Page 30 of 32
Re: Friedman BE-OD Pedal
PostPosted: 11 Nov 2017, 02:31
by ballfire
good day..and more power to those people here..
hey bugg thank you for the schematic..
Is this the schematic that sound like the 80s metal thing setting of friedman clone..??? i saw a youtube demo of friedman clone that sound like fuzz pedal and i dont like it.. other sound like really good like metal tone.. i like the metal tone sinister sound..its impressive..
thanks again i really appreciate it.. :D
PostPosted: 11 Nov 2017, 03:58
by bugg
brddx1 wrote:Hey Bugg, may I ask what difference is between the 2 pcb versions? I just purchaced v1 with 1/8W resistors.
The new version uses 1/4W resistors because a few people had trouble sourcing 1/8W resistors (I get mine from Tayda), also the component placement was made a bit more symmetrical to satisfy my obsessive tendencies.
Aside from that, there is no difference... The tone, circuit, wiring, and control layout is exactly the same.
PostPosted: 12 Nov 2017, 05:20
by ragtime8922
I used the first bugg board and it was tight with 1/4 resistors but worked fine. Which cap is causing the oscilation? I may switch in the new cap because there is a killer George Lynch tone to be dialed in with the oscilation but I don't want it all the time. I love this circuit.
PostPosted: 12 Nov 2017, 10:11
by Branimir
I used 470pF instead of 120pF, no oscillation whatsoever.
PostPosted: 12 Nov 2017, 18:02
by jalmonsalmon
Branimir wrote:I used 470pF instead of 120pF, no oscillation whatsoever.
I would socket that space and try different cap values
PostPosted: 14 Nov 2017, 13:46
by alexradium
johnk wrote:i just finished one and it sounds great.
which layout was used for this?
nice one,thanks
PostPosted: 14 Nov 2017, 17:45
by johnk
PostPosted: 16 Nov 2017, 11:39
by johnk
alexradium wrote:its funny!
this layout is also different from your finished pedal!
i will check it out,thank you!
you're right! here's the one that i used for the pedal:
PostPosted: 16 Nov 2017, 11:56
by modman
Summarized the thread in the first post: viewtopic.php?f=7&t=27775&p=259677#p259677
PostPosted: 18 Nov 2017, 23:31
by roseblood11
Under "definite schematics" you link to the thermionic build doc, which shows silicon clipping diodes. And to a post by bajaman, where he states that only those zetex transistors can sound right, but it's schottkys in the attached schematics.
PostPosted: 20 Nov 2017, 02:53
by ballfire
good day ..
i think the 120pf is not actually 120pf because by looking on the actual pictures on pcb board, the yellow capacitor seems look bigger..may be they tamper the label on it just to confused who may want to trace the actual pedal.. :hmmm:
PostPosted: 20 Nov 2017, 11:41
by modman
roseblood11 wrote:Under "definite schematics" you link to the thermionic build doc, which shows silicon clipping diodes. And to a post by bajaman, where he states that only those zetex transistors can sound right, but it's schottkys in the attached schematics.
Yes, it's a mess... is there a more definite schematic available?
ballfire wrote:good day ..
it's voltage rating that determines the size of a capacitor...
PostPosted: 20 Nov 2017, 14:53
by Frabbio
download/file.php?id=30088&mode=view
I built it using this schematic and i got no problem with oscillation with the 120pF cap, the pedal sounds really close to the demos using 2 x BAV99.
From what i gathered this schematic should be correct, the only missing components are 2x100nf capacitor used as decoupling cap for the opamps, but it works flawlessly even without them.
If someone else has built this version, please chime in and share your experience!
PostPosted: 20 Nov 2017, 17:07
by Frabbio
Single sided layout for Dirty Shirley+Friedman BeOd in a box, this layout has the best of both worlds, there are 7 pcb mounted pots so you can build a BeOD with a mid control, or a DS with a tight knob, as said before the only notable difference is R16 in my schematic (10k for BEOD, 27k for DS).
I used through hole ICs this time, but i kept the smd diodes (BAV99). If somebody is interested i can post the same layout with normal diodes.
Board dimensions are 115x40mm, it should fit in a hammond bb enclosure.
Layout still unverified but it should work.
If you build it please report if everything is working as intended.
Good DIY!
PostPosted: 20 Nov 2017, 20:23
by bugg
Very nice, I have a similar board on order. Can't see any reason it wouldn't work.
I'm really not a fan of the toggle switch sticking out the side of the original DS.
PostPosted: 02 Dec 2017, 22:53
by mnemonic
I got Bugg's PCB the other day, real quality board. I like how symmetrical the layout is. I both love and hate how compact it is... It looks great and I'm glad it fits so well into a 125b, but that compactness does make it a bit harder to work on. No big deal for experienced people but I can still count on two hands how many pedals I've built. I'll get there, I hope.
Worked perfect on the second try (I somehow managed to flip the reverse polarity protection diode). Really great sounding pedal!
(Please ignore the giant red 10n caps, didn't realise the ones I had were too big until I was already half way done, and I'm too impatient to wait for replacements)
PostPosted: 22 Dec 2017, 14:53
by Willypp
I might as well join in the fun. Here's my Bugg board with with a stripped Fetto on vero from the Sabrotone layout. When engaged, you can switch between the Fetto or the BE-OD, and there's a footswitch for switching between gain pots for the BE-OD. I used a 1n5 for instead of the 120p from memory. I have another of his boards to box up too. I run the trimmer flat out, and I'm not very convinced by it at lower gain, but love it cranked. Bit annoyed at that gain knob being out of line with everything else!
PostPosted: 12 Jan 2018, 15:06
by bucksears
I may have missed it, but is there a description of how to mod a BE-OD to add a mid control?
PostPosted: 12 Jan 2018, 17:53
by bugg
bucksears wrote:I may have missed it, but is there a description of how to mod a BE-OD to add a mid control?
Take a look at the Dirty Shirley schematic, it's basically the same circuit with a Mid control instead of a Tight pot. viewtopic.php?f=7&t=28654
The "Brown Betty" combines all of the functionality of both pedals into one.
http://www.pedalpcb.com/product/brownbetty/
PostPosted: 14 Jan 2018, 12:27
by Visualdistortion
Hey,
I've used for the 1N5819 for diode instead of the BAV99 and it seems to be a great thing!
