HBE - Germania (gutshots)
Re: HBE - Germania (gutshots)
Postby ThiagoFaraday » 28 Dec 2016, 02:20
Hey NegationOfNegation! you'r right its not 2N4401 its a 2N4403. and R2 its connected to the base of Q1 and other leg C1.
thank you. and sorry about the quality of the photos and hidden with wire. its because the owner of this pedal dont want to desoldering things. but if you want to see something better just tell me. I try to have better angle photo.
R12 - 3k3
R13 - 10R
ThiagoFaraday
Has thanked: 54 times
Have thanks: 22 times
Postby roberttomasz » 28 Dec 2016, 07:47
- GND= ( +9VDC)
For this message the author roberttomasz has received thanks:
Manfred (28 Dec 2016, 08:28)
roberttomasz
Have thanks: 17 times
Postby ThiagoFaraday » 28 Dec 2016, 08:57
For this message the author ThiagoFaraday has received thanks:
Manfred (28 Dec 2016, 13:46)
ThiagoFaraday
Postby roberttomasz » 28 Dec 2016, 11:32
HBE Germania 44 -- transistor OC44
- switch HI-LO - 6 pin
- " 3Q - 3 pin
roberttomasz
Postby Manfred » 28 Dec 2016, 13:55
Here the preliminary Layout, that contains assingments and values.
I am not sure about the resistor values, because it is difficult to identify the code colors on it.
Hi ThiagoFaraday,
you wrote: "Im having issues to the values on the resistors. the colors are confuse to me and some I cant mesure".
You can use that online application to identify the resistor values.
http://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-5-band
For this message the author Manfred has received thanks:
ThiagoFaraday (28 Dec 2016, 18:36)
Manfred
Has thanked: 785 times
Have thanks: 363 times
Postby roberttomasz » 28 Dec 2016, 14:13
Transistor 2N4403
minus 9VDC
GND plus 9VDC
roberttomasz
Postby Manfred » 28 Dec 2016, 14:42
I started tracing for find the schematic and found that I was totally wrong with some resistor values, therefore I checked again.
Please re-check the values too.
Manfred
Postby NegationOfNegation » 28 Dec 2016, 17:05
[quote="Manfred"]I started tracing for find the schematic and found that I was totally wrong with some resistor values, therefore I checked again.
Hi Manfred,
R11 is 1Meg i.m.h.o, it it the pulldown after output capacitor
(original RM doesn't have a footswitch and no pulldown too).
R7 is 1Meg too, i.m.h.o it it the pulldown for capacitor C3.
I guess, the (re)attached shows the values of R7 and R11.
Q1 is an 2N4403 -- an pnp.
Hi ThiagoFaraday,
I'm afraid, but I guess, somebody with physical access to the
device should disentangle all the blue wires between HF/LF/3Q etc.
and the switches.
HiFi/LowFi-Switch (B) seems to be a bypass for the buffer and Q switch (A)
seems to change input capacitor, but on photograph it is not shure enough
imho.
Greets
Torsten
For this message the author NegationOfNegation has received thanks: 2
Manfred (28 Dec 2016, 22:48), ThiagoFaraday (28 Dec 2016, 18:36)
NegationOfNegation
Have thanks: 18 times
Postby ThiagoFaraday » 28 Dec 2016, 18:36
Hello Manfred , NegationOfNegation.
I think its pretty much it, only corrections NegattionOfNegation already did, R7- 1M, R11-1M, Q1 - 2N4403 (PNP). the circuit its positive ground. like old rangemaster.
and Yes. the Hi-Fi / Lo-Fi switch turn the circuit with the buffer/boost or pass to the simple circuit that starts on the middle of all.
but I see some correction to make on this schematic. first I think R3 go from C6 direct to the base of Q1.
ThiagoFaraday
Postby roberttomasz » 28 Dec 2016, 20:17
Switch 3Q - 3 position
ThiagoFaraday (28 Dec 2016, 20:35)
roberttomasz
Postby ThiagoFaraday » 28 Dec 2016, 20:36
A2 to B2.3
B1.3 to input on 3PDT (same as input jack)
ThiagoFaraday
Postby NegationOfNegation » 28 Dec 2016, 22:41
Hi ThiagoFaraday
ThiagoFaraday wrote:Hello Manfred , NegationOfNegation.
I think, now I got it ;-)
ThiagoFaraday wrote:A2 to B2.3
So, maybe, A1 and A3 are 3Q and 3Q1?
Greets
Torsten
Manfred (28 Dec 2016, 23:04), ThiagoFaraday (28 Dec 2016, 23:30)
NegationOfNegation
Postby Manfred » 28 Dec 2016, 22:52
Hi Manfred,
Thanks for re-checking
Manfred
Postby ThiagoFaraday » 28 Dec 2016, 23:27
yes!
A1 to 3Q
A2 to B2.3
A3 to 3Q1
B1.1 to HF1
B1.2 to HF
B1.3 to input Jack sleeve
B2.1 to input circuit
B2.2 to 3PDT input circuit
B2.3 to LF
I will marked on the photo what I consider B1.2, B2.1 etc...
Manfred (29 Dec 2016, 03:53)
ThiagoFaraday
Postby Manfred » 29 Dec 2016, 16:02
I don,t understand, please give me further explanations,
lifte draft would be helpfull.
Manfred
Postby Manfred » 29 Dec 2016, 16:50
I understand better now, because I found this shot.
ThiagoFaraday (29 Dec 2016, 19:23)
Manfred
Postby ThiagoFaraday » 29 Dec 2016, 19:25
sorry! :oops:
B2.2 to 3DPT (that go to input circuits also) I mean.
ThiagoFaraday
Postby roberttomasz » 29 Dec 2016, 20:07
B1.3 to GND
roberttomasz
Postby NegationOfNegation » 29 Dec 2016, 22:38
Hi all,
attached schem, sorry that PSPICE didn't have switches, so
you must imaginize the leg of every switch.
Circuit make sense, it is either a rangemaster with different
input capacitors (9,5nF 2,7nF 5,4nF) -- this is LowFi mode --
or a buffered booster (full range or with a litle low cut; HiFi).
That means, in HiFi mode 3Q switch doesn't change anything
(so both switches could be realized with on 3 layer 4 position
rotary switch)
One thing seems greek to me, i.m.h.o it would be better, when
LED current doesn't flow via R13, switching LED could cause a
litle pop.
@ThiagoFaraday
Does the other switches cause noises?
Greets and a happy new year
Torsten
Manfred (30 Dec 2016, 00:04), ThiagoFaraday (30 Dec 2016, 01:12)
NegationOfNegation
Postby ThiagoFaraday » 30 Dec 2016, 01:26
Hey all!
NegationOfNegation, I just tested and could not hear any unusual noise when I used the switches or turned on the pedal. may have some that I could not identify with my ears, but if I have it, it is not significant at all.
And I think the pedal its it, you'r right with the HiFi mode on, the 3Q doesnt nothing to the sound. 3Q only for the normal rangemaster mode, LoFi.
For those who want a great sound of rangemaster but think it doesnt fuzz enough its a good choice, with the HiFi mode.
and the 3Q Supplies well the necessity when you change guitars, pickups, amps...
Thank you everyone and Happy New Year! :lol:
ThiagoFaraday
Users browsing this forum: Boba7, boby6kiler, Cub, d312a, efe, GD1, kymar and 12 guests
