smallsound/bigsound - mini  [traced]
Re: smallsound/bigsound mini
Postby smallsnd/bigsnd » 31 Oct 2017, 18:36
natron_mn wrote:Just discovered this awesome thread. I was going to attempt to build this little monster, but had a question first.
What is the minimum voltage on the 220uf cap? I have some of those cool low profile Lelon caps, but they are only rated 10V.
I'm not sure how to tell from a schematic what the voltage requirements are for a given component.
you should always use caps that are rated higher than the supply voltage - get some 16V caps to be safe. :thumbsup
For this message the author smallsnd/bigsnd has received thanks:
natron_mn (31 Oct 2017, 18:50)
smallsnd/bigsnd
Have thanks: 79 times
Postby natron_mn » 31 Oct 2017, 18:57
Thanks Brian!
Is the supply voltage just 9V? More generally, is the supply voltage for any pedal with a 9V power supply simply going to be 9V? Or, do voltages change within the pedal depending on the transistors/ICs?
In this schematic, it looks like there is only a diode and resistor between V+ and the 220uf resistor. So the diode is simply a circuit protection diode and won't change the voltage hitting the 220uf cap?
Sorry if this question is ig'nant. I'm wanting to learn how pedals function as opposed to just building premade pcbs with instructions (a la Madbean pcbs). Those are fun to build, but I'm not really learning anything other than how to solder and follow instructions!
natron_mn
Have thanks: 3 times
Re: smallsound/bigsound - mini
Postby natron_mn » 18 Dec 2017, 16:16
FYI, I picked up an actual SS/BS Mini, and that pedal just rips. So versatile! I still want to attempt building one, but now it's not as big of a rush since I have the real deal!
Way to crush this one, Brian!
natron_mn
Postby natron_mn » 09 Jun 2018, 22:15
Anyone know if I can substitute the 1n5158 diode? Is it just a polarity protection? Could I use a 1n4001 instead?
I’ve never heard of the 5158 diode before. Only 5818
natron_mn
Postby BetterOffShred » 09 Jun 2018, 23:46
Yeah toss a 4001 or a 5817 in there for sure. According to the schematic on page 1 of this thread it's just a polarity protection as suspected. :thumbsup
For this message the author BetterOffShred has received thanks:
natron_mn (10 Jun 2018, 02:03)
BetterOffShred
Have thanks: 2 times
Postby smallsnd/bigsnd » 10 Jun 2018, 21:26
natron_mn wrote:FYI, I picked up an actual SS/BS Mini, and that pedal just rips. So versatile! I still want to attempt building one, but now it's not as big of a rush since I have the real deal!
thanks! :D
BetterOffShred wrote:Yeah toss a 4001 or a 5817 in there for sure. According to the schematic on page 1 of this thread it's just a polarity protection as suspected. :thumbsup
yeah i use 1n5818 for less of a voltage drop than a 1n4001. 5817 would be even less but really any of the above will be totally fine.
smallsnd/bigsnd
Postby natron_mn » 11 Jun 2018, 16:54
Thanks you two! :hug:
I hope to get building this week and report back my findings
natron_mn
Postby natron_mn » 27 Jun 2018, 21:08
About to start building this (finally).
I saw on the first page something about a scramble mod. Would you still happen to be able to share that, Brian? I know I should walk before I run and get the initial build up and running, but I can't help myself :)
natron_mn
Previous
Users browsing this forum: Analogisch, EmmG, LeFather and 19 guests
