Keeler Designs Push
Keeler Designs Push
Postby mirosol » 26 Jun 2017, 19:37
So. There was one of these for sale as a defect unit on a local forum. Description said that there is "some bad contacts or something", but the price was realistic. I already knew this one will be gooped, but went ahead anyway. Got it in the mail and ripped it open as soon as i found the time to do so. Sure enough. Massive loads of clear and black goop. The only real issue with the unit was the standard 3PDT stomp, which didn't work properly. Now, i had it open on my desk and... Well. The pedal sounds pretty decent, big and somewhat cool with its high-ish gain. I didn't hear it like it would be a straight up clone of anything i know, so i was somewhat interested. Took my exacto knife, 12V spare iron, bigger knife and a few other tools out. About an hour or two later, i had pile of crap on my desk, but the circuit was finally bare. All it took was some moderate violence and lots of patience. I did break the power supply current limiting resistor, 47p cap at the feedback loop and also did some damage to the power filter cap. Replaced those and ordered suitable pots to replace the original ones (which are quite horrible). Now that the goop is gone, those standard angled pots will fit in there nicely. Did the trace, figured it should work, drew a stripboard layout and built it. Sounds exactly like the original. Well then a gain.. It's very low parts count design. Wasn't exactly what i was expecting. Simple, yet quite cool design. Fat TS clipper stage, followed by a Rat-like "tone" control, which is buffered - this followed by a standard volume control. IMO, this could have gained a lot more respect if it wasn't for the goop. Or the choice of pots. Funniest part is definitely the message left for me..
Anyway, here are the results.
Parts list / BOM:
All resistors standard 1% metal film, 1/4W
R1 1M2
R2 100K
R3 1K
R4 10K
R5 10K
R6 10K
R7 10K
R8 10K
R9 10K
R10 100R
C1 100n/63V poly
C2 330n/63V poly
C3 47p/50V ceramic
C4 6n8/63V poly
C5 1u/63V poly
C6 47u/25V alum. electrolytic
C7 47u/50V alum. electrolytic
Gain B500K
Tone B50K
Volume B100K
OP1 sanded, possibly 4558/072, or some other dual opamp
D1 unmarked Si, possibly 1N4148, could be a zener
D2 3mm Diffused red LED
D3 3mm Diffused red LED
LED 5mm Clear blue
And the photos. And the schematic. And the layout.
Consider all verified.
For this message the author mirosol has received thanks: 15
bbkassel (26 Jun 2017, 22:21), Chris60601 (03 Jul 2017, 15:15), d312a (27 Jun 2017, 09:35), deltafred (27 Jun 2017, 08:50), dv8r601 (26 Jun 2017, 22:42), FeVeR2112 (27 Jun 2017, 01:01), Intripped (26 Jun 2017, 20:15), Manfred (26 Jun 2017, 21:37), nexion777 (26 Jun 2017, 22:33), storyboardist (27 Jun 2017, 15:24) and 5 more users
mirosol
Has thanked: 153 times
Have thanks: 354 times
Re: Keeler Designs Push
Postby FeVeR2112 » 27 Jun 2017, 00:59
I find the silkscreen text of "Curious?" pretty funny... Only visible after de-goop... :lol:
For this message the author FeVeR2112 has received thanks:
electrosonic (27 Jun 2017, 06:56)
FeVeR2112
Has thanked: 16 times
Have thanks: 24 times
Postby dv8r601 » 27 Jun 2017, 07:27
I built this up at work tonight. Easy and very good sounding overdrive with a good bit of gain. I appreciate all your work mirosol, you are a champion among men.
dv8r601
Has thanked: 349 times
Have thanks: 16 times
Postby Manfred » 27 Jun 2017, 11:35
dv8r601 wrote:I built this up at work tonight. Easy and very good sounding overdrive with a good bit of gain. I appreciate all your work mirosol, you are a champion among men.
Which type of OpAmp did you install?
Manfred
Has thanked: 913 times
Have thanks: 454 times
Postby mirosol » 27 Jun 2017, 11:39
I put 4558D in mine. No audible difference between the stripboard and the original unit.
+m
Manfred (27 Jun 2017, 16:08)
mirosol
Postby dv8r601 » 11 Sep 2017, 17:56
Damn. My bad. I just saw you asked what opamp. I used a rc4558 and a jrc4580. It works great with whatever you put in it.
dv8r601
Postby Manfred » 15 Sep 2017, 23:10
I made board layout copy according the schematic and the shots and added the hidden tracks by guess.
PushComponents.pdf
PushComponentSide.pdf
PushSolderSide.pdf
PushComponentSideMirrored.pdf
PushSolderSideMirrored.pdf
For this message the author Manfred has received thanks:
mirosol (16 Sep 2017, 18:50)
Manfred
Postby Manfred » 18 Sep 2017, 01:43
I made a single sided board version, the conducting paths on the components side were replaced by wire jumpers.
PushComponentsSingleSide.pdf
PushSolderSingleSide.pdf
PushSolderSingleSideMirrored.pdf
For this message the author Manfred has received thanks: 3
bmxguitarsbmx (18 Sep 2017, 19:31), dv8r601 (19 Sep 2017, 21:00), mirosol (10 Dec 2017, 09:12)
Manfred
Users browsing this forum: jimiguitar and 13 guests
