Lovepedal HiVolt
have the schematic for the lovepedal high volt but needs to
Postby Belanger88 » 07 Mar 2017, 14:06
I've got the original schematic for the love pedal hi volt which is a mu-amp cascading JFET design only problem is this is the actual love pedal schematic from sean so it needs to be re-drawn I believe if I want to share and post it which I could use a hand with
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
For this message the author Belanger88 has received thanks:
Nocentelli (09 Mar 2017, 00:33)
Belanger88
Has thanked: 104 times
Have thanks: 31 times
Re: have the schematic for the lovepedal high volt but needs
Postby Nocentelli » 07 Mar 2017, 19:21
https://www.expresspcb.com
..has a free schematic drawing program which is intuitive and easy to use. Or you could email me the schematic and I'll redraw it. Pm me if you're interested in the easy option
Nocentelli
Has thanked: 842 times
Have thanks: 829 times
Postby Belanger88 » 08 Mar 2017, 00:11
sent you a PM
Belanger88
Lovepedal HiVolt
Postby Nocentelli » 09 Mar 2017, 00:32
viewtopic.php?f=7&t=28214
Thanks to Belanger88 -
For this message the author Nocentelli has received thanks: 6
anselm (10 Mar 2017, 23:39), Belanger88 (09 Mar 2017, 02:05), Intripped (09 Mar 2017, 01:13), Manfred (09 Mar 2017, 00:52), nickthemen (09 Mar 2017, 13:52), storyboardist (09 Mar 2017, 16:50)
Nocentelli
Re: Lovepedal HiVolt
Postby Nocentelli » 11 Mar 2017, 13:07
Slight revision (connected "hot" ends of treble + middle EQ pots to last opamp inverting input, EQ pot lug numbers labelled)
For this message the author Nocentelli has received thanks: 5
HENK (15 Mar 2017, 14:10), jalmonsalmon (19 Mar 2017, 18:36), modman (06 Apr 2017, 15:47), nickthemen (11 Mar 2017, 19:45), Zokk (11 Mar 2017, 17:36)
Nocentelli
Postby gigelmargel » 05 Apr 2017, 21:58
Hello!
I've just finished HiVolt, using the excellent layout from Effectslayout (https://effectslayouts.blogspot.ro/2017 ... 0814985595), but it didn't work. I found that the problem comes from the power supply part, which is wrong on the schematic.
So, you must disconnect 1N4001 diode from the pin 7 of MAX1044 and connect it to pin 8 (as I saw in many others schematic).
Now it works, but not as in videos. It hasn't a tight sound. It has a muffled sound. Maybe there are other errors in the schematic? I compared the FET part with BSIAB2 and some values are very different. The most strange part for me is the 33nF+10K+3.9K filter. What is for?
The tone pots has a weak action, especially for the mids.
Thank you!
For this message the author gigelmargel has received thanks: 2
modman (06 Apr 2017, 22:21), roseblood11 (02 Jun 2017, 11:23)
gigelmargel
Has thanked: 13 times
Have thanks: 14 times
Postby Nocentelli » 05 Apr 2017, 23:07
My bad on the voltage doubler - I should have spotted that.
The EQ is weird, but pretty sure it's accurate
Nocentelli
Postby gigelmargel » 06 Apr 2017, 13:10
Nocentelli wrote:My bad on the voltage doubler - I should have spotted that.
The 10K+3.9K seems strange because it is easier to put a very common 14K or 15K instead :)
I will make some sound tests before the filter. I biased the last FET at 8V (half of the power supply).
Anyway, maybe someone which has the pedal can recheck the values. For example, the 820K in HiVolt is only 82K in BSIAB. I don't have many electdonic knowledges...
gigelmargel
Postby johnk » 07 Apr 2017, 23:37
i've built it twice using the posted schematic (with a corrected charge pump) and it doesn't sound anything like the original. the distortion is very ugly sounding so i think that there are a few more errors with the re-draw besides the charge pump.
johnk
Has thanked: 31 times
Have thanks: 263 times
Postby johnk » 11 Apr 2017, 21:01
well, Jesse sent the schematic and i checked it. the only other difference besides the charge pump issue is that the 820K resistor at the gate of the 5th Jfet is an 882K one as per Sean's schematic. other than that it matches it.
i've tried both an 820K and an 82K but to no avail. this one matches the one that Jesse sent me.
For this message the author johnk has received thanks:
Nocentelli (03 May 2017, 19:45)
johnk
Postby gigelmargel » 12 Apr 2017, 15:49
johnk wrote:well, Jesse sent the schematic and i checked it. the only other difference besides the charge pump issue is that the 820K resistor at the gate of the 5th Jfet is an 882K one as per Sean's schematic. other than that it matches it.
After I made the link that you suggested about the pin 3 of the mid pot, mine works almost OK. The main problem is a huge noise (but, as I remeber, BSIAB is noisy by default). Moreover, the mids are a little strange, like a fixed wah :)
Thank you very much!
Nocentelli (03 May 2017, 19:47)
gigelmargel
Postby hozy31 » 28 Apr 2017, 15:16
Hi gigelmargel, what was the link you added to lug 3 of mids pot, i can't seem to find any mention of it?
hozy31
Have thanks: 9 times
Postby gigelmargel » 29 Apr 2017, 21:09
hozy31 wrote:Hi gigelmargel, what was the link you added to lug 3 of mids pot, i can't seem to find any mention of it?
I added link in the layout from here: http://effectslayouts.blogspot.ro/2017/03/lovepedal-hi-volt.html...in the comments you can read exactly where :)
Good luck!
hozy31 (30 Apr 2017, 13:54)
gigelmargel
Postby Nocentelli » 03 May 2017, 19:51
Nocentelli wrote:Post subject: Re: Lovepedal HiVolt Posted: 11 Mar 2017, 12:07
Belanger88 wrote:...only problem is this is the actual love pedal schematic from sean
Nocentelli
Postby roseblood11 » 02 Jun 2017, 11:24
So, there is still no verified schematic?
roseblood11
Has thanked: 332 times
Have thanks: 304 times
Users browsing this forum: BoxStomper, ferryarliansyah, gianniotis21 and 29 guests
cron
