Lovepedal Champ  [traced]
Re: Lovepedal Champ
Postby WellinAudio » 07 Nov 2017, 18:56
Frabbio wrote:You are missing the 2.2M resistor between base and collector, and the electrolytic capacitors are 47uF, not 47nF.
Fixed the capacitors, thanks!
So the 2.2M resistor goes between B and C? Something like this? https://ibb.co/nQ1ZSb
I also saw the 4001 diode on the breadboard layout, but I couldn't find it on the hand drawn schematic. Is it connected between B+ and C4?
WellinAudio
Re: Lovepedal Champ
Postby Frabbio » 08 Nov 2017, 14:46
The 1n4001 is there for protection against inversed polarity, you can omit it.
C1 in your schematic should be 47 nanofarad.
The 2.2M is as in your schematic.
This is a modded Electra distortion, if you search the schematic on google you will see it's almost identical.
Frabbio
Has thanked: 10 times
Have thanks: 76 times
Re: Lovepedal Champ  [traced]
Postby andregarcia57 » 15 Mar 2018, 00:00
chamb is even schematic JTM checks?
For this message the author andregarcia57 has received thanks:
Manfred (15 Mar 2018, 00:50)
andregarcia57
Have thanks: 87 times
Re: Lovepedal Champ
Postby Manfred » 03 Apr 2018, 12:57
Here the separate drawing of the Lovepedal JTM schematic according the layouts from above.
Has thanked: 976 times
Have thanks: 523 times
Users browsing this forum: [Gringo], blackboarcult, G.G., KazTsuno, run~river~run and 14 guests
