Friedman BE-OD Pedal  [traced]
Re: Friedman BE-OD Pedal
Postby rmroza » 07 Oct 2017, 03:38
"A bit ot but apparently Friedman has more stuff to come:
Link
I see more peoples take on the board(s) were created. Because I had sooo many problems with this pedal, I just walked away from it for a long while. I may get back into it to figure out wtf was the problem now that the Summer is over and I have some time. I wonder if just upping the one cap as outlined pages ago would help?
I see there is the latest board that states no oscillation but looks like a hybrid as through-hole and SMD! I'm wondering why SMD at all and if you're going to do that, why not just create and EXACT clone, depopulate the pedal, and make a PCB from it and just post it. Then people would purchase the exact components and eliminate all of the osciallation and issues we had??
In regard to the top comment and link....it seems Friedman adds the MIDDLE pot to the Buxom and Shirley. I know Friedman's design are bascially exactly the same with small tweaks and the Middle pot was not included as a single pedal package was already maximized with 6 post, but think seeing how done in these other pedals and incorporating into the BE-100 with a larger enclosure would be a huge win!
My thoughts.
rmroza
Have thanks: 44 times
Postby Frabbio » 07 Oct 2017, 16:43
rmroza wrote:" I wonder if just upping the one cap as outlined pages ago would help?
My thoughts.
Upping the cap may reduce or eliminate the oscillation, but it will affect the tonal response of the pedal. Using short and shielded wires, especially on the input and the pots may help.
The layout uses smd IC because I have a lot of them, and SOIC-8 and SOT-23 are pretty easy to solder (i don't even turn on the hot air station for these packages).
I confirm that the layout is free of oscillation even with the gain control and gain trimmer maxed
Frabbio
Has thanked: 10 times
Have thanks: 76 times
Postby psychepool » 11 Oct 2017, 15:10
Here's mine. I drawn my own layout for 1590A encloser.
Clipping diode is BAV99 but I think nothing difference with 4 x 1N4148.
Change 120pF on feedback cap with 470pF. (for lower noise)
For this message the author psychepool has received thanks: 4
apollomusicservice (12 Oct 2017, 20:00), jimroot (01 Feb 2019, 17:29), nexion777 (12 Oct 2017, 15:32), roseblood11 (12 Oct 2017, 18:16)
psychepool
Have thanks: 19 times
Postby 287m » 11 Oct 2017, 18:24
psychepool wrote:Here's mine. I drawn my own layout for 1590A encloser.
finally, another 1590A Wizard
Awesome man!
287m
Has thanked: 313 times
Have thanks: 56 times
Postby Jan1966 » 11 Oct 2017, 18:49
Very good.
Fine bit of building and perfboard too you maniac.
Jan1966
Has thanked: 13 times
Have thanks: 16 times
Postby roseblood11 » 12 Oct 2017, 18:18
Great!
Please share the layout... Do you have any problems with noise or oscillation at higher gain settings?
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby psychepool » 13 Oct 2017, 11:00
Here's the layout. The reason that I didn't show my layout is there's many unpredictable cases.
I've been working on layouts to take into account the size of the parts, but in reality, there will be many challenges.
It is important to choose the size of the parts. I will give you some notes.
1. The film capacitors must have a lead spacing of 5mm.
2. The capacitors in pF should be chosen to be able to be mounted at 2.5mm intervals. (ceramic or monolithic would be good)
3. Electrolytic capacitors height must be 7mm or less.
4. If use the 8 pin / 14 pin exclusive IC socket, you can't install resistors under the IC socket.
So you must always cut out four or seven slots in a row and use them in two rows.
5. Wiring must be connected on the soldering side, not on the parts side.
6. Potentiometers must use 9mm size.
7. To secure the height to which the PCB is inserted and to insulate it, use a box jack as shown below and install as close as possible to the top of the case
Drilling guides are slightly different in size from case to case, so you will have to arrange them yourself by yourself.
It is not easy to make it, and it is difficult to make it more reliable than anything else.
You should be careful not to have shorts or disconnection.
Good luck to you.
For this message the author psychepool has received thanks: 5
287m (13 Oct 2017, 11:53), bancika (13 Oct 2017, 13:11), bmxguitarsbmx (15 Oct 2017, 04:33), modman (12 Nov 2017, 15:27), pete_el34 (29 Jan 2018, 02:42)
psychepool
Postby psychepool » 13 Oct 2017, 11:05
There is a little noise, but it's because of the amount of distortion.
The noise does not make you feel uncomfortable.
I know that the original pedal also has a lot of noise.
Perhaps if you use not such a complicated layout, it will have less noise. If so, no one will feel the image that this pedal is noisy.
psychepool
Postby 287m » 13 Oct 2017, 12:01
Now is answered :applause:
psychepool layout is like my hero, miniaturization guru, the one and only, Sijosae :twisted:
although mine perfboarder too, i almost never use 45 degree track, unless use thin leg
287m
Postby Branimir » 24 Oct 2017, 18:04
Built mine today:
Image Image
Used 470pF instead of 120pF, and looks like I forgot to order the 10k rev Log pot for Presence, so I used 10k linear and it's still usable :)
Also, used 1N4148's as seen on photos, and TL082's instead of TL072, only had one TL072.
The protection diode is 1N4001 probably, I didn't have the other one that's noted in the original schem, it's just reverse polarity protection, it doesn't matter.
Only tried it with a small crappy solid state amp, but it sounds great, even through that :) I like how the treble and presence react to each other, and overall all the pots are quite useful, especially the "Tight" knob.
No oscillation, even with the trimpot fully clockwise, tight build for 1/4 resistors!
Now to find some letters to label it and that's it!
If you scoop, it sounds like poop!
Branimir
Have thanks: 2 times
Postby Ice-9 » 24 Oct 2017, 18:41
rmroza wrote:agung - Good to know and thanks for the feedback. How is the noise and squeal situation?!??
I've been busy with amps, but finished up yesterday, so will circle back around into seeing why all of the BE-OD clone (2-vero, 2-pcb) do not work!! People seems to be getting both variations done and the one common theme is "me", so I need to see what the fuck is up. I've built hundreds of pedals and never had problem(s) like this and nothing works. Components are correct and orientation and no apparent solder bridges. I'll try connecting the pots directly on and increasing the cap as many have suggested. Other than that, I'm out of options. It should work, but doesn't and some pots in reverse direction!
Hi rmroza, I'm just wondering if you managed to get to the bottom of the problem you had with the 4 different builds you made of this pedal. It would be helpful to us all if you got it sorted. :popcorn:
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby bugg » 28 Oct 2017, 13:42
For this message the author bugg has received thanks: 5
287m (02 Nov 2017, 03:01), alltrax (28 Oct 2017, 19:56), Belanger88 (28 Oct 2017, 16:50), caspercody (28 Oct 2017, 20:23), J0K3RX (31 Oct 2017, 18:37)
bugg
Has thanked: 36 times
Have thanks: 229 times
Postby johnk » 31 Oct 2017, 00:47
i just finished one and it sounds great.
For this message the author johnk has received thanks: 4
alexradium (14 Nov 2017, 14:16), bucksears (01 Nov 2017, 12:23), rcustoms (02 Nov 2017, 15:56), roseblood11 (02 Nov 2017, 19:25)
johnk
Has thanked: 31 times
Have thanks: 270 times
Postby Nacho5 » 01 Nov 2017, 00:15
johnk wrote:i just finished one and it sounds great.
Which layout did you use?
Nacho5
Have thanks: 5 times
Postby johnk » 01 Nov 2017, 01:22
i used a modified storyboardist one. it had to be modified to fit in a 125B.
johnk
Postby bucksears » 02 Nov 2017, 02:26
Is there a link anywhere online?
I'm working one out in Adobe Illustrator, but if there's something already available, I'd be keen to have a look.
bucksears
Postby 287m » 02 Nov 2017, 02:59
bucksears wrote:
johnk wrote:i used a modified storyboardist one. it had to be modified to fit in a 125B.
David Storyboardist layout --> http://effectslayouts.blogspot.co.id/2017/08/friedman-be-od.html
For perfboarder like me, this pedal and dirty shirley is hard to get all onboard pots in 1590B
But, here the WIP while waiting pots and enclosure :oops:
287m
Postby ballfire » 10 Nov 2017, 11:22
hey good day to every body..
i think im gonna build this overdrive ..may i know where i can find the right schematic of this pedal ??
thank you..
ballfire
Has thanked: 28 times
Postby bugg » 10 Nov 2017, 12:52
ballfire wrote:hey good day to every body..
thank you..
http://www.pedalpcb.com/docs/Thermionic ... ion.v2.pdf
ballfire (11 Nov 2017, 02:27)
bugg
Postby brddx1 » 10 Nov 2017, 15:38
thank you..
Hey Bugg, may I ask what difference is between the 2 pcb versions? I just purchaced v1 with 1/8W resistors.
For this message the author brddx1 has received thanks:
brddx1
Users browsing this forum: Bside2234, Korniskc, lietuvis, rhandy gaye and 10 guests
