Crowther Audio - Prunes & Custard
Re: Crowther Audio - Prunes & Custard
Postby Bernardduur » 24 Mar 2009, 09:27
Check if pin 1 is connected to the big line that runs underneath the IC. I've debugged some versions of friends and all had that problem.
Bernardduur
Has thanked: 87 times
Have thanks: 489 times
Postby jazzercountry » 24 Mar 2009, 12:06
Ok, Pin 1 was not connected to that line, so good call there. I fixed that, but it's still not working. Here are voltages:
1 8.2
2 8.4
3 8.4
4 8.9
5 8.4
6 8.5
7 8.2
8 9.2
jazzercountry
Postby bajaman » 24 Mar 2009, 12:34
there's your problem - pin 4 should be connected to earth (ground) - it should read 0 volts - check your earth connections
Has thanked: 457 times
Have thanks: 1579 times
Postby jazzercountry » 25 Mar 2009, 02:07
Ok, that's fixed. Pin 4 is 0v now. I have sound when the effect is engaged now, but it's just the same as when bypassed. I'm guessing that I cooked the IC having juice running to all 8 pins? I'll try another TL072 and see if that fixes it.
jazzercountry
Postby jazzercountry » 25 Mar 2009, 02:29
Well, looks like I'll have to run to Rat Shack to get another TL072 - but before I make the trip, does that sound like a reasonable explanation? The volume control works when the effect is engaged, there's just no effect (clean sound only louder)
jazzercountry
Postby bajaman » 25 Mar 2009, 03:52
post some pics :!: - showing the wiring etc. and both sides of board.
Postby jazzercountry » 25 Mar 2009, 06:03
Ok, pardon the mess on the trace side. I've been going over this thing so many times I'm starting to get the brown stuff. Anyway, I'm not sure if I was mistaken before or what, but I do get distortion now. It's definitely not the prunes & custard sound, though, maybe it's just the diodes clipping? Anyway, there's no distortion until the gain knob is almost maxed. Also, the switches and the mix control don't have much distinguishable effect. What's next to check?
jazzercountry
Postby bajaman » 25 Mar 2009, 12:12
Okay - assuming the wiring to the pots is correct and assuming the pots are the correct value, I would check for shorts between adjacent tracks - in particular the middle track under the op amp; it looks awfully close to the track connected to pin 1 of the op amp in your photo.
Do you have a ohm meter or digital multimeter??
Check for shorted tracks!
Postby jazzercountry » 25 Mar 2009, 12:38
I have one, but it doesn't have a continuity setting. I checked the one you mentioned, though, and it's good. Am I crazy for thinking this IC is cooked? Would that have this effect?
jazzercountry
Postby JimiB » 31 Mar 2009, 07:57
wouldnt work at all with a bad ic
JimiB
Have thanks: 5 times
Postby JimiB » 31 Mar 2009, 08:12
take a sharp pointed tool and scrape in between the areas I circled untill you are sure they couldnt be making a connection, and then try it again.
JimiB
Postby MWichni » 31 Mar 2009, 09:31
You should also clean the board up from colophony...
MWichni
Have thanks: 56 times
Postby jazzercountry » 31 Mar 2009, 14:34
Any tips for getting rid of that colophony rosin mess?
jazzercountry
Postby Fuzzer » 31 Mar 2009, 15:41
I think alcohol will do, but I don't know what it will do to the board, ¿what is the problem with the colophony after all? :?:
¿Does it bring trouble on long term?
Paint Thinner will also bring down the Colophony.
Fuzzer
Have thanks: 20 times
Postby MWichni » 31 Mar 2009, 16:01
Yes, alcohol will do the job. The colophony used to be tricky. Sometimes it can connect two traces while being on them. When colophony is melted on two traces it could have in it some tin solder and in that way can connect traces. Hope you understand what I am trying to say. :scratch:
MWichni
Postby Fuzzer » 31 Mar 2009, 16:13
Sure, thanks for the clarification MWichni.
So, you should try the alcohol Jazzercountry.
Fuzzer
Postby MWichni » 01 Apr 2009, 13:23
Alcohol will do nothing to the board, so don't be afraid about cleaning board using it.
MWichni
Postby jazzercountry » 04 Apr 2009, 16:34
Ok, I got it all cleaned off. Same problem, though. Switches and shape control have no effect. Volume works, but Drive is completely clean until it's turned up all of the way. I double checked my pot values, and the solder connections to the pots and switches. I'm not really sure what to do next. In the meantime I've finished a half dozen other projects that have fired up the first time, so that makes this one even more frustrating.
jazzercountry
Postby MWichni » 04 Apr 2009, 16:52
Well, you have empty places on your board. I don't know what should be in there but it is first suspicious.
MWichni
Postby jazzercountry » 04 Apr 2009, 17:00
Yeah, I was curious about those, but I'm pretty sure I followed the layout.
jazzercountry
Users browsing this forum: No registered users and 13 guests
