How to get your Youtube video embedded in your post
Postby modman » 20 Nov 2015, 14:42
There is a little trick to getting the Youtube vids embedded
https://www.youtube.com/watch?v=o0b3ZzlRRQs
needs to be embedded as: (delete the s in the "https")
Code: Select all
[youtube]http://www.youtube.com/watch?v=o0b3ZzlRRQs[/youtube]
which gives you:
Link
hope to fix this bug permanently in a short while with upgrades of forum software
(it's that time again, has been for some time)
Has thanked: 3217 times
Have thanks: 602 times
Re: How to get your Youtube video embedded in your post
Postby Limadito » 21 Nov 2015, 20:08
(This is my first post on the site, even when I have been a registered user for a few years...)
A workaround for the "https://" issue is modify the YouTube bbCode in this way: replacing the "http" for the {IDENTIFIER} tag will make the bbCode work well with both protocols.
Code: Select all
[youtube]{IDENTIFIER}://www.youtube.com/watch?v={TEXT}[/youtube]
And the HTML replacement should look something like this:
Code: Select all
<object width="640" height="526"><param name="movie" value="{IDENTIFIER}://www.youtube.com/v/{TEXT}"></param><param name="wmode" value="transparent"></param><embed src="{IDENTIFIER}://www.youtube.com/v/{TEXT}?rel=0" type="application/x-shockwave-flash" allowfullscreen="true" wmode="transparent" width="640" height="526"></embed></object>
Using this bbCde the video will be displayed, no matter the YouTube link uses "http://" or "https://" .
Hope this helps! :D
Limadito
Postby Duckman » 22 Nov 2015, 05:21
Link
Just to try as modman recommend
Duckman
Has thanked: 369 times
Have thanks: 141 times
Postby Duckman » 22 Nov 2015, 05:25
And works like a charm... thanks modman (disabeled thanks button?)
Duckman
Postby Limadito » 22 Nov 2015, 11:46
Duckman wrote:And works like a charm... thanks modman (disabeled thanks button?)
Removing the "s" by hand will work for sure, the code I've suggested do that for the user (well, not exactly, but does the job... ) :wink:
Limadito
Postby modman » 23 Nov 2015, 12:18
Code: Select all
Warning
The BBCode you are trying to add seems to use a {TEXT} token inside a HTML attribute. This is a possible XSS security issue. Try using the more restrictive {SIMPLETEXT} or {INTTEXT} types instead. Only proceed if you understand the risks involved and you consider the use of {TEXT} absolutely unavoidable.
Postby Limadito » 24 Nov 2015, 22:28
Code: Select all
Warning
Yes, this is a stadard message while editing that bbCode, coming from the use of the {TEXT} token in the bbCode itself and no related to the mod proposed (try to modify the size attributes of the bbCode in use, and you will get the same warning). I've been using it for few years without security issues, but if you aren't sure, don't use it. :thumbsup
There is a way to avoid that warning, and is adding a video wrapper to the common.ccs file of the theme in use. This will allow the use of the newer YT player in HTML5 capable browsers (without using Flash layer), but won't work as a drop-in replacement (you will need to create a new tag for inserting video).
At the very end of your common.ccs, add:
Code: Select all
/* Custom styles
.video-wrapper {
   width: 640px;
   max-width: auto;
.video-container {
   position: relative;
   padding-bottom: 56.25%;
   padding-top: 30px;
   height: 0;
   overflow: hidden;
.video-container iframe, .video-container object, .video-container embed {
   position: absolute;
   top: 0;
   left: 0;
   width: 100%;
   height: 100%;
The bbCode in use is
Code: Select all
[yt]{IDENTIFIER}://{SIMPLETEXT}.youtube.com/watch?v={SIMPLETEXT2}[/yt]
And HTML Replacement is
Code: Select all
<div class="video-wrapper">
<div class="video-container">
<iframe class="youtube-player" type="text/html" width="640" height="526" src="{IDENTIFIER}://{SIMPLETEXT}.youtube.com/embed/{SIMPLETEXT2}?rel=0" allowfullscreen frameborder="0"></iframe>
</div>
</div>
This bbCode will not trigger the warning mentioned above.
Limadito
Postby PegasusOne » 12 Sep 2019, 14:48
Embed videos & playlists
1. On a computer, go to the YouTube video you want to embed.
2. Under the video, click SHARE .
3. Click Embed.
4. From the box that appears, copy the HTML code.
5. Paste the code into your blog or website HTML.
PegasusOne
Users browsing this forum: No registered users and 18 guests
