JHS - AT (Andy Timmons) Signature Drive
Postby bugg » 15 Dec 2017, 20:02
PCBs are available here: http://www.pedalpcb.com/product/angryandy/
For this message the author bugg has received thanks: 4
dv8r601 (16 Dec 2017, 02:10), Groovenut (16 Dec 2017, 15:39), jt (16 Dec 2017, 16:43), karul (15 Dec 2017, 23:19)
bugg
Has thanked: 35 times
Have thanks: 221 times
Re: JHS - AT (Andy Timmons) Signature Drive
Postby roseblood11 » 15 Dec 2017, 22:36
The toggle is a on/off/on, so no clipping diodes in middle position?
For this message the author roseblood11 has received thanks:
bugg (16 Dec 2017, 00:23)
roseblood11
Has thanked: 344 times
Have thanks: 309 times
Postby roseblood11 » 15 Dec 2017, 22:38
Hast du in deiner Finanzplanung ein Plug In für Drums mit drin? Hilft einem sehr beim Ideen sammeln... Ich nutze zB EZdrummer, weil man da schnell im Plug-In eine Songstruktur bauen kann und dann mit einem Click in die DAW übernehmen.
roseblood11
Postby bugg » 16 Dec 2017, 00:22
roseblood11 wrote:The toggle is a on/off/on, so no clipping diodes in middle position?
I do believe that is correct. This should correspond to the 100W mode, described as "cleaner, loud".
roseblood11 (19 Dec 2017, 01:29)
bugg
Postby Scruffie » 16 Dec 2017, 02:51
roseblood11 wrote:Hast du in deiner Finanzplanung ein Plug In für Drums mit drin? Hilft einem sehr beim Ideen sammeln... Ich nutze zB EZdrummer, weil man da schnell im Plug-In eine Songstruktur bauen kann und dann mit einem Click in die DAW übernehmen.
Mein Deutsch ist schlecht aber das ist nicht verwandt? :scratch: :mrgreen:
Scruffie
Has thanked: 27 times
Have thanks: 138 times
Postby Groovenut » 16 Dec 2017, 04:43
I was under the impression that the louder setting were the LEDs , the lowest setting were the Schotky's and the middle setting were mosfets.
Groovenut
Has thanked: 64 times
Have thanks: 113 times
Postby bugg » 16 Dec 2017, 13:17
There are no mosfets in the thing. I know the Madbean Turnabout has them, but the AT doesn't.
bugg
Postby Groovenut » 16 Dec 2017, 15:35
Ah I see. Very interesting. Thanks for the info!
There's an assembled board on ebay that claims to be JHS @ that seems to bear this out in the pics.
Groovenut
Postby alexradium » 16 Dec 2017, 15:37
OMG its amazing,what a genius!
For this message the author alexradium has received thanks:
Nocentelli (16 Dec 2017, 23:39)
alexradium
Has thanked: 51 times
Have thanks: 53 times
Postby bugg » 16 Dec 2017, 16:40
I don't have the original in-hand anymore but this is a fairly good pic of the PCB.
The two components at the bottom (D201 and Q200) are part of the LED switching. There are no components on the other side of the board.
bugg
Postby Manfred » 16 Dec 2017, 22:42
Miss the point, I guess text insert by mistake.
Manfred
Has thanked: 950 times
Have thanks: 501 times
Postby roseblood11 » 17 Dec 2017, 01:26
Ups, I wanted to post that to another forum. Crappy small smartphone display...
roseblood11
Users browsing this forum: gcwills, luckett and 10 guests
