Crowther Audio - Prunes & Custard
Re: Crowther Audio - Prunes & Custard
Postby JimiB » 04 Apr 2009, 17:50
did you do what I suggested?
JimiB
Have thanks: 5 times
Postby MWichni » 04 Apr 2009, 17:56
Make a photo of solder side of your board.
MWichni
Have thanks: 56 times
Postby Mr. G. » 04 Apr 2009, 23:06
on the top middle of the solder side picture, it looks like one of the 3 larger solder points (the one on the left) might be touching another track.
Mr. G.
Have thanks: 8 times
Postby jazzercountry » 04 Apr 2009, 23:30
Yes, Jimib I did the scraping in the spots you showed with a magnifier, so I'm sure they aren't shorting. Same thing with the top middle left pad, it's clean. With the earlier problem getting connections to ground, I'm wondering if some of these connections aren't making contact with the trace at all?
jazzercountry
Postby stanimal08 » 19 Sep 2009, 00:06
yeah, I also built this last week (for myself, have built two more for friends this week) and had to debug my own mistakes, when i got them all working they sounded (to me) better than the original (i had one years ago), more smooth and musical but still maintaining that odd modulated splat fuzz sound that's just too cool... I noticed an obvious tonal difference in one pedal that I used different components (ran out of 40pf caps so I used another 10pf and 15k resistors because i ran out of 16k and didn't feel like "building" them out of 15 and 1k resistors) which made one significantly less "splatty" and a bit cleaner, sounds pretty good but definitely a wicked step brother.....
thanks to Bajaman again for great PCB's that are fun building....
stanimal08
Postby Brink » 10 Nov 2009, 20:23
I didn't see a vero, so I made one.
Check the schematic for the offboard wiring.
The 2 switches are not included, effectively hardwired in the positions shown in the schematic. You'll probably want to jumper IC pin 4 to track B, the ground.
I have not built on yet.
Brink
Has thanked: 10 times
Have thanks: 20 times
Postby Brink » 11 Nov 2009, 20:09
Also I forgot the input cap.
Brink
Postby Brink » 11 Nov 2009, 21:30
And the 100u is in the wrong place. I'll post a fixed vero later.
Brink
Postby Brink » 12 Nov 2009, 07:03
Here is my latest vero
(mods, feel free to delete previous posts and this sentence)
Brink
Postby bunnycat » 01 Feb 2010, 07:57
Anyone successfully built this from the vero layout?
I'm thinking about having a go at it - if I do I will post my results.
bunnycat
Postby bunnycat » 12 Feb 2010, 10:17
Built it and it sounds great... except when it's bypassed with the drive knob turned up past 3 'o' clock. For some reason, it makes a high pitched noise (tone) when bypassed at this (very high) drive level. It only happens when the effect is bypassed, and goes away when the drive knob is turned back down. The only parts I used that are different than the spec were a rectifier diode instead of the zener and a 54n cap instead of the 47n. Any ideas?
bunnycat
Postby pandadandan » 12 Feb 2010, 10:22
bunnycat wrote:Built it and it sounds great... except when it's bypassed with the drive knob turned up past 3 'o' clock. For some reason, it makes a high pitched noise (tone) when bypassed at this (very high) drive level. It only happens when the effect is bypassed, and goes away when the drive knob is turned back down. The only parts I used that are different than the spec were a rectifier diode instead of the zener and a 54n cap instead of the 47n. Any ideas?
How have you wired the switch? Are you grounding the effect even when bypassed? If not, you might benefit from rewiring your 3pdt to have a constantly grounded circuit.
pandadandan
Have thanks: 3 times
Postby KindaFuzzy » 12 Feb 2010, 12:50
Mine did the same until I grounded the input during bypass, now it's fine.
KindaFuzzy
Has thanked: 106 times
Have thanks: 296 times
Postby bunnycat » 12 Feb 2010, 17:53
I'll try that and post my results. Thanks!
bunnycat
Postby bunnycat » 15 Feb 2010, 10:36
Worked perfectly (thanks)! Wow, I really love this thing, especially on my analog synths (SH-1000, SH-2). It gives it some nice organic diode-filter-like qualities when the drive is turned up past 1 o' clock. It's going to be an integral part of my synth sound, I think. It adds grit that makes me think of the Korg MS-20. Now where's that Frostwave Resonator?
And now, on to the Hotcake (soulsonic's LM741CH Mojo version, on vero)...
Thanks again... I learned a better bypass wiring!!
bunnycat
Postby bunnycat » 15 Feb 2010, 19:45
One more question, if y'all are still there: is there any reason to seek out a 10v Zener (to replace the 1n4002 rectifier diode I used in its place)? I was reading about the function of the (8.2v) Zener in the Crowther Hotcake and it seems to limit the circuit voltage to 8.2v. Is the 1n4002 doing anything that is detrimental to the function of the circuit? I assume it's just there to provide reverse polarity protection (which I still don't understand the workings of), but would there be a good reason to use the 10v Zener?
-Samantha
bunnycat
Postby KindaFuzzy » 15 Feb 2010, 20:47
The normal diode should be fine, the hotcake thing with the 8.2v zener makes a difference because the op-amp itself is clipping in that circuit, and limiting the votage feeding it limits the headroom (I guess). The 10v zener in the P&C just dumps any voltage over 10v to ground if you use the wrong power adapter as well as adding polarity protection.
KindaFuzzy
Postby bunnycat » 15 Feb 2010, 22:35
ok, that makes me feel better. thanks!
bunnycat
Postby Brink » 23 Feb 2010, 02:22
I'm working on a new PCB, one that fits in a 1590B (it's currently 1.9" x 1.9").
I'm working off the latest Krome_Magnon schematic, which I think is the most accurate one traced. (Link:http://img252.imageshack.us/img252/9505/prunesandcustardkhtracegz8.jpg)
The switches in the open position are guitar, LoFreq off. (Closed are Bass, LoFreq on)
Let me know what you think or if you see any errors.
Brink
Postby cornocopius » 23 Feb 2010, 14:07
Awesome Brink! Looking forward to seeing if it can be crammed into a 1590B!
cornocopius
Users browsing this forum: cbriere, fuzzbunny, Google [Bot] and 22 guests
