Catalinbread - SFT REV 2
Postby Visualdistortion » 29 May 2016, 17:30
Someone share me the SFT REV 2 for the week, so I take pictures and get values of capacitors and pots, maybe it can help for helping debugging the previous tracing.
This is pictures: https://www.dropbox.com/sc/p76h70dy0ch3 ... G8ttR24Bxa
I can give you more information but you need to be really fast, because I will give back the pedal tomorrow.
Catalinbread SFT REV 2
Pots:
Treble & Bass : A1M
Vol: A250K
Gain: A1M
1N4001 protection diode
Q1-Q6: MPF 4393
CAPACITORS:
C1: 104K
C2: /
C3: 4n7
C4: 1uF
C5: 683K
C6: 151 1KV blue
C7: /
C8: 1uF
C9: 104K
C10: 102K
C11: 4n7K400
C12: 681K
C13: 472K
C14: .47 1KV blue
C15: 1uF Pol
C17: 2,2uF Pol
C18: 472K
C19: 472K
470uF
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
For this message the author Visualdistortion has received thanks: 5
arcaarca (06 Jun 2016, 16:32), blackbunny (12 Jan 2018, 11:15), Blend (29 May 2016, 22:05), deltafred (30 May 2016, 12:18), lohstah (31 May 2016, 21:32)
Visualdistortion
Have thanks: 17 times
Re: Catalinbread - SFT
Postby SonicRiff » 06 Jun 2016, 15:51
That's great. thanks ! The SFT Rev2 is awesome.
SonicRiff
Postby Blend » 06 Jun 2016, 16:08
Here is a schematic based on "Visualdistortion" pictures, concrete differences compared to the first version of the SFT removing 2 of the 8 original 2N5457, replaced with mpf 4393 and used here with variant mu-amp SRPP, adding gain boost, reshaped tone etc. Has anyone had a chance to compare the sound of both versions? I version is reliable with bass (top 18/24v), whose guitar. For those shown in the schematic (?) It was impossible to verify the value (R) and the connection (Q6 source resistance).
For this message the author Blend has received thanks: 3
arcaarca (06 Jun 2016, 16:32), lohstah (07 Jun 2016, 13:01), SonicRiff (07 Jun 2016, 09:53)
Blend
Has thanked: 45 times
Have thanks: 53 times
Postby Visualdistortion » 06 Jun 2016, 21:43
I compared a clone of version I I did few years ago (apparently the tracing of the first version have some errors) with this one, I can really say that the version II it's really really better, awesome ampeg tone on a clean bass amp.
I can try to get again the pedal, and verify what you want with pictures, please tell me asap what you need to confirm.
I tried to label the resistors; but they are really close to the pcb.
I wanna make it
French... sorry ;)
Visualdistortion
Postby SonicRiff » 07 Jun 2016, 09:58
I have the V1 and had the opportunity to test V2.
The V2 is really awesome, much easier to use thanks to the switch and has a wider tonal range (like 2 amps in one pedal). Like the V1, SFT V2 works like a charm with my bass.
SonicRiff
Postby Blend » 07 Jun 2016, 13:58
hello, I'm sending you the pictures in which you can understand where I miss the connecting traces, i reloading the schematic for writing correction R17 is 1K8.
ozzy666 (08 Jun 2016, 19:06)
Blend
Postby Blend » 07 Jun 2016, 14:18
If you can control tracks under Q1 and Q6 is perfect.
For this message the author Blend has received thanks: 2
ozzy666 (08 Jun 2016, 19:06), SonicRiff (07 Jun 2016, 16:17)
Blend
Postby Visualdistortion » 12 Jun 2016, 08:51
On Q6, C14 go on the center pin S
On Q1, the 2 1M resistors are NOT connected to the D pin
R10 go directly to G pin of Q4. C5 is not connected to G PIN
I've added tons of pictures, tell me if you need something more. It's actually sunday 10am here, I can take the pedal with to monday 5PM.
I wanna make it
French... sorry ;)
Blend (12 Jun 2016, 11:05)
Visualdistortion
Postby Visualdistortion » 12 Jun 2016, 17:33
https://www.dropbox.com/s/tkz6y23cny55o ... 1.jpg?dl=0
On left of Q6: Brown black Red Gold so 1K
I don't have nothing to measure the blue cap it's writted
'47
1KV
and the " ' " it's clearly in front of number 47
ALSO:
- The + leg of C4 go on the the left point of C3.
- On Q1, the 2 1M resistors are NOT connected to the D pin
- R10 go directly to G pin of Q4. C5 is not connected to G PIN
I wanna make it
French... sorry ;)
For this message the author Visualdistortion has received thanks: 2
Blend (12 Jun 2016, 19:01), lohstah (14 Jun 2016, 09:11)
Visualdistortion
Postby Blend » 12 Jun 2016, 19:13
It finally, thanks to Visualdistortion for the many pictures taken, C14 is 47pF and downhill from source Q6 the resistance value is 1K. In conjunction with the drafting of the schematic, I have tried to adopt some improvements on my clone of the first version of the SFT and it really worth for those who kept him in a drawer or as a doorstop or if you do not want to deal with the new building of the SFT II.
For this message the author Blend has received thanks: 4
deltafred (12 Jun 2016, 21:29), HENK (13 Jun 2016, 11:44), lohstah (14 Jun 2016, 09:11), Visualdistortion (12 Jun 2016, 20:47)
Blend
Postby Visualdistortion » 12 Jun 2016, 20:37
Awesome! hope someone will do a pcb or a vero soon =D
I wanna make it
French... sorry ;)
Visualdistortion
Postby Blend » 12 Jun 2016, 22:05
In the meantime, try these simple mods on an old SFT, may be enough. (The schematic used had been done by gkoerselman to page 5)
Blend
Postby roseblood11 » 12 Jun 2016, 22:15
That switch will make a loud noise... Better place a large resistor in series with the cap and short it with the switch.
For this message the author roseblood11 has received thanks:
Blend (12 Jun 2016, 22:24)
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby Blend » 13 Jun 2016, 19:14
If I connect the capacitor 22uF, the problem arises, but with the complete switch as in the original I do not hear any crackling noise, other mod that suggest you do in the 1st SFT is to replace R5 22k with 10k. :wink:
n4m3less (04 Apr 2017, 23:30)
Blend
Postby Visualdistortion » 06 Jul 2016, 08:59
I made the vero from Tagboard and it seems to get the same problem than the others people who made it:
- The pedal is really low/dark tuned compared to the original, I think there is a problem on the bass pot, like you can't shut up the bass frequenciens (on the original, on bass at 0, you only get treble)
- There is a switching mode problem, on "stoner mode" in the clone, I get the same the same amount of gain than the "stones mode" on the original, and on the stones, I've clearly less gain.
I wanna make it
French... sorry ;)
Visualdistortion
Postby Visualdistortion » 06 Jul 2016, 13:21
Finally on the tagboard there was a problem on the pinout of the swtich, I rewired it, and now the pedal seems pretty close to the original, like 90%.
Just a bit less volume and bit more bassy, when the original get a lot of high medium, the clone are more on low medium.
I wanna make it
French... sorry ;)
Visualdistortion
Postby Blend » 06 Jul 2016, 15:33
What kind of jfet are using in place of the originals ?
Blend
Postby Visualdistortion » 06 Jul 2016, 17:58
The same than the original
I wanna make it
French... sorry ;)
Visualdistortion
Postby Blend » 11 Jul 2016, 13:00
... Pictures with shadows, colors ambiguous or unfocused, mmmm: everything ok except 3 red rings = change the last stand with 2k2, benefits in the output impedance, in db volume and in eq and remember to clone the doubt! :roll:
blackbunny (12 Jan 2018, 11:15), ozzy666 (15 Jul 2016, 23:39)
Blend
Postby Visualdistortion » 12 Jul 2016, 11:33
:applause:
I will try this tomorrow. Thanks.
I wanna make it
French... sorry ;)
Visualdistortion
Next
Users browsing this forum: digi2t, dikenn, electricb, rock soderstrom and 11 guests
