Bogner La Grange  [traced]
Postby Saruman » 01 Jul 2016, 09:17
For this message the author Saruman has received thanks: 36
bajaman (01 Jul 2016, 10:42), Danch (18 Jan 2017, 13:32), electrosonic (01 Jul 2016, 19:25), Greenmachine (13 Jan 2017, 23:17), IvIark (15 Nov 2016, 00:23), Manfred (01 Jul 2016, 10:46), mensur (01 Jul 2016, 19:16), modman (01 Jul 2016, 15:47), pablocarrillo (15 Jan 2017, 00:18), roseblood11 (03 Jul 2016, 13:49) and 26 more users
Saruman
Have thanks: 124 times
Re: Bogner La Grange
Postby Intripped » 01 Jul 2016, 12:36
wow, you've done a great work here! thanks!
how did you managed to remove that goop?
I see from the schem a lot of similarities with the zwex pedals (SHO, Box Of Rock, ...can you identify the transistors' numbers? bs170?), but there's also an opamp stage and hard clipping with different diodes options, which i don't recognize as a known circuit, in this moment.
For this message the author Intripped has received thanks:
Tjarko (09 Mar 2017, 22:28)
Intripped
Has thanked: 583 times
Have thanks: 215 times
Postby Saruman » 01 Jul 2016, 14:24
Im Degoop Doctor :?
opamp (OPA132) K=1,5. Its boffer.
bs170 as in exampes:
For this message the author Saruman has received thanks: 4
blackbunny (11 Jan 2018, 01:17), fahri (29 Mar 2018, 23:23), Manfred (02 Jul 2016, 04:02), modman (01 Jul 2016, 15:55)
Saruman
Postby Saruman » 01 Jul 2016, 17:11
La Grange is modified Zvex Box Of Rock.
fahri (29 Mar 2018, 23:23), modman (28 Mar 2018, 18:28), roseblood11 (03 Jul 2016, 13:50)
Saruman
Postby fuzzbunny » 01 Jul 2016, 20:17
:applause: Bravo!
fuzzbunny
Have thanks: 10 times
Postby bajaman » 01 Jul 2016, 23:05
:D
What is that pic chip for ?
Has thanked: 443 times
Have thanks: 1514 times
Postby Intripped » 02 Jul 2016, 12:31
this La Grange looks like a combination of different pedals; from what i can see there is:
- a switchable BOOST section (SHO) in front
- an op-amp gain stage (if i'm not wrong the gain is 2.5, being R37(rf)=15K and R31(r2)=10K, in a non-inverting configuration)
- a modified COT50, ala Briggs, with different clipping options, "nature"="blend" and "structure"=fixed value
- a Box Of Rock with some tweaks and options
Lithium_Grim (29 Nov 2017, 09:18)
Intripped
Postby Chugs » 03 Jul 2016, 07:56
Nice work. Is there parts values for the schematic?
Chugs
Has thanked: 59 times
Have thanks: 49 times
Postby bajaman » 03 Jul 2016, 08:19
That op amp buffer / gain stage looks a bit weird - if it is powered by+9 and -9 volt supplies why is there an additional +9v bias rail ?
Postby Saruman » 03 Jul 2016, 11:05
Only after crack Red Ecstasy Pedal. Waiting for 3 years on this forum, but why owners Red Pedl are very lazy :cry:
I buy La Grage and after 5 days I havу it scematic.
That op amp buffer gain stage looks a bit weird - if it is powered by+9 and -9 volt supplies why is there an additional +9v bias rail ?
bias rail is + 0.7V gives maximum undistorted signal on opamp
Intripped, you are absolutely right! :applause: 15k,10k
Saruman
Postby rcustoms » 03 Jul 2016, 21:23
awesome work dude,values please to draw the pcb
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Has thanked: 346 times
Have thanks: 491 times
Postby Intripped » 04 Jul 2016, 12:27
Saruman wrote:Intripped, you are absolutely right! :applause: 15k,10k
i'm Resistor Ronker :?
...bytheway: what does ronker mean?
Intripped
Postby Saruman » 04 Jul 2016, 16:34
I do not know, I'm not an еnglish speaker!
Saruman
Postby FuzzMonkey » 05 Jul 2016, 08:34
Try Urban Dictionary maybe???
FuzzMonkey
Has thanked: 25 times
Have thanks: 24 times
Postby J0K3RX » 06 Jul 2016, 02:49
I think it's pretty much the British equivalent of what Americans refer to as, trailer trash, white trash, wal-mart people etc.. Definitely not a compliment.. :lol:
J0K3RX
Has thanked: 321 times
Have thanks: 492 times
Postby orcl2 » 27 Jul 2016, 20:25
Hi guys, nice work by the way, did you have the schem fot this?
orcl2
Has thanked: 10 times
Postby Saruman » 29 Jul 2016, 09:45
to be continued.....
Saruman
Postby FuzzMonkey » 30 Jul 2016, 04:36
Saruman wrote:to be continued.....
I look forward to it. Can I ask if the pedal still works after de-gooping it? I know they're not exactly cheap.
FuzzMonkey
Postby Saruman » 01 Aug 2016, 08:53
Рedal work after de-gooping. No problem.
Saruman
Postby Saruman » 08 Nov 2016, 08:44
For this message the author Saruman has received thanks: 20
Greenmachine (13 Jan 2017, 23:18), IvIark (15 Nov 2016, 00:28), lohstah (08 Nov 2016, 21:20), Manfred (08 Nov 2016, 09:00), mensur (21 Nov 2016, 03:30), mr coffee (20 Jan 2017, 06:10), nickthemen (08 Nov 2016, 12:33), Sari (13 Nov 2016, 07:16), theleftfoot (30 Nov 2017, 10:48), toneman (09 Nov 2016, 00:50) and 10 more users
Saruman
Next
Users browsing this forum: turbofeedus and 9 guests
