Earthquaker Devices - Grand Orbiter
Earthquaker Devices Grand Orbiter
Postby Beedoola » 06 Sep 2014, 02:45
Anyone have any info one this circuit?
Beedoola
Has thanked: 19 times
Have thanks: 28 times
Re: Earthquaker Devices - Grand Orbiter
Postby destro » 16 Dec 2015, 05:24
I checked out the v1 at some point and found it was very similar to the ross phaser with mods similar to the ones at tonepad. I know they also mention the dod490, but found more similarities to the ross. Check out tonepad's add on stage board if you want deeper.
destro
Have thanks: 36 times
Postby Pokfor » 02 Jul 2018, 12:35
I was interested in this pedal. Who can make a photo of the board?
Pokfor
Has thanked: 10 times
Have thanks: 12 times
Postby modman » 02 Jul 2018, 13:02
Pokfor wrote:I was interested in this pedal. Who can make a photo of the board?
Who can use google?
destro wrote:I checked out the v1 at some point and found it was very similar to the ross phaser with mods similar to the ones at tonepad. I know they also mention the dod490, but found more similarities to the ross. Check out tonepad's add on stage board if you want deeper.
Who can read?
Has thanked: 3147 times
Have thanks: 584 times
Postby plush » 02 Jul 2018, 13:05
Google images
V3 is based on 3 lm13700 and 1 tl074 same as v2 does, but uses SMT and 1/8w resistors
plush
Has thanked: 25 times
Have thanks: 46 times
Postby Pokfor » 02 Jul 2018, 13:22
I already saw these pictures, and believe me, I studied them in great detail. I used Google for a long time before writing here. I was hoping to see something more detailed than these two photos.
The fact that the base is coming from Ross, I already understood and confirmed on these photos, but it seems to me that interesting solutions on the diagram should.
For example, work Sweep. I understand how it is arranged theoretically, but I would really like to see it.
Depth is also interesting. I thought this controller controls the width of the LFO, but it turned out that it really mixes dry and wet signals.
Sorry for my english
Pokfor
Postby POTL » 03 Jul 2018, 16:32
Need good photos of the board from two sides.
Let's think about what we have.
1) The site says that this is a 4-stage phaser, then 2 lm13700 are used in the phase shift phase
2) According to different sources - this scheme is based on DOD490 and ROSS Phaser, then 3 lm13700 is used in the LFO section
3) We have 4 channel op amp, if we look at the madbead project, we can understand how it is used
a) Input buffer
b) The virtual ground's buffer
c) Input filter
d) Output filter
Many argue that the sound is more like Phase 90 than Small Stone, so in the filter section, you should expect components that are similar in terms of denominations.
http://www.madbeanpedals.com/projects/S ... ht2015.pdf
http://freestompboxes.org/viewtopic.php?t=1894&p=186129
For this message the author POTL has received thanks:
modman (18 Jul 2018, 12:45)
POTL
Has thanked: 65 times
Have thanks: 60 times
Users browsing this forum: No registered users and 12 guests
