Lollygagger FX - Canaglia
Postby Desdog » 09 Jan 2018, 00:05
For this message the author Desdog has received thanks: 3
Manfred (09 Jan 2018, 00:38), Nocentelli (09 Jan 2018, 21:22), Zokk (10 Jan 2018, 15:46)
Desdog
Has thanked: 57 times
Have thanks: 14 times
Re: Lollygagger FX - Canaglia
Postby Nocentelli » 09 Jan 2018, 22:43
For this message the author Nocentelli has received thanks: 2
dv8r601 (10 Jan 2018, 00:55), Manfred (10 Jan 2018, 04:05)
Nocentelli
Has thanked: 807 times
Have thanks: 813 times
Postby Manfred » 10 Jan 2018, 04:50
The first part of the circuit is derived form the Lovepedal Champ circuit.
The second part could be derived from the Zvex Super Hard On buffer circuit.
Has thanked: 785 times
Have thanks: 363 times
Postby Manfred » 10 Jan 2018, 08:22
I ran a simulation of the first stage with 2.5 Kiloohms, 5 Kiloohms and 10 Kiloohms potentiometer without clipping diodes.
The simulatons gave following results:
The gain change is linear over the ajustment range.
gain ranges:
2.5 Kiloohms potentiometer: 4.25 to 7.1
5 Kiloohms potentiometer: 4.25 to 4.75
10 Kiloohms potentiometer: 4.25 to 14.25
The start point of clipping is a bit different for all potentimeter.
The clippings starts from 250 Millivolts to 320 Millivolts but the diode clipping starts much earlier.
Nocentelli (10 Jan 2018, 21:39)
Postby Nocentelli » 10 Jan 2018, 21:39
Manfred wrote:gain ranges:
Nocentelli
Postby Manfred » 10 Jan 2018, 22:07
:scratch: Please formulate your questions.
I ran the simualtion with the first stage circuit of the Lollygagger.
Postby Nocentelli » 10 Jan 2018, 23:59
Apologies, i was posting from my phone and the screen is cracked so typing was difficult - I'm on the pc now.
I was expressing surprise at the result for 5k. I assumed the gain went up as the added series resistance at the collector from the pot increased: This seems to be true from the 2k5 and 10k pots' ranges, but the maximum gain for 5k appeared to be an anomaly.
Nocentelli
Postby Manfred » 11 Jan 2018, 00:23
:oops: Sorry, now I understand, I am getting old.
gain ranges:
5 Kiloohms potentiometer: 4.25 to 10.65 <-------
Guessed circuit:
Nocentelli (11 Jan 2018, 23:17)
Postby Nocentelli » 11 Jan 2018, 23:49
I don't think C4 exists.
C3, 5 and 6 look quite fat and C5 appears to be 330n in one picture.
I'm not very good at ID'ing diodes, but they seem smaller than the usual 1N4148
Nocentelli
Postby Manfred » 11 Jan 2018, 23:51
In this derived Electra Distortion circuit the Potentiometer value is 50 Kiloohms
A further guess:
Users browsing this forum: Hirti, mare, Rastadread and 8 guests
