Darkglass Electronics - Microtubes B3K  [traced]
Re: Darkglass B3K
Postby POTL » 20 Jun 2018, 06:06
izikg wrote:
jmwreck wrote: I am having a problem with the Drive (B3k) because I got a cutting out sound, it seems that the distortion sound will get disconnected and all that's left is the clean sound,
Hi
I also get this cutting out when at high gain , I found that high frequencies noise is amplified and causing this problem on the drive opamp.
I suspect it has something to do with the filter before that opamp , but I just can not understand it.
does any one know this filter design or can explain that
I also noticed that the BDDI has a similar filter
Thanks,
Hi
The first figure - R8 C8 - controls high frequencies.
1) When the switch is in the center position, the high frequencies do not change.
2) When the capacitor is connected to ground, the high frequencies are cut off, this is the classic RC-filter
3) When the capacitor connects to the resistor, this parallel RC-filter, like the Marshall, in this mode, high frequencies rise.
The second picture is Bandstop filter - the filter does not let pass a certain frequency. In this case, this filter cuts low-mid freq, the frequency of 320 HZ is cut completely and the frequencies near it are also severely cut off.
POTL
Has thanked: 65 times
Have thanks: 60 times
Re: Darkglass Electronics - Microtubes B3K
Postby POTL » 20 Jun 2018, 06:22
Hello everybody
I watched the circuit today and read Douglas's reports on the forums, at first I thought this pedal was an original development, then I realized that Douglas collected it based on the MXR M80, Sansamp Bass Drive Di and CMOS amplifier as Red Llama.
So, if you want to copy B7K, then I advise you to look at the equalizer circuits from m80 and bass driver di.
Regarding the control of the middle frequencies, you can change the frequencies using the DPDT toggle switch (as in the original).
Below is the scheme, you just need to connect the toggle switch to C2 and C5
You need to copy the central part of the circuit 2 times and select the components for the desired frequencies, I hope this helps you to copy the circuit :D
POTL
Postby ray86 » 26 Jun 2018, 15:57
CD4049????
ray86
Postby POTL » 26 Jun 2018, 17:55
ray86 wrote:CD4049????
Yeah, it's here.
POTL
Re: Darkglass B3K
Postby zyu » 09 Aug 2018, 16:25
Harold wrote:Here's another schematic based on the GUMA: http://peperspedals.blogspot.nl/2017/02 ... cb-to.html and the update on that: http://peperspedals.blogspot.nl/2017/03 ... pdate.html
I also made a Vero out of it, but I still haven't checked it: http://diyl.sait.nl/guma-drive-darkglass-b3k
Hello!
One small mistake.
R5 should be installed before R4, and not AFTER it, as in your scheme.
zyu
Postby jhergonz » 10 Feb 2019, 21:03
will try to build b3k with "ERA" knob like the Vintage microtubes, i'll just put B100k pot in series with the 33k(R23) resistor ... hope this will work just fine.
jhergonz
Has thanked: 50 times
Previous
Users browsing this forum: Agent86, audioguy, Fat Bob and 11 guests
