Zvex - Fuzz Factory 7
- tube-exorcist
Of course...... Zachary should have one.
- theblackman
get fuzz face, add knobs.
- xaxxop
It’s a fuzz factory using 50s transistors, adding a passive tone control (I wonder if the tone control is like the woolly mammoth), a switch to bypass the tone control and and 9 position switch for the fat feature (I guess switching the original 10nF capacitor for 8 more differents values).
Is someone brave enough to draw a eschematic to start testing?
I will try one tomorrow
Leo
Leo
Leandro
- jrfox92
- Completed builds: Death by Audio Fuzz War
Electro-Harmonix Big Muff Pi V5
Skreddy Lunar Module
Colorsound Overdriver
Electro-Harmonix Big Muff Pi Multi-Diode and Feedback Mod
Electro-Harmonix Holy Grail Room Reverb and Reverb Length Mod
Boss DS-1 Synth Circuit Bend - Location: Akron, Ohio
- Has thanked: 3 times
- Been thanked: 54 times
eatyourguitar probably has one.
eatyourguitar wrote: schematic:
[ Image ]
the switch should be DPDT ON-OFF-ON so you can go back to the stock fuzz factory. everything on here is designed so you can go back to the fuzz factory. I did not want to build something that could not replace my old 7 knob fuzz factory that I sold and ZVEX copied exactly 3 years ago. the output volume is doubled without adding noise from extra gain stages. the only thing I am a little unsure about are the values for C7 and C4. if you want to do the tone control like the official zvex 7 knob, you should leave tone pin1 disconnected or maybe just move the tone control to the output jack like a guitar. I am finishing up the pcb design right now if anyone is interested PM.
comments and suggestions welcome.
