessed signal envelope.
I think there was an error or two on Pisotones site regarding one rotary switch wiring and a resistor that was forgotten in the detection section. aside this, it's a marvellous tutorial.
For this message the author Alex Frias has received thanks:
modman (17 Nov 2014, 23:57)
Alex Frias
Have thanks: 13 times
Postby alteredsounds » 28 Jul 2008, 20:48
Quite looking forward to building this, a change from overdrive and fuzz overkill! Do you know if the errors you mentioned are corrected in the mcmeat.pdf attatchment on this thread?
alteredsounds
Have thanks: 6 times
Postby MarcoMike » 29 Jul 2008, 13:39
no mistakes on the pdf. I built it from that project and works great!
For this message the author MarcoMike has received thanks:
modman (17 Nov 2014, 23:58)
MarcoMike
Postby Bernardduur » 29 Jul 2008, 14:41
MarcoMike wrote:no mistakes on the pdf. I built it from that project and works great!
+1
Some of the components aren't mounted on the PCB though; maybe that was the "error"
Bernardduur
Postby Alex Frias » 29 Jul 2008, 15:16
As MarcoMike said: you can follow the .pdf with no fear!
I think the attention must be on the off wiring and remember that some components are not PCB mounted.
IMHO, this project worthes all the effort.
Alex Frias
Postby rs » 29 Jul 2008, 21:53
I've built mine per the PDF and it worked out very well.
It's a very cool project 8) .
rs
Has thanked: 83 times
Postby fish head » 12 Aug 2008, 00:12
To those of you who've built the McMeat: what kind of enclosure did you use?
fish head
Postby the tourist » 12 Aug 2008, 08:36
I used smallbear's DD size - http://www.smallbearelec.com/Detail.bok?no=52
in hindsight, I think I probably could have squeezed everything into a smmh/holy stain sized box
the tourist
Postby rs » 13 Aug 2008, 00:37
I've built my own with bended alluminum.
rs
Postby jazzercountry » 01 Jan 2009, 18:13
I think I'm going to use toggle switches instead of the Lovetone's rotaries. (Got the idea here: http://www.martoneaudio.com/meatwad.htm) Anyone know what type to get? I know there are 2 with 3 positions and 2 with 2 positions, I just don't know if I need SP3T & SPDT or what. Also, one of the build reports I saw had some caps across some of the poles of the range knob, wasn't sure if I was seeing that correctly or how to apply that to a toggle switch. Said picture is here: http://www.pisotones.com/Meatball/psst/ ... edium.jpeg
Thanks much!
Ryan
jazzercountry
Postby theyear2042 » 07 Jan 2009, 10:23
i built mine into a 1590bb - had to leave off the true bypass switch due to lack of room
imo the pedal is way overcomplicated and difficult to use. imo you would be much better off making the MuTron III - RG did a pcb for it - same sound, much better control.
2042!
theyear2042
Next
Users browsing this forum: mett89 and 25 guests
