BJFE-Baby Blue  [traced]
BJFE-Baby Blue
Postby momo lab » 02 Nov 2017, 19:20
Hi, everyone,My English is very bad,Sorry about this.
this is bjfe-baby blue od, wonderful od pedal,I hope the disassembly process goes well.
For now, I have a question,I do not know the type of this diode,It's big,The character is S 2A 1200.
When I finish, I will upload the detailed layout, thank you all.
For this message the author momo lab has received thanks: 7
dv8r601 (02 Nov 2017, 23:22), Greg (03 Nov 2017, 13:30), HappyCat (28 Dec 2017, 15:38), Intripped (04 Nov 2017, 14:16), Manfred (03 Nov 2017, 03:48), modman (02 Nov 2017, 20:56), schrumpfschlauch (03 Nov 2017, 08:03)
momo lab
Have thanks: 30 times
Re: BJFE-Baby Blue
Postby toneman » 02 Nov 2017, 19:33
Looks like a schottky diode. Like ones used in switching power supplies. Has less voltage drop than a silicon diode.
Also Depends a little on where it is used in the circuit.
If it is in the clipping/clamping/feedback circuit, any schottky will probably work.
Maybe just try a good old 1N4148/1N914 (?)
8)
Tone-to-the-Bone
For this message the author toneman has received thanks:
momo lab (03 Nov 2017, 10:06)
toneman
Has thanked: 90 times
Have thanks: 19 times
Re: BJFE-Baby Blue
Postby Manfred » 03 Nov 2017, 04:17
You could measure the threshold voltage of the diode in this way:
I do not see an OP-Amp Pin layout on the PCB shot.
Is there an OP-Amp installed or is this only a transitor circuit?
For this message the author Manfred has received thanks: 2
bajaman (03 Nov 2017, 10:02), momo lab (03 Nov 2017, 10:07)
Manfred
Has thanked: 982 times
Have thanks: 531 times
Re: BJFE-Baby Blue
Postby momo lab » 03 Nov 2017, 10:19
This job is difficult and slow,I mean,Really slow.
The threshold for this diode is 0.536v and 0.523v,It does not use the OP-amp, but the use of a JFET,Very simple and effective circuit.
For this message the author momo lab has received thanks: 2
Manfred (03 Nov 2017, 10:34), modman (03 Nov 2017, 18:28)
momo lab
Re: BJFE-Baby Blue
Postby Manfred » 03 Nov 2017, 10:49
What are the dimensions of the PCB-Board?
Manfred
Re: BJFE-Baby Blue
Postby momo lab » 04 Nov 2017, 12:55
Manfred wrote:What are the dimensions of the PCB-Board?
Its size is 55 * 22 mm, but its shape is irregular.
I have built an identical PCB plan,Although not perfect, but I am ready to use it,Suppose I copy the value of it.
For this message the author momo lab has received thanks: 3
anselm (05 Nov 2017, 13:42), Manfred (04 Nov 2017, 13:46), modman (07 Nov 2017, 11:59)
momo lab
Re: BJFE-Baby Blue
Postby Manfred » 09 Nov 2017, 17:02
I see, it is a tough piece of work, the tracing takes time.
Manfred
Re: BJFE-Baby Blue
Postby momo lab » 11 Nov 2017, 14:35
Sorry, a lot of work these days.
Schematic has been updated.
d312a (11 Nov 2017, 19:33), fuzzbunny (11 Nov 2017, 18:43), Greg (12 Nov 2017, 00:44), Manfred (11 Nov 2017, 20:31), modman (12 Nov 2017, 12:42), Nocentelli (11 Nov 2017, 16:22), Tuolotupa (11 Nov 2017, 21:45)
momo lab
Re: BJFE-Baby Blue
Postby momo lab » 11 Nov 2017, 21:41
I just updated the layout, and sprayed the shell ready to clone it, thank you all.
HappyCat (28 Dec 2017, 15:39)
momo lab
Re: BJFE-Baby Blue
Postby fuzzbunny » 12 Nov 2017, 01:22
Thanks for your hard work!
Do you have any idea which JFETs the original circuit used? Any voltage readings on the original JFETs?
How about D3 & D4 ? What kind of diodes?
fuzzbunny
Have thanks: 10 times
Re: BJFE-Baby Blue
Postby Manfred » 12 Nov 2017, 05:17
The FET-Stage circuits of the Baby Pink Booster and Model_H drive are similar to the Baby Blue FET-Stages,
where the 2N5952 FET is applied.
In my opinion R6 should by 22k not 220k as in the schematic shown.
BJFE applies often the 1N400X diodes as clipping diodes.
Manfred
Re: BJFE-Baby Blue  [traced]
Postby momo lab » 12 Nov 2017, 08:44
For this message the author momo lab has received thanks: 6
d312a (12 Nov 2017, 12:30), dv8r601 (13 Nov 2017, 09:03), Manfred (13 Nov 2017, 22:20), modman (12 Nov 2017, 12:41), resynthesis (23 Aug 2018, 01:04), toneman (10 Aug 2018, 18:03)
momo lab
Re: BJFE-Baby Blue
Postby momo lab » 13 Nov 2017, 14:25
fuzzbunny wrote:Thanks for your hard work!
Manfred wrote:The FET-Stage circuits of the Baby Pink Booster and Model_H drive are similar to the Baby Blue FET-Stages,
After I checked, R6 is indeed 22K, not 220K, 15K resistor should be 14.7K.
It uses diodes and JFETs I'm not sure, the diode has a clear character, S 2A 1200, but I do not know its model number.
After the measurement, the first stage FET voltage is 4.62V and 1.72V, the second stage FET voltage is 4.72 / 1.68 and the third stage is 5.55 / 1.44.
Earlier today, I tried to make a PCB and use it to test the BF244 as a JFET, frustrating that it did not work well, the gain was significantly lower, and the more frustrating thing was that I came from China, fake Very much, I'm not sure JFET in my hand is really BF244, in your country common 2NXXXX series I can not determine the hands of the real thing. I do not know where something went wrong, and now it's no longer sounding, ready to do a few more PCB tries, I will try to feedback in time, thanks again!
momo lab
Re: BJFE-Baby Blue
Postby Manfred » 13 Nov 2017, 22:44
I have done some calculations and found that the value R5 ist to high.
Please check it again, maybe is the value 14.7 Kohms not 47 kohms.
Cool milling, who is the manufacturer of the milling machine?
Have look at this webside, this rectifier diodes look much alike.
https://www.ebay.com/itm/Diode-Rectifier-75-Amp-1200-Volt-Vintage-Restoration-Part-Tested-Qty-of-2-/321099522209
Manfred
Re: BJFE-Baby Blue
Postby momo lab » 14 Nov 2017, 14:48
Manfred wrote:I have done some calculations and found that the value R5 ist to high.
Today I have reworked the PCB and tested it, except for the low gain, which worked fine.
Schematic diagram before the ground fault. Has been updated in V2.
This milling machine was made by myself three years ago, using only electric drills and saws. The production of a BB OD PCB about half an hour, but it is loud noise.
I found in another old Emerald Green thread that it uses the same diode and does not think this red diode is the same as it.
To make it easier to test for more diodes, I used a 24-segment switch to test more differently more quickly.
Communicate with everyone I use Google Translate, which was unthinkable 10 years ago, thank you all.
Manfred (14 Nov 2017, 20:30), megavolt (17 Feb 2018, 14:39), modman (01 Feb 2018, 12:05)
momo lab
Re: BJFE-Baby Blue
Postby marshmellow » 14 Nov 2017, 15:26
If you include a ground layer on your pcb, you would have to mill much less.
Print on the transistors is not readable?
marshmellow
Have thanks: 122 times
Re: BJFE-Baby Blue
Postby Manfred » 02 Dec 2017, 17:53
momo lab wrote:This job is difficult and slow,I mean,Really slow.
I want to know at which current the threshold has been measured?
Have you measured the voltages on the FET terminals in the original circuit?
Manfred
Re: BJFE-Baby Blue
Postby vovian » 31 Jan 2018, 00:41
Hello. Thank You for this big job. You made fantastic work. So what diodes is better for this project?
vovian
Re: BJFE-Baby Blue
Postby KK Japan » 31 Jan 2018, 03:08
Please Comeback, momo lab!
KK Japan
Have thanks: 4 times
Re: BJFE-Baby Blue
Postby Nick123 » 31 Jan 2018, 13:23
I think I have found an error in the last schematic.
Only the wiper of RV2 should be grounded.
Nick123
Have thanks: 9 times
Next
Users browsing this forum: Analogisch, EmmG, jt, LeFather, Mr.TYR and 19 guests
