Throbak - Strangmaster  [traced]
Postby Manfred » 17 Aug 2017, 21:21
In the shot you can see well the Germanium transistor typ 2SD96.
Who knows the applied Silicon transistor type on?
Manfred
Has thanked: 1051 times
Have thanks: 637 times
Re: Throbak strangmaster
Postby dv8r601 » 19 Aug 2017, 08:01
Dont get upset if I'm wrong but I think it was a bc108b in mine or maybe a 2n2222. I had it a while back and never messed with it because it sounded pretty good as it was.
For this message the author dv8r601 has received thanks:
Manfred (19 Aug 2017, 09:33)
dv8r601
Has thanked: 409 times
Have thanks: 23 times
Postby Manfred » 19 Aug 2017, 09:39
Thanks for your the answer.
In view of the current gain the 2N2222 is more likely.
Do you know the values of the other components too?
Manfred
Postby dv8r601 » 22 Aug 2017, 00:36
I didn't take time to write anything down when I had it, now thinking about it I'm almost certain it was an 2n2222a. Plus, They use them in alotta other pedals they make, so I'm pretty sure that is it. I'll see if the new owner can take some board shots and get back to me. I wanna make one myself, because it was a killer od pedal.
dv8r601
Postby bc108 » 06 Aug 2018, 23:44
For sure, it seems that they use 2n2222: maybe due the low hfe (like the Ge's one's).
For reference, take a look to the Catalinbread Naga Viper; Rangemaster NPN version, some add's and use a 2N2222 transistor.
bc108
Has thanked: 20 times
Re: Throbak strangmaster  [traced]
Postby Manfred » 26 Jan 2019, 22:58
I bought an used Strangmaster several months ago, I sold it in the meantime.
I made some shots and traced the PCB.
Furthermore, a made some measurements.
Here are the results:
Read transistor values:
NPN Silicon BJT 2N2222A:
hFE=258 at Ic=5,02mA
Vbe=0,752V at Ib=5,00mA
VceSat=0,018V at Ic=5,0mA and Ib=1,00mA
IcLeak=0.000mA
NPN Germanium BJT 2SD30:
hFE=119 at Ic=5,01mA
Vbe=0,298V at Ib=5,00mA
VceSat=0,017V at Ic=5,0mA and Ib=1,00mA
IcLeak=0,176mA
I made output traces using different input signal voltages at different bias pot settings.
I measured the frequency response too.
You can find the readings in the following ZIP-file.
All diagrams were labeled.
StrangMasterMeasurements.zip
For this message the author Manfred has received thanks: 5
bc108 (27 Jan 2019, 00:13), dv8r601 (31 Jan 2019, 23:12), fernandorock13 (28 Jan 2019, 18:57), ilshat (05 Feb 2019, 16:43), karul (27 Jan 2019, 01:40)
Manfred
Postby jalmonsalmon » 02 Apr 2019, 18:59
I am kind of wondering what effect that 220p cap has on the input to ground :scratch:
jalmonsalmon
Has thanked: 81 times
Have thanks: 24 times
Postby Manfred » 02 Apr 2019, 20:21
jalmonsalmon wrote:I am kind of wondering what effect that 220p cap has on the input to ground :scratch:
The capacitor serves to supress radio frequencies.
For this message the author Manfred has received thanks: 2
ilshat (27 Oct 2019, 18:28), jalmonsalmon (03 Apr 2019, 03:09)
Manfred
Postby RSWRecording » 07 Apr 2019, 00:43
Same thing I was wondering.
RSWRecording
Re: Throbak - Strangmaster
Postby modman » 13 Apr 2019, 22:18
I didn't mean to lock this topic, just happened because it was put on solved in the wrong folder.
Keep on necrobumpin' that shit ;-)
Has thanked: 3298 times
Have thanks: 612 times
Users browsing this forum: gturo, ouka987, tbist32, txvaporguy and 19 guests
