LR Baggs Para DI Acoustic Preamp
- lukatosh
i've started tracing this yesterday... So far this is what i have
Here is the power section... You can look at IC1 that pin 4 is not conected directly to ground. Somebody can explain this circuit block? (The unit may be phantom powered). Here, C9 is a NON polarized capacitor (50v 22uf NP). Is there a way that you can replace this using two electrolitic capacitors? Finally, the input signal flow start like this... Thanks!
Good work
Why would you want to replace the non-polar cap??? They are readily available.
Where are you??lukatosh wrote:Not much in my country
- lukatosh
Apparently... the signal goes like this:
Input-> Gain Stage- >Buffer -> Eq -> Phase invert and line balancing (DI) ->Out
The Eq is based on this:
http://www.geofex.com/article_folders/eqs/paramet.htm
Tree fixed frecuencies usin transistors (treble, presence and bass) and two variabe frequencies (Notch and Mids)
A couple of questions...
1) About the leds... Since non of them have a current limiter resistor, is possible that they have a built in resistor? How can i check this?
https://www.mouser.com/new/kingbright/k ... stor-LEDs/ 2) Is this correct? i want to replace the NP capacitor. Are they related to the phantom power? (please omit the "+" sign in the lower circuit, it's a non polarized capacitor )
- phatt
- Transistor Tuner
Hard to answer but the Led (the snippet you posted) it has a Zener which sets the voltage so there is no need for a drop resistor. Very few circuits would use Leds with the built in resistor.
As for the NP Capacitor Q, In most cases you can just use a Polar Cap with positive facing the active device. (The output of the opamp I'm guessing) it will make no difference to the AC signal.
The pin 4 drawing makes little sense and without a more detailed drawing of the circuit with values on the components (Hint) it's had to give a meaningful answer. You may have misread the tracks which is easy to do.
I often have to re draw a circuit a few times before it makes sense.
Can I suggest you post a picture of the board that might help us to understand the circuit.
Phil.
Phil.
- lukatosh
Well...here we go. I have not had much time... To much to do at work.
1.- The unit uses 3 LMC6032.
IC2a Eq
IC2b Line balancing
IC3a: Notch control freq.
IC3b: Line balancing.
IC1a used to control bass freq.
IC1b used on this arrangement: ¿it' possible to replace the LMC6032? (Not available in my country). From what i've readed, mostly it was selected because of its low power comsumption. The unit may be powered by batteries or phantom. I want to add a 9v dc supply so, current comsumption will not be a "mayor problem".
2.- What about the leds and zeners?... Even if the zener sets the voltage, will even be needed a current limit resistor?
IC2a Eq
IC2b Line balancing
- phatt
- Transistor Tuner
Again without a full schematic it's hard to know what's going on but as it's a basic audio circuit I'd say any of the common opamps will produce the same outcome,, give or take an electron.
Regards the Led's,,, remember that the led only draws the current it needs if the voltage is too high then the led will overheat and burn out, the zener holds the voltage at the correct level so no need to use a resistor as well.
Phil.
Phil.
- lukatosh
This would be the power section .. Including the phantom power.
Simulated on multisim and phantom led works ok but not the same with the "on" led. I have to re check those resistor values arround the IC1 B.
Also...The IC is LMC6032. And "IN-RING" is conected to ground when the input plug is inserted.
- lukatosh
Hello again... Well, much to do at work... It doesn't left much time to work on this. But here we are again.
I've started the Eq section... specifically the presence control... I would like to understand how it works.
The manual says that it works on the 5kHz range. The circuit part traced is on the uploaded image.
How can i know a formula to verify that it really works on that frecuency and know the "Q" ? also...what if we could change that to 3.5kHz, what vaues should change?
i've looked at the AMZ gyrator calculator (http://www.muzique.com/lab/gyrator.htm) but... this circuit uses a JFET... and honestly, I do not remember much of what I study about transistors at university... I dont know what changes must be done to get the "5khz" as a result.
Also... JFET are a bit more expensive than Bipolar... Can I just use a 2n5088 as RG suggest? (http://www.geofex.com/article_folders/eqs/paramet.htm)
Hope you guys can help me!
Thanks so much... i will keep working on this!
- pres.PNG (20.77 KiB) Viewed 2975 times
- caspercody
Amy updates on the completed schematic?
