Lovepedal - Dover Drive  [traced]
Re: Lovepedal - Dover Drive
Postby ivan H » 01 Oct 2017, 01:14
That's great if one is looking to change the original effect into a high gain distortion (I already have high gain distortions), however I put this together because I wanted the original effect for some Reverend Billy G type tones which it can do quite well. A search on transistor gains for silicon fuzz face type circuits led me to info that the first transistor gain is best somewhere around 65% ~ 85% of the second transistor. Actual gains aren't so important (allegedly) so long as this ratio is kept. Apparently this gives the best interaction between the guitar & effect, allowing cleanup with the guitar's volume control, touch sensitivity etc. Also mentioned experimenting with input/output cap values along with the transistors to get tonal response desired. Cheers
ivan H
Have thanks: 9 times
Postby Manfred » 01 Oct 2017, 09:22
I am interrest in this theme too and going to work on it.
Manfred
Has thanked: 784 times
Have thanks: 362 times
Postby di-anno » 02 Oct 2017, 21:23
Manfred wrote:Thanks, sounds good!
I further step could be to hook in the blend circuity of the Lovepedal Silicon Fuzzmaster.
http://tagboardeffects.blogspot.de/2012/06/lovepedal-silicon-fuzzmaster.html
Thanks for reply, it's fairly clear that bassy/clarity of this pedal strongly depends on its input impedance and probably in your link there is the best solution to manipulate it. However I found in buffered version a better sound than the original (..for my ears and for my rig..) so i experienced in that way introducing a dual gang pot in buffer to control clarity/bass and volume pot responce. i still have some noise problem but promises good.
I think that in front of fuzz face type pedal it would be very useful something like this:
http://www.stompbox.de/buffer_english.html
di-anno
Have thanks: 4 times
Postby ivan H » 03 Oct 2017, 06:52
Cool, I'd be interested in your results. I'll do the same when time allows. Cheers
ivan H
Postby ivan H » 31 Oct 2017, 10:55
Ok, I know its been a while, been pretty busy but I have spent a little time tweaking. Went back to 209 hfe for Q1 & 271 hfe for Q2 (Q1 @ 77% of Q2). This gives the best performance & interaction with the guitar, just bass heavy. So, I lowered the value of the FF output cap by half to 0.047uf which did the trick. Still have the resistor in series with the gain pot at the moment. Cheers
ivan H
Postby Kennc_dk » 05 Nov 2017, 09:32
I have measured key bias nodes on the Dover Drive that i traced the schematic from:
Battery measured to 9.43 volts.
On the IC :
pin 1,2,5,6 and 7 = 3.04 Volt
Pin 3 = 2.88 Volt ( hmm, I’ll recheck this one)
Pin 8 = 6.17 Volt
Pin 4 = 0 Volt
On PNPs :
Q1: 6.17 V, 5.89V and 4.85 V
Q2: 2.07 V, 4.85V and 5.49 V
I’ll measure HFE on both of them very soon.
Note to PNPs: gain is set to 1’oclock. Internal trimmer is Stock, as on the schematic.
For this message the author Kennc_dk has received thanks: 2
di-anno (05 Nov 2017, 20:53), Manfred (05 Nov 2017, 09:35)
Kennc_dk
Have thanks: 19 times
Postby Kennc_dk » 05 Nov 2017, 09:55
Yes, the pedal i quite bassy, so i have added an external switchable low-cut a’ka ‘The fuzz face Eric Johnson mod’ on the output of the Dover drive. Adding the low-cut between fuzz stage and OD stage causes nasty biasshifts.
I use the low-cut mainly on solos that are not to take too much Sound space in the band. In a trio constellation i almost never use the low cut.
Yes, due to the High gain of this pedal and the PNPs (AM detectors!) at the input, the pedal i prone to Pick up radio signals, mobile phones ect.
Despite bassy’ness and radio moskow, I LOVE MY DOVER DRIVE PEDAL!
Kennc_dk
Postby ivan H » 06 Nov 2017, 10:36
Thanks heaps for the voltages Kennc_dc, I'll check through mine against them. I did a quick google search but haven't found anything on the Eric Johnson low cut mod yet, I'd be interested to know about. I'll look a bit further. I did look at the the axis fuzz mods, might try a couple of. Cheers
ivan H
Postby Kennc_dk » 12 Nov 2017, 18:06
ivan H wrote: I did a quick google search but haven't found anything on the Eric Johnson low cut mod yet, I'd be interested to know about. I'll look a bit further. I did look at the the axis fuzz mods, might try a couple of. Cheers
on this www: https://www.electrosmash.com/fuzz-face its stated that:
"Eric Johnson seems to prefer a 100KΩ level resistor over the stock 500KΩ. Using a smaller resistor, the filter will cut more lows out (fc=160Hz) which will result in a brighter sound."
This makes sense regarding Erics solos, so I added the 160Hz LF/bass cut on the output of the Dover drive as I described previously. if your solo is to ride on the top of a crowed band, this preferably selectable -mod/option makes sense, both for the fuzz faces and the dover drive ;-)
Kennc_dk
Postby ivan H » 13 Nov 2017, 10:04
This is exactly why I am experimenting to brighten it up. In a 3 piece setting it might do ok as is, but trying to use for leads in a 4 piece, well, you already know. Thanks heaps for the tip, greatly appreciated. Cheers
ivan H
Previous
Users browsing this forum: Chugs, jrolvera, kusi and 7 guests
