Wampler - Hotwired vs 1  [traced]
Postby marckosolo1 » 08 Nov 2017, 21:57
Today I got this one to look at. This is version 1.Tracing was not difficult. Only one opamp is used for both sides {RC4580DD). Voltage dividing ( Vreff) is shared by both sides. Clear red leds are used. All caps are Panasonic film caps except the 47pF cap and the electrolytics in the divider-circuit. In the overdrive-section is a three-way on-of-on toggleswitch is used for bass. All resistors are metal-film. I don't have a good program for drawing schematics so i had to scribble some on the images .I hope it is clear enough. I didn't draw the switching . It is standard true bypass switching.
For this message the author marckosolo1 has received thanks: 13
alexradium (09 Nov 2017, 12:30), bmxguitarsbmx (09 Dec 2017, 20:26), drd (13 Nov 2017, 15:51), dv8r601 (08 Nov 2017, 23:32), Intripped (08 Nov 2017, 22:47), Manfred (08 Nov 2017, 22:50), modman (09 Nov 2017, 16:59), Nocentelli (11 Nov 2017, 18:01), sego91 (14 Nov 2017, 18:38), twangcat (09 Nov 2017, 01:01) and 3 more users
marckosolo1
Have thanks: 29 times
Re: Wampler - Hotwired vs 1
Postby sego91 » 16 Nov 2017, 01:47
Hey guys, here I transcripted the layout, correct please if you see something wrong, cause I'm gonna prepare the PCBs tomorrow :D
For this message the author sego91 has received thanks: 3
287m (16 Nov 2017, 23:07), Cybercow (02 Mar 2019, 04:17), modman (16 Nov 2017, 10:22)
sego91
Has thanked: 10 times
Have thanks: 9 times
Postby indyguitarist » 29 Nov 2017, 01:33
sego91 wrote:Hey guys, here I transcripted the layout, correct please if you see something wrong, cause I'm gonna prepare the PCBs tomorrow :D
[ Image ]
Looks right, but I *think* r16 and r7 were 1k resistors, not 10k. I thought we had used independent voltage dividers as well, but maybe not on this version. It's been 8 years ago or thereabout, so I could be wrong. But yes, it's a fairly simple circuit. Have fun with it, I just ask you don't violate registered trademark and sell it as a Wampler or Hot Wired or similar derivative.
For this message the author indyguitarist has received thanks:
sego91 (29 Nov 2017, 10:58)
indyguitarist
Have thanks: 162 times
Postby modman » 29 Nov 2017, 10:16
Another gut shot...
For this message the author modman has received thanks: 2
bmxguitarsbmx (09 Dec 2017, 20:24), sego91 (29 Nov 2017, 11:10)
Has thanked: 3283 times
Have thanks: 611 times
Postby Cybercow » 02 Mar 2019, 04:18
[ Image ]
Did you ever do PCBs for this circuit? If so, do you have any available?
Cybercow
(moo)
Cybercow
Users browsing this forum: badhornet, illus1on7 and 18 guests
