Darkglass Electronics - Microtubes B3K  [traced]
Re: Anyone with a Darkglass B3K willing to open her up for u
Postby Silver Blues » 22 Jan 2015, 16:54
Still might be cool. One can never have too many good overdrives :mrgreen: It's odd though, the files are labelled "B2K" but everywhere else says "B3K" and I can't find any information at all about the B2K...
Silver Blues
Have thanks: 21 times
Postby lars-musik » 01 Feb 2017, 16:12
has anybody out there a schematic for the Darkglass B3K? That would be greatly appreciated! Thanks!
lars-musik
Has thanked: 29 times
Have thanks: 25 times
Re: Darkglass B3K
Postby Cub » 01 Feb 2017, 18:03
No schematic, but I assume your goal is to build a clone ? Then you can save yourself a lot of time and order a kit with the PCB and parts of the GUMA-Drive from http://schalltechnik04.de/. Knobs and an enclosure are optional, either drilled and bare or completely drilled, painted and labelled. 8)
Cub
Has thanked: 75 times
Have thanks: 88 times
Re: Darkglass B3K
Postby lars-musik » 02 Feb 2017, 16:06
Hi Cub,
yes, thanks. I knew that kit. But indeed I'd need a schematic to do my own. Preferably in a 1590a and without the relay bypass.
I found the Vintage model and guess I am just as happy with this one.
Cheers!
lars-musik
Re: Darkglass B3K
Postby Silver Blues » 02 Feb 2017, 23:22
Going by what I had to go through with the VMT, this is going to be literally impossible to fit in a 1590A. I have photos of the GUMA boards but I'm not sure a good trace could be done with them, as much as I'd love to know.
Silver Blues
Re: Darkglass B3K
Postby Cub » 03 Feb 2017, 11:43
With a couple of layers of boards with SMD components, it should theoretically be possible. Practically, that's a different story. :lol:
Besides, a 1590A with side-mounted jacks isn't much less wide than a 1590B end-mounted jacks.
Cub
Re: Darkglass B3K  [traced]
Postby miguelmoita » 26 Apr 2017, 04:38
Here is the schematic of the B3k. Very similar to the VMT that is already available on the forum. I did not test it yet, but I test the VMT and sounds awesome. So, I am confident for this one too.
I will make a tone transfer, test it and the post it here in a couple weeks.
For this message the author miguelmoita has received thanks: 13
Crackerman86 (25 Jul 2017, 20:12), deltafred (27 Apr 2017, 20:20), Intripped (26 Apr 2017, 08:16), Manfred (26 Apr 2017, 08:47), modman (27 Mar 2018, 11:15), olyaneko (31 May 2017, 16:32), Silver Blues (26 Apr 2017, 19:34), Smegma (02 May 2017, 14:30), tp801 (26 Apr 2017, 18:10), Zokk (26 Apr 2017, 21:18) and 3 more users
miguelmoita
Have thanks: 36 times
Re: Darkglass B3K
Postby nezvers » 31 May 2017, 12:18
Sorry for my lack of knowledge but I don't see the source for VD and VDD which I assume are VR / (1/2Vcc).
nezvers
Re: Darkglass B3K
Postby olyaneko » 31 May 2017, 17:41
probably that's how it will be :roll:
For this message the author olyaneko has received thanks:
olyaneko
Have thanks: 5 times
Re: Darkglass B3K
Postby miguelmoita » 02 Jun 2017, 05:36
Yes, you are right. I forgot!
That's the right place to put the VDD.
I just finished mine.
Sounds awesome!! I did not had the opportunity to compare with the original yet. But I am very satisfied with the sound of it. Its brutal like a true Darkglass.
I attached some photos. Just needs the decals now.
i just saw some errors and missing values in the schematic.
I used different JFETs than the J201 that I put in the schematic. I used the MMBFJ201. They are SMD, but I order from Musikding some little adapters that coverts to through hole footprint to make the tone transfer process easier.
I did not tried the J201 so I do not know if it sounds different or not.
I forgot the values for the Pots. Level: A100k; Blend: B100k. Drive: C100k
D1 and D2 I used 1N4148.
And I think that is all.
For this message the author miguelmoita has received thanks: 2
jmwreck (03 Aug 2017, 07:25), olyaneko (03 Jun 2017, 06:32)
miguelmoita
Re: Darkglass B3K
Postby olyaneko » 03 Jun 2017, 06:32
please, and can you give a PCB file for this circuit ?, ... mmm you can just take a picture-photo, I'll rewrite it later (for example in Sprint Layout, i can draw a little in this program), please :oops: ...
olyaneko
Re: Darkglass B3K
Postby Silver Blues » 03 Jun 2017, 19:17
The MMBFJ201 are just J201, but in an SMD format. A great many people are using them as substitutes for the TO-92 J201s because they are far more consistent and easier to find.
For this message the author Silver Blues has received thanks:
olyaneko (04 Jun 2017, 08:03)
Silver Blues
Re: Darkglass B3K
Postby miguelmoita » 03 Jun 2017, 21:06
ok Silver Blues. That's what I thought.
Actually I had some troubles with the inconcesty of the J201 in the past. That is why I did not think twice to use the MMBFJ201.
Olyaneko just give me a few days to organize the file. The drawing is a bit confusing because I used two PCBs (one on top of the other) to fit it on a 125B using PCB mount Pots. I think it will arise some doubts the way it is.
miguelmoita
Re: Darkglass B3K
Postby fersynes » 08 Jun 2017, 05:46
Could you please post the PCB and layout?
fersynes
Have thanks: 4 times
Re: Darkglass B3K
Postby olyaneko » 08 Jun 2017, 11:12
mmm, is that you to me ? :roll:, i still do not have them :oops: ...
olyaneko
Re: Darkglass B3K
Postby miguelmoita » 09 Jun 2017, 21:06
Hello all,
Here it is! :D
Sorry about the delay. I had a lot of work this week.
Just a few hints. The VDD connects to the lug 3 of the level pot and lug 2 and 1 of the Drive pot. G2 is just another ground terminal, ignore it if you want.
If you have any questions just let me know.
I had the opportunity to experiment with different basses and amps during this week and I notice some inconsistency with passive and active basses. Passive sounds a lot better. I also mount the VMT and is way more consistent on this. Sooo, now I am not sure that everything is ok. I am thinking to make a new one to figure it out, but it will take a while. So, it will be very nice that you try it and let me know your opinions.
Miguel
For this message the author miguelmoita has received thanks: 3
fersynes (10 Jun 2017, 08:05), olyaneko (10 Jun 2017, 07:26), vadgrek (10 Jun 2017, 15:30)
miguelmoita
Re: Darkglass B3K
Postby olyaneko » 10 Jun 2017, 07:25
nyaaaa, a tremendous thank you :oops: ,...mmm, and the red bar in the drawing is a jumper ?, right ? :oops: :oops: ...
...mmm, and I'm on the drawing where to connect the toggle switch "Attack" is not found :oops: :oops: ,...oops, i'm sorry, it turns out "Boost" was named, it's me inattentive :oops: :oops: :oops: ...
olyaneko
Re: Darkglass B3K
Postby fersynes » 10 Jun 2017, 08:06
Thank you so much! I Will try it and tell what happen with my active bass
fersynes
Re: Darkglass B3K
Postby miguelmoita » 10 Jun 2017, 15:59
You're welcome guys! :)
Yes olyaneko, the red bar is a jumper and Boost switch is the Attack.
One more thing that I forgot to warn. Lug 2 of Level pot connects to lug 3 of Blend pot as you can see in the schematic.
Go for it fersynes. :) I'll be waiting your feedback.
fersynes (10 Jun 2017, 19:21), olyaneko (10 Jun 2017, 17:49)
miguelmoita
Re: Darkglass B3K
Postby fersynes » 29 Jun 2017, 06:55
Wells I built ir and the controls are working but there is a constant sound thicking (mybe a shortcut) like "tuktuktuktuktuk" that caries with the drive pot and Boost Switch. Still can't figure out what's the problem but Will try to debug it later or built a new one. I cheked all the wire conections mentioned and are right. Will tell if i make it. Sorry for my English. Cheers
fersynes
Users browsing this forum: swyse and 10 guests
