Friedman - Buxom Boost
Postby bugg » 13 Jan 2018, 03:28
PCBs are on the way - http://www.pedalpcb.com/product/bettyboost/
For this message the author bugg has received thanks: 13
blackbunny (17 Jan 2018, 09:57), DonDougie (13 Jan 2018, 20:07), dv8r601 (15 Jan 2018, 16:28), Intripped (15 Jan 2018, 22:32), J0K3RX (15 Jan 2018, 22:57), mr coffee (28 Jan 2018, 18:26), nexion777 (15 Jan 2018, 19:51), rcustoms (29 Aug 2018, 16:17), toneman (15 Jan 2018, 19:39), vot (13 Jan 2018, 04:57) and 3 more users
bugg
Has thanked: 36 times
Have thanks: 225 times
Re: Friedman - Buxom Boost
Postby Lithium_Grim » 15 Jan 2018, 09:02
That is a complex powersection. Why so complex, normally a -9v requires a lot less components? Can anyone give some insight?
Lithium_Grim
Have thanks: 14 times
Postby toneman » 15 Jan 2018, 19:45
Q1 and VR1 form a preregulator for the LT1054 which is sensitive to overvoltage.
Too much input and POOF!
U could do this with 2 9V batteries but what's the fun in that?
8)
Tone-to-the-Bone
toneman
Has thanked: 90 times
Have thanks: 19 times
Postby LeroyP » 02 Feb 2018, 03:02
The first to op amps have gains of only 1.47 each?? Is that right?? With the gain control turned up full the total numerical gain for the three stages combined is only around 20 (26db).
This could be achieved by having one stage and a 200k pot instead of the three stages plus the 100k pot.
Am i missing something??
Leroy
LeroyP
Postby alexradium » 14 Feb 2018, 16:22
LeroyP wrote:The first to op amps have gains of only 1.47 each?? Is that right?? With the gain control turned up full the total numerical gain for the three stages combined is only around 20 (26db).
Leroy
26 dB is plenty of gain for any application,as a clean boost,the use of more stages is because of the tight filter to work independently of the volume boost and be separated from the guitar input.
Even if you could kill 3 birds with one stone,why not throwing a couple more for fun if it doesn't cost much more,i mean 2 or 3 TL072s cost very low money,they are machine mounted in big quantities and the pedal sold to more than 200.
alexradium
Has thanked: 52 times
Have thanks: 55 times
Postby screamingdemon » 28 Aug 2018, 09:36
Question i orderd the pcb but what type of caps should i use.Panasonics stacked metal film or polyfilm.
screamingdemon
Postby plush » 28 Aug 2018, 17:15
screamingdemon wrote:Question i orderd the pcb but what type of caps should i use.Panasonics stacked metal film or polyfilm.
Just by it looks, the pcb is designed to use boxed capacitors (epcos, wima, arcotronics and others) with 5mm lead spacing (63-100v), but you can use any other type that fits - polyfilm, metal film, ceramics etc with no tonal difference. Just avoid using cheap unbranded caps.
plush
Has thanked: 21 times
Have thanks: 26 times
Users browsing this forum: Groovenut and 3 guests
