Page 5 of 6
Re: Tube-Vibe
Posted: 21 Oct 2009, 10:43
by guiddruid
This is the suspected microcontroller:
http://www.microchip.com/wwwproducts/De ... e=en010277
Once we have figured out which pins of this chip go where, it shouldn't be too hard to write some code which will work in a _similar_ fashion.
To get it _very_ close to the original will probably require some measurements of a working device, and will depend on exactly how the device is connected...
Re: Tube-Vibe
Posted: 21 Oct 2009, 10:58
by Greg
Good start..
I'll try to do the resistors this week.
Re: Tube-Vibe
Posted: 21 Oct 2009, 11:15
by borislavgajic
Here it is.........now mister Greg_G please make part list (if you can)....
boris
p.s.
this is for spam-lovers......
Re: Tube-Vibe
Posted: 21 Oct 2009, 11:29
by borislavgajic
so if we compare this two drawings....
.....I am very intrigued about
power supply of this baby......so small,going on 12volt
DC ..draws 3 tubes...
..great for all tube projects.....tiny amplifiers...........
somebody with greater knowledge (then mine) could help ........?
boris
and if there is someone with PHASEoMATIC....it would be great to see guts of that......just to see how RESONANCE pot is conected.......[/b]
Re: Tube-Vibe
Posted: 21 Oct 2009, 11:39
by MWichni
Hi Boris, you have forgotten about inductor on the layout. BTW Tubes are powered with high voltage instead of the lfo section which is +5V I believe?
Regards,
Mariusz.
Re: Tube-Vibe
Posted: 21 Oct 2009, 11:50
by borislavgajic
MWichni wrote:Hi Boris, you have forgotten about inductor on the layout. BTW Tubes are powered with high voltage instead of the lfo section which is +5V I believe?
Regards,
Mariusz.
no I did not forget it,just wanted to show schem as soon as possible........AUDIO part is what was primary for me.......better layout....soon ...with tracks.......
you are right......when you have 12v DC ..it is not hard to get 5V regulated......
....What I would like to know how he gets 300V
so elegantly
this is first time for me to trace twosidedboard so be patient please
boris
Re: Tube-Vibe
Posted: 21 Oct 2009, 12:42
by MWichni
borislavgajic wrote:MWichni wrote:Hi Boris, you have forgotten about inductor on the layout. BTW Tubes are powered with high voltage instead of the lfo section which is +5V I believe?
Regards,
Mariusz.
so elegantly
boris
Well I think that he gets 300V using DC/DC converter 12/300V for example. This inductor is the part of that converter, because there is no need to get big current for the anodes of the tubes so the inductor is quite small. Hope you get my point.
Regards,
Mariusz.
Re: Tube-Vibe
Posted: 21 Oct 2009, 12:54
by borislavgajic
Regards,
Mariusz.
Mariusz I get your point
,....and what I really hope to get is a drawing from you ....schematic as close as possible to Vibes power section....it is not much to ask?
boris
Re: Tube-Vibe
Posted: 21 Oct 2009, 17:45
by MWichni
I'll try to draw the schematic for this one.
Re: Tube-Vibe
Posted: 21 Oct 2009, 18:31
by borislavgajic
MWichni wrote:I'll try to draw the schematic for this one.
great!!!!
Re: Tube-Vibe
Posted: 22 Oct 2009, 09:04
by borislavgajic
this is all I've done........
Greg...can you please
check PCB traces that are not visible on photos......did I get them right
next is .....
1.......resistor
values,cap(near volumepot)......
Greg_G
2.......
Power section schematic.....................
MWichni
3.......
PIC programming................................
somebody craisy
that is all for now
boris
Re: Tube-Vibe
Posted: 22 Oct 2009, 18:31
by JiM
Re: Tube-Vibe
Posted: 22 Oct 2009, 18:40
by chicago_mike
Boris, you are a sick, sick man!
Re: Tube-Vibe
Posted: 22 Oct 2009, 18:44
by himister
chicago_mike wrote:Boris, you are a sick, sick man!
Exactly. I totally agree. Sick man. If you finish this one it will be kick ass for sure.
Usually I wouldn't bother with SMD but.... Go for it.
Re: Tube-Vibe
Posted: 23 Oct 2009, 09:12
by borislavgajic
thanks......we all can do everything.....with little help from eachother
I want to trace all those pedals...
http://www.effectrode.com/website/effec ... pedals.htm
...so...
....please if somebody have theese pedals,post some gut pictures
Tube-Vibe.................this one is in progress
Tube Drive
Delta-Trem
Phaseomatic Deluxe............would like to see this one very much
Vibra Chorus
thanks
hard part......for me is that PIC - LFO.....but somebody here is an expert for PIC-ing,and can do that in 45 minutes....problem are traces below parts,and you have to use imagination(if you don't have knowledge)
...so please feel free to contribute......LFO and POWER part is missing
...tube heaters are connected pin4...GND pin 5....12.6V
boris
Re: Tube-Vibe
Posted: 23 Oct 2009, 10:37
by MWichni
Hi guys, I see that the DC/DC converter is made using a microcontroller too. It's based on PIC12F675 if I read that correctly from the Greg's picture. Here is a part of the schematic which I can see without any problems. But there are traces under IC's and other parts that I can't see but I try to figure out as much as I can.
If Greg could make better pics of the lfo and power section it would be great.
Regards,
Mariusz.
Re: Tube-Vibe
Posted: 23 Oct 2009, 10:41
by Greg
R1 = 82K
R2 = 22K
R3 = 1.8K
R4 = 1M
R5 = 22k
R6 = 1M
R7 = 1.5K
R8 = 22K
R9 = 22K
R10 = 10K
R11 = 10K
R12 = 390R ?
R13 = 22K
R16 = 1K
R18 = 10K
R19 = 10K
R20 = 1.5K
R21 = 1M
R22 = 22K
R23 = 22K
R24 = 22K
R25 = 22K
R26 = 22K
R27 = 22K
R28 = 22K
R29 = 22K
R30 = 22K
R31 = 22K
R32 = 22K
R33 = 22K
R34 = 100R
R35 = 100R
R36 = 100R
R37 = 10K
R38 = 10K
R39 = 10K
D2 = 15DN
D3 = B2G 03C 270
TR3 = 6CW
TR4 = 6CW
Re: Tube-Vibe
Posted: 23 Oct 2009, 12:29
by borislavgajic
great!!!! thanks Greg............please...I could not read
value of output condenser......one conected to volume pot......?
Regards,
Mariusz.
this is almost done
boris
Re: Tube-Vibe
Posted: 26 Oct 2009, 15:56
by borislavgajic
R1 and R19 on anode (pin1) tube1......looks little strange to me.......I would say that signal should go from pin1 through C to the rest of the circuit.........
what is the reason of this topology? (smaller signall for blending?).... did I make correct schem?
are those resistors 1W?
boris
p.s.
any progres with power section?.......sharper pictures of that part?
Re: Tube-Vibe
Posted: 28 Oct 2009, 01:56
by toneman
Has it been determined if this is, 4 sure,
just a 2-layer pcb?
or is it a 4-layer?? (with "poured gnds" on the top and bottom.)
Yes, traces
under the ICs are difficult to figure out if U can't lift the IC.
If the HVPS uses part of a PIC, that's gonna be a sticky also
Determine if there is (analog)feedback to the PIC for the switcher.
If not, it's just free-running and can substitute a 555 for the pulsing.
a 12V to 200V DC-2-DC PIC converter would be trick
but, 555 boost converters aren't that hard to build
As Boris said, go for the signal path first
U can build power supplies several ways....the tubes won't mind
Great work so far
afn
T
