AMT - Legend Amp Series 2  [traced]
Re: AMT - Legend Amp Series 2
Postby Ice-9 » 01 Oct 2015, 22:28
ggedamed wrote:You're not talking about the thing that Burgs does with his left hand index, are you?
Hope you don't mind me insisting on this :cheers, the sound artifacts are really difficult to explain or even point to.
Well spotted, the little vibrato hammer type of thing he does, also at the 5.05 mark toggling of the pickup switch and it also looks like just before that he may just catch the vol knob.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby phatt » 02 Oct 2015, 15:05
I don't mind if you insist,,, all good. :thumbsup
Between 5:03 and 5:04 there is a fast flurry of notes and there is a lot of mud (maybe the term is inter-modulation)
The P2 is even more pronounced
https://www.youtube.com/watch?v=9CLi4gA_b4M
At 0:43 it spits for a split second on a bend up and again at 0:47 another fast riff,, spatters badly.
Just sayin,,That would bug me. :x
Phil.
phatt
Have thanks: 264 times
Postby Nicht Bernd » 15 Oct 2015, 10:47
The pcb is far too big for a 1590BB. What kind of box do I need?
Nicht Bernd
Has thanked: 98 times
Have thanks: 6 times
Postby DimebuGG » 24 Oct 2015, 00:14
I made a through hole pcb of this for 1590BB type enclosure. Although it's already done, I need to take a look at it again before posting. 8)
What will be the necessary adjustments if 18-24V will be used to power this circuit?.
For this message the author DimebuGG has received thanks: 3
287m (24 Oct 2015, 07:40), J0K3RX (24 Oct 2015, 10:53), Nicht Bernd (24 Oct 2015, 21:44)
DimebuGG
Have thanks: 161 times
Postby phatt » 24 Oct 2015, 08:57
DimebuGG wrote:What will be the necessary adjustments if 18-24V will be used to power this circuit?.
I'd guess,,,,,,,,,a complete redesign. :blackeye Which will likely achieve very little benefit.
If it ain't broke don't fix or frigg with it. [smilie=a_whyme.gif]
Phil.
phatt
Postby bajaman » 24 Oct 2015, 09:05
they were designed for 9v dc - phatt is spot on with his comment - use the correct voltage for the correct response
Has thanked: 438 times
Have thanks: 1506 times
Postby J0K3RX » 24 Oct 2015, 10:52
I think they can use up to 12V... I wouldn't go a hair over +300VDC but, it might be fun to watch somebody else try! :twisted:
J0K3RX
Has thanked: 320 times
Have thanks: 490 times
Postby DimebuGG » 24 Oct 2015, 11:14
J0K3RX wrote: I wouldn't go a hair over +300VDC but, it might be fun to watch somebody else try! :twisted:
Oh yeah, will definitely try that.. :wink:
DimebuGG
Postby Ice-9 » 24 Oct 2015, 18:32
Yeah.. I says 9-12v on the tin, and they sound bloody good so no point I changing the voltage.
Ice-9
Postby DimebuGG » 26 Oct 2015, 01:44
Here it is..
Thanks to bajaman for allowing me to attach his schematic. :applause:
For this message the author DimebuGG has received thanks: 12
287m (26 Jan 2016, 06:22), bajaman (26 Oct 2015, 07:08), blackbunny (19 Oct 2016, 14:47), bmxguitarsbmx (18 Mar 2017, 03:03), brejna (26 Oct 2015, 22:59), ggedamed (27 Oct 2015, 19:52), J0K3RX (26 Oct 2015, 06:58), Manfred (27 Oct 2015, 00:06), Nicht Bernd (26 Oct 2015, 12:58), rcustoms (26 Oct 2015, 03:17) and 2 more users
DimebuGG
Postby J0K3RX » 26 Oct 2015, 19:13
DimebuGG wrote:Here it is..
Damn!! That is some crazy trace work!! Nice job!
J0K3RX
Postby J0K3RX » 18 Oct 2016, 17:47
Found these in the "guitar-gear.ru" forum.. posted by forum member mrubanoff :wink:
For this message the author J0K3RX has received thanks: 8
bajaman (18 Oct 2016, 20:31), blackbunny (19 Oct 2016, 14:46), deltafred (18 Oct 2016, 18:09), dv8r601 (30 May 2018, 20:29), Ice-9 (18 Oct 2016, 22:35), mozwell (19 Oct 2016, 02:13), nenecarrizo83 (18 Oct 2016, 21:26), zamguitar (18 Oct 2016, 20:24)
J0K3RX
Postby Ice-9 » 19 Oct 2016, 20:58
J0K3RX wrote:Found these in the "guitar-gear.ru" forum.. posted by forum member mrubanoff :wink:
I haven't had time to compare these against the traces me and Bajaman made, have you spotted any differences ? :popcorn:
Ice-9
Postby J0K3RX » 21 Oct 2016, 00:56
Nope, just stumbled across them while looking at other stuff and though :hmmm: better grab these before they disappear into the abyss.. Funny though because I think mrubanoff was explaining a problem with the P1 and asking for help to find a resolution but, I could be wrong..? The translation was horrible at best.. Klingon language would probably have made more sense :scratch:
orcl2 (22 Oct 2016, 18:50)
J0K3RX
Postby orcl2 » 12 Jun 2017, 02:33
Hi folks! Someone had tested this schem?
orcl2
Has thanked: 10 times
Postby masramdhani » 12 Jun 2017, 10:15
Thanks bajaman for your schematic.
I made a E2 clone based on your schematic. I use it as a preamp pedal, so i'm not building the drive and the cabsim out. In my country, 2sk208 and 2sk30R is quite rare, so i'm using only 2N5458, J201, and J177. By changing the JFET,re-adjustment of the resistor value for the amplifier stage is needed. I use 1 10k multiturn trimpot to solve those problem especially on the drain resistor. So far the sounds is acceptable. But, i hear a slight of "fart" when the sounds fade out. Still working on it.
Anyway thanks guys :thumbsup :thumbsup :thumbsup
masramdhani
Postby Statzern » 27 Aug 2017, 14:24
Has anyone built this yet? I have the AMT E2 which I love and would love to build just the high gain sections for preamps, but this PCB is big! Would even fit in a 1590BB? Looks like barely from the measurements.
Statzern
Postby POTL » 15 Oct 2017, 06:36
I correctly understand that the p-channel Jfet(T5/T7/T9) for the offset of the n-channel Jfet(T4/T6/T8) but does not affect the sound?
POTL
Has thanked: 65 times
Have thanks: 56 times
Postby mnemonic » 06 Dec 2017, 13:55
bajaman wrote:they were designed for 9v dc - phatt is spot on with his comment - use the correct voltage for the correct response
I was wondering this also, I like to experiment with different voltages, and often pedals will function differently at higher voltage. I can understand how some wouldn't like that change in response and would consider it 'sterile', but a lot of stuff tends to sound punchier to me at 18 volts.
There was mention earlier in the thread of some of the electrolytics being 25 volts, so if all of them were atleast 25 volts I would think the pedal would be fine at 18 volts, right? I googled the data sheets of the transistors and that is still well within their ratings.
I'll have to open up my R2 soon and check the cap voltages. It sounds great at 12 volts but now I'm curious.
mnemonic
Have thanks: 5 times
Postby RockKenny » 16 May 2018, 16:17
For this message the author RockKenny has received thanks: 2
J0K3RX (17 May 2018, 14:49), mnemonic (18 May 2018, 09:33)
RockKenny
Have thanks: 2 times
Previous
Users browsing this forum: allisjake, animalejo, DimebuGG, Jmpj48, marketleader and 14 guests
