HBE - Germania (gutshots)
Postby ThiagoFaraday » 24 Dec 2016, 22:27
Hi everyone, Im trying these days trace this really good rangemaster clone. will post more later.
[img]file:///C:/Users/Thiago/Downloads/P_20161224_180902_LL.webp[/img]
[img]file:///C:/Users/Thiago/Downloads/P_20161224_180513_LL%20(1).webp[/img]
ThiagoFaraday
Has thanked: 54 times
Have thanks: 23 times
Re: HBE - Germania (gutshots)
Postby ThiagoFaraday » 25 Dec 2016, 22:29
D1 - n4001
D2 - n4001
Q1 - 2N4401
Q2 - AC128
C1 - 47NF
C2 - 47nf
C3 - 2,7NF
C4 - 47uf
C5 - 47uF
C6 - 22uf
C7 - 10PF
C8 - 10NF
C9 - 2,7nf
C10 - 6,8NF
Resistors need to check again.
For this message the author ThiagoFaraday has received thanks:
modman (26 Dec 2016, 18:41)
ThiagoFaraday
Postby fuzzbunny » 25 Dec 2016, 22:44
I am not seeing the images you are trying to post. Anyone else having the same experience?
For this message the author fuzzbunny has received thanks:
ThiagoFaraday (26 Dec 2016, 07:26)
fuzzbunny
Have thanks: 10 times
Postby ThiagoFaraday » 25 Dec 2016, 23:38
:scratch: Omg, I test with logout and worked here, I use the link of my google+ page. but this is my first post. maybe Im doing something wrong. I can see. but if no one cann see it I need to fix. :scratch:
ThiagoFaraday
Postby Intripped » 26 Dec 2016, 02:28
Even I can't see them
For this message the author Intripped has received thanks:
Intripped
Has thanked: 568 times
Have thanks: 212 times
Postby ThiagoFaraday » 26 Dec 2016, 02:47
ThiagoFaraday
Postby ThiagoFaraday » 26 Dec 2016, 02:58
Now I think, doing right. :slap: please if still cant see at all, tell me
For this message the author ThiagoFaraday has received thanks: 3
Intripped (26 Dec 2016, 04:06), Manfred (26 Dec 2016, 09:30), modman (26 Dec 2016, 18:41)
ThiagoFaraday
Postby ThiagoFaraday » 26 Dec 2016, 03:12
ThiagoFaraday
Postby Intripped » 26 Dec 2016, 04:06
It's ok now
For this message the author Intripped has received thanks: 2
modman (26 Dec 2016, 18:41), ThiagoFaraday (26 Dec 2016, 07:25)
Intripped
Postby alexradium » 26 Dec 2016, 09:02
it looks like a chinese made board,so dirty,and what about the magic blacked capacitors....
alexradium
Has thanked: 51 times
Have thanks: 53 times
Postby ThiagoFaraday » 26 Dec 2016, 19:26
alexradium wrote:it looks like a chinese made board,so dirty,and what about the magic blacked capacitors....
no, thats made in USA. thanks for reply
ThiagoFaraday
Postby Manfred » 27 Dec 2016, 11:09
Hi ThiagoFaraday,
thanks for sharing the gutshots.
I traced the PCB imgages to create a PCB etching template.
I could not trace all conductors, because some are hidden behind the parts.
Please could you check the conductors and insert the missing ones on my drawing.
Next, I would like trace the connections and draw the schematic.
The bright conductors are on the componet side.
For this message the author Manfred has received thanks: 2
Intripped (27 Dec 2016, 12:18), ThiagoFaraday (27 Dec 2016, 18:43)
Manfred
Has thanked: 914 times
Have thanks: 455 times
Postby ThiagoFaraday » 27 Dec 2016, 18:46
Hi Manfred, wow you did an awesome work on that pcb! thanks alot! :applause:
and sure, I will open and check again, Im having issues to the values on the resistors. the colors are confuse to me and some I cant mesure.
But I think its a metter of time to figure out.
ThiagoFaraday
Postby ThiagoFaraday » 27 Dec 2016, 20:23
Hey Manfred, here I just erased one bright, and make the missing traces with fine lines on the same color as you did, but my traits turned out really ugly. :oops:
sorry for that.
For this message the author ThiagoFaraday has received thanks: 2
Intripped (28 Dec 2016, 00:43), Manfred (27 Dec 2016, 23:27)
ThiagoFaraday
Postby roberttomasz » 27 Dec 2016, 21:41
corets- R5 ... Emiter -2N4401
For this message the author roberttomasz has received thanks:
ThiagoFaraday (27 Dec 2016, 21:59)
roberttomasz
Have thanks: 17 times
Postby ThiagoFaraday » 27 Dec 2016, 21:56
roberttomasz, I only see here R5 connected to R4 and to collector 2N4401. C2 its connected to emitter :hmmm: . I will correct that. thank you roberttomasz!
ThiagoFaraday
Postby Manfred » 27 Dec 2016, 23:27
Hi ThiagoFaraday,
thank you very much for your great support.
I inserted the missing conductors according your drawing, please re-check it.
One land is not connected. I marked this aerea by an circle.
ThiagoFaraday (28 Dec 2016, 00:29)
Manfred
Postby ThiagoFaraday » 28 Dec 2016, 00:33
Hey Manfred I appreciate your work!
and I'm here to help. Any questions just ask. I'm going try to measure the resistors in a few hours and will post what I got.
the missing conductor was to R5 next to that. I miss that, was very close. sorry about that.
Manfred (28 Dec 2016, 08:26)
ThiagoFaraday
Postby Manfred » 28 Dec 2016, 01:12
ThiagoFaraday wrote:Hey Manfred I appreciate your work!
Don't be in such a hurry, there is time.
It's after midnight on our location, so I go to bed now.
ThiagoFaraday (28 Dec 2016, 02:25)
Manfred
Postby NegationOfNegation » 28 Dec 2016, 01:34
tried to recognize schematic -- seems to be a treble booster
with input buffer and some switching possibility between buffer
and treble booster (treble booster input capacitors, low pass
before treble booster).
2N4401 (npn as an emitter follower) does not really make sense
in this circuit, are you shure?
Gutshots are not really good, some parts of circuit board
are hidden by wires -- see e.g. R2 on schematic trial.
Additionally, wiring (and labeling) of switches must be detected
by hand, not via photograph.
Greetings from germany -- Good night and good luck
NoN
For this message the author NegationOfNegation has received thanks: 3
Manfred (28 Dec 2016, 08:24), mirosol (28 Dec 2016, 07:38), ThiagoFaraday (28 Dec 2016, 02:02)
NegationOfNegation
Have thanks: 19 times
Next
Users browsing this forum: dan.schumaker, lovetone and 25 guests
