AMT - Legend Amp Series 2  [traced]
Re: AMT - Legend Amp Series 2
Postby bajaman » 18 Jul 2015, 14:46
awesome work apollo
Keen to see the finished pedal(s)
ps: I tried running my B2 out of the preamp output into my E2 and then using the cabsim output from the E2 - very smooth!
Has thanked: 400 times
Have thanks: 1336 times
Postby apollomusicservice » 18 Jul 2015, 15:20
My idea was to put these pcb's into rack case, and then with switch to choose a certain type,
and perhaps make the remote control with foot switches. I also adjusted the width and
height of PCB for 1590BB enclosure. I'll see how this will turn out.
For this message the author apollomusicservice has received thanks:
Nicht Bernd (18 Jul 2015, 18:57)
apollomusicservice
Has thanked: 65 times
Have thanks: 758 times
Postby apollomusicservice » 18 Jul 2015, 15:27
bajaman wrote:awesome work apollo
Nice idea, perhaps to make separate outputs for each simulation, and than use these outputs to drive separate amplifiers in same time or switch them. :thumbsup
apollomusicservice
Postby bajaman » 19 Jul 2015, 07:55
Does anyone know where to purchase those cute spline shaft board mounting pots that AMT use in their pedals? They are smaller than the 16mm diameter pots that are easily sourced!
Postby apollomusicservice » 19 Jul 2015, 08:15
bajaman wrote:Does anyone know where to purchase those cute spline shaft board mounting pots that AMT use in their pedals? They are smaller than the 16mm diameter pots that are easily sourced!
Something like these
http://www.alibaba.com/product-detail/1 ... 01008.html
apollomusicservice
Postby bajaman » 19 Jul 2015, 09:56
Thanks apollo - yes similar but they are stereo ganged pots not single 3 terminal types. i went to the manufacturers website - they have lots of 12mm pots but no spline shaft single types.
Postby bajaman » 28 Jul 2015, 13:14
another update folks - the high gain sections so far traced including the D2 - thanks to Ice-9 :hug:
For this message the author bajaman has received thanks: 11
ggedamed (28 Jul 2015, 16:19), Ice-9 (28 Jul 2015, 22:53), J0K3RX (29 Jul 2015, 06:21), juice2 (28 Jul 2015, 19:30), lithiumdeuteride (05 Aug 2015, 18:08), Manfred (28 Jul 2015, 22:51), nenecarrizo83 (19 Aug 2015, 22:34), Nicht Bernd (28 Jul 2015, 19:42), nickthemen (28 Jul 2015, 20:14), snofla1900 (28 Jul 2015, 15:52) and one more user
Postby Ice-9 » 28 Jul 2015, 21:18
Great stuff Bajaman, :applause: I must say again though. These are great pedals and at a realistic price, worth every penny.
For this message the author Ice-9 has received thanks:
bajaman (28 Jul 2015, 22:08)
Ice-9
Has thanked: 137 times
Have thanks: 350 times
Postby bajaman » 28 Jul 2015, 22:13
I absolutely agree with you Ice-9, these are indeed some of the best sounding (and feeling) pedals on the market and SO cheap compared to all those booteek tube screamer variations :roll:
Come on folks - we still need to trace the other pedals in this series: Vt2, O2, M2, R2, P2, C2 :)
Ice-9 (28 Jul 2015, 22:54)
Postby rcustoms » 30 Jul 2015, 07:16
A little contribution
guitars,pedals and amps.
@zuleta.rafael(Instagram)
For this message the author rcustoms has received thanks: 8
287m (04 Aug 2015, 22:18), bajaman (30 Jul 2015, 07:34), Duckman (30 Jul 2015, 12:22), Ice-9 (30 Jul 2015, 14:15), Manfred (30 Jul 2015, 20:00), nenecarrizo83 (19 Aug 2015, 22:38), Nicht Bernd (30 Jul 2015, 18:52), nickthemen (30 Jul 2015, 10:36)
rcustoms
Has thanked: 322 times
Have thanks: 481 times
Postby rcustoms » 30 Jul 2015, 07:23
For this message the author rcustoms has received thanks: 6
287m (04 Aug 2015, 22:21), bajaman (30 Jul 2015, 07:34), Duckman (30 Jul 2015, 12:22), Ice-9 (30 Jul 2015, 14:15), Manfred (30 Jul 2015, 20:00), nickthemen (30 Jul 2015, 10:36)
rcustoms
Postby Duckman » 30 Jul 2015, 12:29
Maybe rotating the BF5458 will simplify the tracing, just to get the drain not so surrounded :hmmm:
For this message the author Duckman has received thanks:
rcustoms (30 Jul 2015, 15:01)
Duckman
Has thanked: 364 times
Have thanks: 125 times
Postby rcustoms » 31 Jul 2015, 05:42
the clean channel
For this message the author rcustoms has received thanks: 4
287m (04 Aug 2015, 22:21), Manfred (31 Jul 2015, 08:06), nenecarrizo83 (19 Aug 2015, 22:38), Nicht Bernd (31 Jul 2015, 08:45)
rcustoms
Postby rcustoms » 31 Jul 2015, 06:15
mr steve ,is posible mix the clean channel with the hi gain eq stage to optain something like fender clean channel emulation? :scratch:
rcustoms
Postby Nicht Bernd » 04 Aug 2015, 09:02
mr rcustoms, for a silly person like me-if the "E2" has let´s say R6 with 100 ohm and the "S2" has not-is it just a wire (bridge) for R6?
Nicht Bernd
Has thanked: 98 times
Have thanks: 6 times
Postby rcustoms » 04 Aug 2015, 19:32
Nicht Bernd wrote:mr rcustoms, for a silly person like me-if the "E2" has let´s say R6 with 100 ohm and the "S2" has not-is it just a wire (bridge) for R6?
hi nicht ,see the schematics e2 and s2 from bajaman the first one r6p=100 ohm for e2, and the second r6p=200 ohm for s2
rcustoms
Postby Ice-9 » 05 Aug 2015, 11:20
Some of the resistors are replaced with wire inks (0 Ohm resistors) on different models of the pedal, this is because the same pcb is used for all the pedals and uses just the configuration of components to make up that particular model type.
Nicht Bernd (05 Aug 2015, 17:39)
Ice-9
Postby Nicht Bernd » 05 Aug 2015, 17:37
Thanks Ice, this I wanted to know.
Nicht Bernd
Postby J0K3RX » 17 Aug 2015, 23:20
Great stuff here!! Anybody have an eagle or diptrace schematic of any of this stuff and feels like sharing with me? Would save me a shit ton of time not having to re-drawing the schematics.. I want them so I can design some boards myself.. I will use Diptrace for that but eagle or diptrace schem is fine, I can convert the eagle using the eagle to diptrace ulp tool...
J0K3RX
Has thanked: 308 times
Have thanks: 471 times
Postby J0K3RX » 18 Aug 2015, 23:14
J0K3RX wrote:Great stuff here!! Anybody have an eagle or diptrace schematic of any of this stuff and feels like sharing with me? Would save me a shit ton of time not having to re-drawing the schematics.. I want them so I can design some boards myself.. I will use Diptrace for that but eagle or diptrace schem is fine, I can convert the eagle using the eagle to diptrace ulp tool...
Well... Alrighty then.
J0K3RX
Users browsing this forum: No registered users and 13 guests
