Page 1 of 4
Lovetone - Meatball [traced]
Posted: 25 Jul 2007, 13:24
by modman
The schematic used to be at moosapotamus.net, but now gone. Only two projects based on the schematic survived:
http://home.planet.nl/~joep.remkes/mcmeat.html
http://pisotones.com/Meatball/psst/meatball-psst.html
Did someone save the schemo?
Gutshots
Posted: 16 Feb 2008, 15:30
by p.eat
anybody have some gutshots of an original? I'd like to have a look at the layout.
thanks,
Peter
Posted: 16 Feb 2008, 17:35
by the tourist
Re: Lovetone - Meatball
Posted: 25 Jul 2008, 14:22
by puppiesonacid
any confirmed builds from the McMeat pdf yet?
Posted: 25 Jul 2008, 15:25
by Bernardduur
puppiesonacid wrote:any confirmed builds from the McMeat pdf yet?
Yes, I build one...... nice project!
Posted: 25 Jul 2008, 20:39
by lohstah
yep, cool project, xspecially for bass players. i actually built mine before i started etching, so i perfed it.
cheers,
lohstah
Posted: 25 Jul 2008, 21:30
by soulsonic
I'm into cool bass effects. What does it do exactly?
Posted: 25 Jul 2008, 23:48
by puppiesonacid
Posted: 26 Jul 2008, 00:07
by soulsonic
Sure has alot of freakin' knobs!
Posted: 28 Jul 2008, 16:11
by Alex Frias
I built a McMeat two years ago. A monster of a filter! Very pleased with the results.
I also did some mod's but I don't remember exactly how they was done, one made the "Color" control much more responsive along the way. The other was about to add the Tremulus Lune LFO to the center frequency of the filter, kind of cycling wahwah.
I didn't use the proper already made optocouplers, so I did them with LED + LDR covered with some thermo-retractil tube.
The looping chain is a very useful thing too as you can use some dynamics-killing effect (like a fuzz or a compressor) and the McMeat envelope detector will follow the unprocessed signal envelope.
I think there was an error or two on Pisotones site regarding one rotary switch wiring and a resistor that was forgotten in the detection section. aside this, it's a marvellous tutorial.
Posted: 28 Jul 2008, 19:48
by alteredsounds
Quite looking forward to building this, a change from overdrive and fuzz overkill! Do you know if the errors you mentioned are corrected in the mcmeat.pdf attatchment on this thread?
Posted: 29 Jul 2008, 12:39
by MarcoMike
no mistakes on the pdf. I built it from that project and works great!
Posted: 29 Jul 2008, 13:41
by Bernardduur
MarcoMike wrote:no mistakes on the pdf. I built it from that project and works great!
+1
Some of the components aren't mounted on the PCB though; maybe that was the "error"
Posted: 29 Jul 2008, 14:16
by Alex Frias
As MarcoMike said: you can follow the .pdf with no fear!
I think the attention must be on the off wiring and remember that some components are not PCB mounted.
IMHO, this project worthes all the effort.
Posted: 29 Jul 2008, 20:53
by rs
I've built mine per the PDF and it worked out very well.
It's a very cool project
Posted: 11 Aug 2008, 23:12
by fish head
To those of you who've built the McMeat: what kind of enclosure did you use?
Posted: 12 Aug 2008, 07:36
by the tourist
I used smallbear's DD size -
http://www.smallbearelec.com/Detail.bok?no=52
in hindsight, I think I probably could have squeezed everything into a smmh/holy stain sized box
Posted: 12 Aug 2008, 23:37
by rs
I've built my own with bended alluminum.
Posted: 01 Jan 2009, 17:13
by jazzercountry
I think I'm going to use toggle switches instead of the Lovetone's rotaries. (Got the idea here:
http://www.martoneaudio.com/meatwad.htm) Anyone know what type to get? I know there are 2 with 3 positions and 2 with 2 positions, I just don't know if I need SP3T & SPDT or what. Also, one of the build reports I saw had some caps across some of the poles of the range knob, wasn't sure if I was seeing that correctly or how to apply that to a toggle switch. Said picture is here:
http://www.pisotones.com/Meatball/psst/ ... edium.jpeg
Thanks much!
Ryan
Posted: 07 Jan 2009, 09:23
by theyear2042
i built mine into a 1590bb - had to leave off the true bypass switch due to lack of room
imo the pedal is way overcomplicated and difficult to use. imo you would be much better off making the MuTron III - RG did a pcb for it - same sound, much better control.
2042!
