Black Arts Toneworks - Boneshaker  [traced]
Re: Black Arts Toneworks - Boneshaker  [traced]
Postby SteveDallman » 29 Dec 2017, 14:44
Schematic from DOD
For this message the author SteveDallman has received thanks: 5
d312a (29 Dec 2017, 16:52), Manfred (02 Jan 2018, 06:45), modman (01 Jan 2018, 14:41), Nocentelli (29 Dec 2017, 18:14), Victor Nery (17 Jan 2018, 04:53)
SteveDallman
Have thanks: 8 times
Postby jrfox92 » 29 Dec 2017, 20:19
That's certainly prettier than mine. :lol:
Where'd you get it from?
Oh, here's an update based on the PDF:
jrfox92
Have thanks: 52 times
Postby SteveDallman » 01 Jan 2018, 14:37
I requested it from DOD and a few minutes later it was in my email.
For this message the author SteveDallman has received thanks: 3
Gila_Crisis (04 Jan 2018, 14:29), modman (01 Jan 2018, 16:37), Nocentelli (04 Jan 2018, 15:20)
SteveDallman
Postby Gila_Crisis » 04 Jan 2018, 14:28
EddieTavares wrote:It looks like a modified infamous boss hm-2:
http://1.bp.blogspot.com/-k5ZZPH95Fxg/T ... 2BHM-2.gif
that's the same I thought aboutwhen I looked at the schematic!!! wouldn't it be all SMD it'll be quite easy to mod these to more HM2-vibes!
Gila_Crisis
Have thanks: 68 times
Postby Khas Evets » 04 Jan 2018, 18:54
I have the HM-2 and Boneshaker. There are some similarities to the HM-2, but they sound very different to my ears.
If you block it out,
The Boneshaker is SHO -> Opamp gain stage with Depth -> Si diodes to ground -> gyrator eq (or just SHO -> DOD 250 -> eq)
The HM-2 is two transistor gain stages -> TS style soft clipper -> GE diodes in line -> SI diodes to ground -> gyrator eq
While the gyrators are similar, the clipping section is quite different. The HM-2 is a hodgepodge of clipping stages, and IMHO suffers from it. Plus the GE diodes in that configuration are fairly uncommon in dirt boxes. I think removing some of the diodes in the HM-2 might actually improve it. I've jumped the GE diodes and preferred it.
For the Boneshaker, it might be interesting to put a 5k gain knob in place of the 820k resistor. That would complete the SHO circuit. Stock, the BS always has some distortion, even at the lowest gain setting. I imagine it would act as a saturation control. Then add a switch to bypass the DOD 250 section. A SHO into a semi-parametric eq would be very useful.
Khas Evets
Postby jrfox92 » 04 Jan 2018, 22:56
Khas Evets wrote:The HM-2 is two transistor gain stages -> TS style soft clipper -> GE diodes in line -> SI diodes to ground -> gyrator eq
FYI, those are coring diodes. IIRC, they function as a crude noise gate.
jrfox92
Postby EddieTavares » 04 Jan 2018, 23:34
Gila_Crisis
Years ago a friend gave me one hm-2. Honestly I have never used that out of my house, some days ago I got it to apply some mods to make it sound more "Boneshakerish" and it sounds much better now. I just increase the feed back resistor r15 to 330k to reach the gain that I've heard in the videos.
In the eq section I don't want to add more pots but find some values that sound better in my rig, so I decided to keep the two tone control and maybe I set internally the mid control cutting some db's at 500 to 800 hz.
Khas Evets
Off course they are not the same, hm-2 imho is a peace of ***** but both have almost the same building blocks, the boost and drive sections cam be easily applied in the HM-2, there is no space in the enclosure to add 5 more pots but I'm setting internally the frequencies and band width to something more usable with my guitar and amp.
EddieTavares
Have thanks: 13 times
Postby Khas Evets » 05 Jan 2018, 01:50
They do function as a noise gate, but they also introduce crossover distortion, which is the part I don't care for.
Khas Evets
Previous
Users browsing this forum: alligatorrat, G.G., Sogum92 and 6 guests
