Amptweaker - BigRock/TightMetal Pro  [traced]
Postby J0K3RX » 10 Mar 2017, 07:52
Here's a teaser :twisted: 2:00AM and I gotta get some sleep... :shock: Stay tuned for more!
For this message the author J0K3RX has received thanks: 10
Belanger88 (10 Mar 2017, 10:38), bmxguitarsbmx (12 Mar 2017, 20:02), brejna (10 Mar 2017, 19:05), EmmG (10 Mar 2017, 07:56), FausterCraster (10 Mar 2017, 09:25), marmaliser (10 Mar 2017, 09:36), modman (05 May 2019, 17:37), nexion777 (05 Jun 2017, 19:32), tcpoint (12 Mar 2017, 06:36), Zokk (10 Mar 2017, 15:33)
J0K3RX
Has thanked: 330 times
Have thanks: 516 times
Re: Amptweaker - BigRock/TightMetal Pro
Postby Belanger88 » 10 Mar 2017, 10:40
J0K3RX wrote:Here's a teaser :twisted: 2:00AM and I gotta get some sleep... :shock: Stay tuned for more!
is the boost section jfet or mosfet?
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
For this message the author Belanger88 has received thanks:
Jan1966 (10 Mar 2017, 11:32)
Belanger88
Has thanked: 104 times
Have thanks: 34 times
Postby Frank_NH » 10 Mar 2017, 19:26
Pretty cool - seems well-built. It obviously was designed to be opened up given the various internal switches. Just three TL072 op amps? Hmmm. :scratch:
For this message the author Frank_NH has received thanks:
Frank_NH
Has thanked: 20 times
Have thanks: 77 times
Postby J0K3RX » 11 Mar 2017, 05:56
Ok here are some raw images that I took with my phone. I need to clean the flux off this thing.. There is a thick candy coating all over the boards and even up on the transistors which I cleaned with a Q-tip and denatured alcohol.. I will probably end up removing the jacks from the main board. Need to pay attention on that because the jacks are different and that is why I screwed the nuts back in after I removed the board. They have different threads and different lengths. I may end up removing all of the pots from the daughter board but maybe not.. will see.
https://dl.dropboxusercontent.com/u/111 ... %20Pro.zip
I will be getting more pics but these should give anybody a good over all look at the pedal.
J0K3RX
Postby J0K3RX » 12 Mar 2017, 17:06
Couple more with the jacks and the boost pots removed.. I will probably remove all of the pots from the little board and I think I will remove all of the TL072's.
For this message the author J0K3RX has received thanks: 8
bajaman (13 Mar 2017, 10:39), Belanger88 (13 Mar 2017, 06:04), bmxguitarsbmx (12 Mar 2017, 20:02), hyrk (16 Mar 2017, 14:18), mlp-mx6 (02 Apr 2017, 02:45), nexion777 (05 Jun 2017, 19:32), toneman (26 Jul 2017, 15:57), x-tn (20 Mar 2017, 16:46)
J0K3RX
Postby J0K3RX » 17 Mar 2017, 22:31
If anybody cares, I am slowly kicking it's ass... Whoever created this board layout is completely insane!
For this message the author J0K3RX has received thanks: 20
bajaman (18 Mar 2017, 22:54), bmxguitarsbmx (17 Mar 2017, 23:56), Broadcaster (30 Jul 2017, 08:29), DimebuGG (18 Mar 2017, 12:15), FiveseveN (18 Mar 2017, 02:52), marmaliser (20 Mar 2017, 10:02), modman (05 May 2019, 17:38), nexion777 (17 May 2017, 15:23), Nicht Bernd (21 Mar 2017, 16:45), x-tn (20 Mar 2017, 16:46) and 10 more users
J0K3RX
Postby rcustoms » 17 Mar 2017, 22:43
J0K3RX wrote:If anybody cares, I am slowly kicking it's ass... Whoever created this board layout is completely insane!
awesome work,please schematics
guitars,pedals and amps.
@zuleta.rafael(Instagram)
For this message the author rcustoms has received thanks:
nexion777 (05 Jun 2017, 19:33)
rcustoms
Has thanked: 348 times
Have thanks: 493 times
Postby darmstat » 23 Mar 2017, 22:56
Hello Any progress on this one? Thanks
darmstat
Have thanks: 46 times
Postby hyrk » 24 Mar 2017, 09:31
I care, I care !!
For this message the author hyrk has received thanks:
nexion777 (26 May 2017, 17:52)
hyrk
Has thanked: 17 times
Postby J0K3RX » 26 Mar 2017, 00:06
It's coming along, slowly.. I may have something this weekend but don't hold your breath. :? My life is one distraction after another and by the time I am able get one moment to myself I am ready to go to sleep... :roll: I thought the tight metal was a twisted spaghetti bowl of traces but this thing makes that seem simple. It's not really that bad but the traces are all over the place and change sides constantly and it just never seems to end.... If not for my LED flash light being used as a PCB x-ray I would be Ska-Rewd! :wink:
For this message the author J0K3RX has received thanks: 7
Belanger88 (18 Apr 2017, 08:00), bmxguitarsbmx (26 Mar 2017, 20:33), brejna (15 Apr 2017, 17:17), dv8r601 (14 Jun 2017, 23:01), hyrk (28 Mar 2017, 08:35), nexion777 (17 May 2017, 15:25), Nicht Bernd (24 May 2017, 17:23)
J0K3RX
Postby agung » 18 May 2017, 12:25
Helooo
Any progresss for this tight metal pro ?? :horsey: :horsey:
For this message the author agung has received thanks: 2
nexion777 (19 May 2017, 18:27), Nicht Bernd (18 May 2017, 12:30)
agung
Have thanks: 2 times
Postby moonshiner » 21 May 2017, 01:08
Cant wait for this one
moonshiner
Postby batak_man » 08 Jun 2017, 09:44
thx for the share, you really2 help guitarist who want great pedal but dont have lot money like me.. hahaha
Its the final layout?
Btw its blur if i zoom. If you dont mind, would you share HQ pic?
batak_man
Has thanked: 15 times
Have thanks: 7 times
Postby J0K3RX » 10 Jun 2017, 21:25
I can assure you that this will be completed even if I have to box it up and send it to somebody else to finish! I have a son that has severe autism and he has been going through a rough time so, I haven't had time to even begin to get my head back into this twisted ass pedal... My son is 110% priority over everything else on the face of this earth, hope you can understand..
you want a higher res shot ok but, I can tell you that you won't be able to make any sense of it where I left off but, here ya go anyway..
Here are the really large images
https://www.dropbox.com/sh/oz8efydd4po9 ... 8Mu0a?dl=0
askwho69 (21 Oct 2017, 11:06), batak_man (19 Jun 2017, 14:30), Belanger88 (29 Jul 2017, 03:57), coldcraft (11 Jun 2017, 03:45), dv8r601 (14 Jun 2017, 23:02), hyrk (26 Jun 2017, 15:36), ilshat (11 Jun 2017, 07:50), modman (05 May 2019, 17:38), nexion777 (10 Jun 2017, 22:39), teddeeh (11 Jun 2017, 20:55)
J0K3RX
Postby batak_man » 13 Jun 2017, 15:26
J0K3RX wrote:I can assure you that this will be completed even if I have to box it up and send it to somebody else to finish! I have a son that has severe autism and he has been going through a rough time so, I haven't had time to even begin to get my head back into this twisted ass pedal... My son is 110% priority over everything else on the face of this earth, hope you can understand..
thx Mr. J0K3RX for the pic. I understand and im realy2 sorry if im ask in wrong time. Hope god show the way. :thumbsup :thumbsup :thumbsup
batak_man
Postby darmstat » 26 Jul 2017, 13:49
Any luck on a schematic of the EQ section? Please
For this message the author darmstat has received thanks:
nexion777 (26 Jul 2017, 16:29)
darmstat
Re: Amptweaker - BigRock/TightMetal Pro  [traced]
Postby bajaman » 27 Jul 2017, 06:57
Thanks to jokerx
tidied up layout and generated schematic :wink:
For this message the author bajaman has received thanks: 13
287m (29 Jul 2017, 10:57), apollomusicservice (29 Jul 2017, 11:31), batak_man (03 Aug 2017, 13:27), bmxguitarsbmx (30 Jul 2017, 20:35), ilshat (07 Oct 2017, 19:54), J0K3RX (27 Jul 2017, 18:27), modman (05 May 2019, 17:39), nexion777 (27 Jul 2017, 19:30), rcustoms (29 Jul 2017, 14:32), zamguitar (27 Jul 2017, 14:25) and 3 more users
Has thanked: 457 times
Have thanks: 1579 times
Postby bajaman » 29 Jul 2017, 11:02
No lights
No boost
No loops
No worries
Just a Hammond 1590BB friendly board packed with components - all switches sockets and pots off board connected by flying leads.
added a 12 v regulator to protect the added charge pump from over voltage. will easily run off 9v dc (or up to 18v dc).
Pictures when built and tested - probably about 3 weeks away so don't hold your breath :wink:
For this message the author bajaman has received thanks: 11
287m (29 Jul 2017, 12:49), apollomusicservice (29 Jul 2017, 11:31), batak_man (28 Aug 2017, 08:24), Chris60601 (03 Aug 2017, 20:32), J0K3RX (29 Jul 2017, 16:14), jalmonsalmon (31 Jul 2017, 00:51), Jan1966 (29 Jul 2017, 12:41), modman (05 May 2019, 17:39), naskoialan (15 Sep 2017, 15:40), teddeeh (30 Jul 2017, 00:22) and one more user
Postby 287m » 29 Jul 2017, 13:07
Baja :shock: you rock!
bookmarked. Too many list :mrgreen:
287m
Has thanked: 324 times
Have thanks: 57 times
Postby bajaman » 30 Jul 2017, 08:09
here's the wiring diagram for the bajaman BRP
The switches are all mini toggle type :wink:
Next
Users browsing this forum: Bret608, Nocentelli, pietro_moog, Stevenrb718 and 9 guests
