J Rockett - The Dude (gut Shots)
Postby rafikian » 04 Nov 2016, 15:43
My friend has juste lent me his Fantabulous J Rockett The Dude, this peadl is AWESOME !!
Did take some pictures :)
this is a double sided PCB with 3 x 4558 smd IC
Pots are
Lvl = B50K
Ratio= A250K
Treble=B10K
Deep=C25K
I ll put the values of the Rs and Cs when possible.
Rafik.
For this message the author rafikian has received thanks: 5
Intripped (25 Dec 2016, 01:43), jt (08 Nov 2016, 09:04), snofla1900 (06 Nov 2016, 19:43), ThiagoFaraday (24 Dec 2016, 22:37), zzztop (07 Feb 2017, 09:23)
rafikian
Have thanks: 8 times
Re: J Rockett - The Dude (gut Shots)
Postby MGaburriJazzDude » 23 Dec 2016, 16:16
It's just me, or there are too many OP Amps in there?
MGaburriJazzDude
Postby induction » 23 Dec 2016, 16:55
Too many for what?
induction
Has thanked: 63 times
Have thanks: 132 times
Postby alexradium » 23 Dec 2016, 17:01
induction wrote:Too many for what?
for a chicken brain...
alexradium
Has thanked: 53 times
Have thanks: 60 times
Postby MoonWatcher » 23 Dec 2016, 21:27
MGaburriJazzDude wrote:It's just me, or there are too many OP Amps in there?
If it's mostly copied from an existing design, then 3 op amps would be 'just right.' :P
MoonWatcher
Has thanked: 43 times
Have thanks: 63 times
Postby MGaburriJazzDude » 24 Dec 2016, 00:39
I mean, aren't 6 op amps a lot for a traditional overdrive?
Are we in front of a totally new overdrive topology?
But, thinking about it a bit, it could be that they've used multiple gain stagesin series or something like that. I don't know, i will be amazed if someone told that finaly a boutique manufacture came up with a completely new overdrive design... It would be amazing, wouldn't it?
(Excuse my rough english...)
MGaburriJazzDude
Postby alexradium » 24 Dec 2016, 13:39
MGaburriJazzDude wrote:I mean, aren't 6 op amps a lot for a traditional overdrive?
opamp or transistors are used for many different tasks,buffering,clipping,mixing,recovery,high,low or bandpass filters,differential,servo dc....
it could be one for input and output buffers,one for clipping,one for tone,one for a gyrator,who knows...anyway there are several pedals that use a lot of opamps,Blakstar and Tech21 most notably.
For this message the author alexradium has received thanks:
MGaburriJazzDude (24 Dec 2016, 15:17)
alexradium
Postby MGaburriJazzDude » 24 Dec 2016, 15:21
You're right, i didn't think about it that way... :slap:
By the way, is there any clue of whats going on in that lil' black box?
MGaburriJazzDude
Postby Saruman » 27 Dec 2016, 08:44
schematic?
Saruman
Have thanks: 124 times
Postby 1oldsidewinder » 31 Dec 2016, 21:50
Not all the op-amp stages may be in use. IIRC, the Blue Note only used half of a 4558. Another possibility might be a charge pump. Also the Dude's "ratio" control is supposed to be a clean blend. I guess a dual gang pot might be a clue. Just a guess but Rockett has had a lot of success with their Klones.
1oldsidewinder
Has thanked: 19 times
Have thanks: 5 times
Postby matt239 » 20 Jan 2018, 07:15
Any idea how the thing works?
matt239
Has thanked: 62 times
Users browsing this forum: box, Chuck D. Bones, d312a, EmmG and 7 guests
