Mid Fi Electronics - Glitch Computer
Postby pzorito » 06 Feb 2015, 01:57
I was asked from someone on r/guitarpedals to take pictures of the insides of this crazy beast and post em here. enjoy! hope this helps http://imgur.com/a/OoeVz
For this message the author pzorito has received thanks: 3
kroaton (06 Feb 2015, 19:18), modman (05 Mar 2015, 18:41), tabbycat (06 Feb 2015, 02:38)
pzorito
Have thanks: 4 times
Re: mid fi glitch computer guts
Postby kroaton » 06 Feb 2015, 02:33
Man, I've wanted to put together one of these for a long time (it's near impossible to grab one locally).
Nice of you to post the shots, man.
I see a CD4013, LM741, LM386 (JRC variant), 10uF cap (blue), 2x 10k resistors (light brown), can't tell what value the pink resistors, transistor, diode, pots and the grey cap show and there's no underside so I can't trace it (is the back of the board covered with something?).
Does Doug still post around here?
kroaton
Postby pzorito » 06 Feb 2015, 04:14
the back of the board is covered with cardboard and appears to be pretty well epoxied together. I don't know anything about fixing pedals and I don't wanna risk harming it :( sorry
pzorito
Re: Mid Fi Electronics - Glitch Computer
Postby doug deeper » 04 Mar 2015, 05:11
There's a voltage regulator in there. No transistor.
A couple .01uf caps, a .1, a couple 47uf, a 10uf.
The 741 is massively abused...as is the 386.
The cardboard is hot glued on, you may be able to pop it off,
But there is a resistor on the bottom of the board that may rip off.
For this message the author doug deeper has received thanks: 2
lapsteelman (19 Dec 2017, 05:46), rousejeremy (21 Dec 2017, 03:55)
doug deeper
Have thanks: 87 times
Postby rousejeremy » 19 Dec 2017, 01:03
No pics of the bottom of the board? Looks simple enough to figure out, and an AMAZING PEDAL!
rousejeremy
Has thanked: 28 times
Have thanks: 24 times
Users browsing this forum: bumblebee, illus1on7 and 13 guests
