HBE - Germania (gutshots)
Re: HBE - Germania (gutshots)
Postby Manfred » 30 Dec 2016, 08:57
The final layout:
For this message the author Manfred has received thanks:
ThiagoFaraday (30 Dec 2016, 22:18)
Manfred
Has thanked: 914 times
Have thanks: 455 times
Postby Manfred » 30 Dec 2016, 23:33
I redraw the schematic,with the request to check this.
ThiagoFaraday (31 Dec 2016, 00:28)
Manfred
Postby roberttomasz » 31 Dec 2016, 11:36
Error=schematics(switch). IN-effects-GND-LED
For this message the author roberttomasz has received thanks:
Manfred (02 Jan 2017, 13:26)
roberttomasz
Have thanks: 17 times
Postby Manfred » 01 Jan 2017, 21:48
roberttomasz wrote:Error=schematics(switch). IN-effects-GND-LED
Please give me more details or make a sketch, i cannot see it. :hmmm:
The R11 ground connection dot was missing.
C5 have got the wrong polarity.
The output jack was the wrong type.
Manfred
Postby sebjus » 02 Jan 2017, 12:24
Hi 4 all.
This is finally corrected schema, last and 100% working. Special thanx for tomaszgab -> roberttomasz. This is a his work.
For this message the author sebjus has received thanks:
sebjus
Have thanks: 2 times
Postby Manfred » 02 Jan 2017, 13:31
Sorry, I was blind, but now I saw what you meant.
Manfred
Postby roberttomasz » 02 Jan 2017, 14:06
OK... HBE Germania - transistor AC128
Germania 44 - transistor OC44
roberttomasz
Postby Manfred » 03 Jan 2017, 09:32
roberttomasz wrote:OK... HBE Germania - transistor AC128
Does the circuit remain the same when the OC44 is applied?
Manfred
Postby ThiagoFaraday » 03 Jan 2017, 13:51
Probably the only difference is the OC44 PNP Mullard transistor. Because they have same controls, only an older version are without the 3Q but still with the HiFi-LoFi.
ThiagoFaraday
Has thanked: 54 times
Have thanks: 23 times
Postby sebjus » 03 Jan 2017, 18:56
It is the same, look:
This is corrected your schema:
Specjal thanx for roberttomasz, everything is his work. Im only install here a .jpg :)
Manfred (03 Jan 2017, 23:42)
sebjus
Previous
Users browsing this forum: ampjunkie, ipelles, now:here, The Apostle and 22 guests
