Bypass switch/selector
Postby POTL » 23 Dec 2016, 06:56
Hello
Share opinions how to make the switch from true bypass to buffer
Like Mi Audio Boost n Buff or Wampler Decibel+
POTL
Has thanked: 53 times
Have thanks: 50 times
Re: Bypass switch/selector
Postby POTL » 27 Dec 2016, 08:30
JUMP!
POTL
Postby plush » 27 Dec 2016, 10:18
POTL wrote:Hello
The easiest way is to simply bypass the buffer with a dip switch or panel mount toggle
Couple of spdt or one dpdt should do the job
You can also turn on and off buffer's dc supply with another spdt to save your battery when you are in true bypass mode
For this message the author plush has received thanks:
POTL (27 Dec 2016, 10:38)
plush
Has thanked: 20 times
Have thanks: 19 times
Postby POTL » 27 Dec 2016, 10:39
bro can you make a cirquit or link to a cirquit?
POTL
Postby plush » 28 Dec 2016, 11:01
POTL wrote:bro can you make a cirquit or link to a cirquit?
Yeah, i guess
link: http://i.imgur.com/3gX1JYJ.jpg
POTL (28 Dec 2016, 21:46)
plush
Postby POTL » 28 Dec 2016, 21:47
Yeah, i guess
do you think this will work?
I then drew something similar but was not exactly sure
https://pp.vk.me/c636220/v636220754/2f3 ... KZU1fo.jpg
This is my version of the MXR Micro Amp and JHS Black Buffer :D
POTL
Postby plush » 29 Dec 2016, 10:34
There is no way it shouldn't.
Also you'd better adjust your buffer's output volume to match the bypassed signal if you haven't done it yet.
POTL (29 Dec 2016, 22:40)
plush
Postby phatt » 29 Dec 2016, 14:15
For this message the author phatt has received thanks:
phatt
Have thanks: 234 times
Postby POTL » 29 Dec 2016, 22:38
strange it seemed to me then that I have drawn corresponds to the fact that you sent the link to me
regarding the volume knob - it was designed by MXR as I wrote above :roll:
on my circuit bypass DPDT switch goes on and there are 2 position
first bypass
second buffer
pins 1 and 4 on the bypass
5 and 2 are connected by track
6 and 3 on the buffer
that is, the buffer may be included along with a booster and separately
POTL
Postby POTL » 04 Jan 2017, 16:52
BUMP
POTL
Postby POTL » 05 Jan 2017, 19:03
S2 rotated 180 degrees
who thinks that?
POTL
Postby POTL » 16 Jan 2017, 00:51
Hello
I redid the circuit, I want to ask whether all is correct
Switch 1 is a 3PDT stompbox
Switch 2 is a DPDT bypass true or buffer
POTL
Postby phatt » 16 Jan 2017, 12:19
This might help clarify the switch wire up you need. I've left out the Led as I'm sure that is ok :thumbsup
Phil.
POTL (16 Jan 2017, 12:22)
phatt
Postby POTL » 16 Jan 2017, 12:24
phatt wrote:This might help clarify the switch wire up you need. I've left out the Led as I'm sure that is ok :thumbsup
Phil.
Yeah cool
I was very close
Thanks bro
:hug:
POTL
Users browsing this forum: ferryarliansyah, frooshontay and 11 guests
