Deville Click-Less Bypass.
Postby The Uncle Buck » 03 Feb 2018, 02:06
Schematic - Attached to this post.
Hex Code - Attached to this post. You will need to change the file extension from ".doc" to ".hex" (the board would not upload a file with the .hex extension). Why am I only posting the hex code? Because that's all a MCU hacking service can provide. It works in both the Click-Less Bypass Kit as well as Deville pedals (I used a Buzzmaster as the test unit)
Caveats - The Deville Click-Less is one of the quietest relay switching systems I've come across but it falls just shy of perfect.
1) There's a faint ticking noise when the pedal is engaged. Adding 1µF electrolytic in series with the 1k resistor/LED from pin 7 of the MCU remedies it.
2) There's an audible squeaking/metallic ping when the footswitch is engaged. I haven't figured out how to rectify that.
3) Both of these issues are present in the Buzzmaster I used as the test unit with the MCU that came with the pedal, so I do not believe the hex code is corrupt.
The Click-Less Bypass system was sold to Mammoth Electronics a few years back but they changed a few things (it's now been phased out of their product line completely)...no LED ticking or footswitch squeak/ping but there is an audible "thump" when switching the pedal on and off. Also, I was told by the hacking service that it's near impossible to convert the hex code back to the source code. There are pieces of software that can do it but apparently the results can be incomplete and/or unreliable.
For this message the author The Uncle Buck has received thanks: 2
FiveseveN (03 Feb 2018, 17:59), Wiseblood (14 Mar 2018, 03:40)
The Uncle Buck
Have thanks: 2 times
Re: Deville Click-Less Bypass.
Postby Jack Deville » 03 Feb 2018, 03:22
Wow!!
Only took 8 or 9 years to crack.
Seriously, mods: remove this as it is in violation of IP laws:
Read: software piracy.
I'm sure you understand the severity of infraction.
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
For this message the author Jack Deville has received thanks:
culturejam (03 Feb 2018, 05:33)
Jack Deville
Have thanks: 88 times
Postby FuzzMonkey » 03 Feb 2018, 04:11
The Internet never forgets however.
FuzzMonkey
Has thanked: 25 times
Have thanks: 24 times
Postby jrfox92 » 03 Feb 2018, 08:06
For this message the author jrfox92 has received thanks: 3
BlueMeany (03 Feb 2018, 12:06), Motter (03 Feb 2018, 17:24), Nocentelli (03 Feb 2018, 10:02)
jrfox92
Have thanks: 52 times
Postby black03 » 11 Feb 2018, 18:42
Jack Deville wrote:Wow!!
What an idiot you are! Do not worry, because it is a scam that you sold to Mammoth, the product is very bad, and you think you are a genius. A real disaster, your ego is going to kill you.
black03
Users browsing this forum: Pete and 8 guests
