Hudson Electronic Broadcast  [traced]
Postby tipunk777 » 30 Oct 2015, 15:21
Hello.
I'm a new user of this forum and a french guy, so excuse me if my words are not precise.
I'm looking for this pédal... Image
They say that is inspired by an old RCA broadcast mic preamp. Did anyone have anything about it ?
For this message the author tipunk777 has received thanks:
jtn191 (03 Apr 2016, 20:07)
tipunk777
Re: Hudson Electronic Broadcast
Postby johnk » 23 Dec 2016, 04:38
i have the 9V version but added a charge pump to make it run on 18V internally.
the original is built on veroboard, but here's my PCB layout for it:
For this message the author johnk has received thanks: 2
Manfred (23 Dec 2016, 10:05), Zokk (23 Dec 2016, 13:59)
johnk
Has thanked: 32 times
Have thanks: 272 times
Postby aishabag23 » 23 Dec 2016, 17:00
The guys over at TagboardFX have done a few vero layouts of this one:
http://tagboardeffects.blogspot.com/201 ... dcast.html
Loe Sounds
aishabag23
Has thanked: 95 times
Have thanks: 11 times
Postby Manfred » 23 Dec 2016, 18:11
Where I can find the schematic of it.
Manfred
Has thanked: 1015 times
Have thanks: 606 times
Postby johnk » 24 Dec 2016, 01:58
i drew up a schematic for my 9V version today. it's the one with the trimpot for the high gain.
Manfred (24 Dec 2016, 03:12), Zokk (24 Dec 2016, 10:20)
johnk
Postby johnk » 24 Dec 2016, 06:16
just an FYI. i built both versions (the newer 24V version and the original 9V version which i own) and i like the original 9V version running on 18 or 24 volts better, so i drew up another PCB & built the older version and it sounds identical to my original.
here's the PCB layout for the one that i prefer:
johnk
Postby Manfred » 24 Dec 2016, 13:40
I have a further question.
Are gain selections of the transistor needed?
Manfred
Postby johnk » 24 Dec 2016, 17:03
i've tried OC44's, OC71's and OC 75's and all of them sound pretty much the same.
Manfred (25 Dec 2016, 01:00)
johnk
Postby johnk » 25 Dec 2016, 21:31
i just finished my polished & etched 1590B early version 9V Broadcast (with internal 25V charge pump), with all top jacks and a relayed true bypass:
johnk
Postby fuzzbunny » 25 Dec 2016, 22:46
Great work John K.! (as always...)
fuzzbunny
Has thanked: 15 times
Have thanks: 12 times
Re: Hudson Electronic Broadcast  [traced]
Postby johnk » 30 Dec 2016, 08:49
i forgot one resistor in the above schematic!
here's the correct one:
For this message the author johnk has received thanks: 5
Addy Bart (12 Mar 2017, 00:24), andy-h-h (18 Sep 2018, 10:40), Intripped (03 Jun 2018, 10:17), modman (19 Mar 2018, 15:01), ThiagoFaraday (30 Dec 2016, 22:18)
johnk
Postby aishabag23 » 12 Jan 2017, 04:55
johnk wrote:i just finished my polished & etched 1590B early version 9V Broadcast (with internal 25V charge pump), with all top jacks and a relayed true bypass:
[ Image ]
[ Image ]
Just perfect!
Loe Sounds
aishabag23
Postby gigelmargel » 11 Feb 2017, 21:27
Hello!
Anyone can post the voltages of the transistors, mainly the ones of OC74?
I have only some AC128s and I want to know if are biased right or not.
Thank you!
gigelmargel
Has thanked: 16 times
Have thanks: 15 times
Postby gigelmargel » 27 Feb 2017, 18:32
:scratch:
gigelmargel
Postby V1nce69 » 15 Dec 2017, 16:48
johnk wrote:i drew up a schematic for my 9V version today. it's the one with the trimpot for the high gain.
[ Image ]
I just traced my Broadcast 24V. I unsoldered all diodes on the power supply board to be sure of the type. I made an true to the original vero layout and measured the voltages on both transistors.
Hudson Electronics Brodcast 24V, PG Edition_vero layout.pdf
If you have any questions feel free to ask. I took many pictures. I can post them later.
Vincent
For this message the author V1nce69 has received thanks: 3
Addy Bart (23 Mar 2018, 06:38), andy-h-h (16 Aug 2018, 12:57), Intripped (03 Jun 2018, 09:57)
V1nce69
Has thanked: 30 times
Have thanks: 66 times
Postby V1nce69 » 16 Dec 2017, 06:00
If you have any questions feel free to ask...
Vincent
And here are all the pictures:
For this message the author V1nce69 has received thanks: 4
Addy Bart (23 Mar 2018, 06:38), Intripped (03 Jun 2018, 10:16), modman (19 Mar 2018, 15:02), plush (29 Jan 2018, 10:44)
V1nce69
Postby plush » 29 Jan 2018, 10:45
Hi!
I can verify V1nce69's work.
plush
Has thanked: 26 times
Have thanks: 56 times
Postby teddeeh » 19 Mar 2018, 13:54
Heres a couple of photos i have found of the dual footswitch.
Sadly no underside but could be worrh an experiment or two in decifering this layout, as wehave the original one to go from and fundamentally they are the same.
teddeeh
Have thanks: 10 times
Postby andy-h-h » 15 Aug 2018, 10:13
Can this be built without the transformer? It looks like it's just acting as decoupling / isolation device.
andy-h-h
Have thanks: 2 times
Postby marshmellow » 15 Aug 2018, 12:04
Yes, you can build it without the transformer. But it's not in the circuit to provide isolation (as drawn it doesn't), it is there to form the sound. In comparison to an overdriven guitar sound, transformer distortion is very subtle, its contribution might be minimal anyway. These little transformers usually also have very limited bandwidth, so to mimic the sound of the original pedal, you will probably have to introduce at the very least some bass cut.
marshmellow
Have thanks: 123 times
Next
Users browsing this forum: Chris 1.0, pedalpartsuk, storyboardist, wannacmypokemons and 5 guests
