Keeley - 30ms Double Tracker
Postby floris » 06 Mar 2018, 19:41
Keeley 30ms Double Tracker gutshots.
Spin Semiconductor FV-1 for audio delay / detune / reverb: http://www.spinsemi.com/products.html
24LC32A 8pin DIP EEPROM that holds the program for the FV-1 chip.
TL074 for the audio path, probably buffers and such to interface with the FV-1 chip.
TQ2-9V "single side stable" DPDT relay that is used for true bypass next to a 3PDT foot-switch.
4x 10kB pots for controlling the parameters of the program running on the FV-1 chip.
For this message the author floris has received thanks: 4
bmxguitarsbmx (07 Mar 2018, 04:15), Desdog (30 Mar 2018, 17:51), Intripped (08 Mar 2018, 15:16), modman (29 Mar 2018, 23:37)
floris
Has thanked: 171 times
Have thanks: 55 times
Re: Keeley - 30ms Double Tracker
Postby caspercody » 07 Mar 2018, 16:01
Check out Pedalpcb.com Unison Double tracker. Might help with the schematic.
http://www.pedalpcb.com/product/unison/
For this message the author caspercody has received thanks:
floris (09 Mar 2018, 03:09)
caspercody
Has thanked: 30 times
Have thanks: 44 times
Postby Boba7 » 07 Mar 2018, 22:51
A relay AND a 3pdt?
Boba7
Have thanks: 7 times
Postby floris » 08 Mar 2018, 00:06
Boba7 wrote:A relay AND a 3pdt?
Yes I also found that interesting. Seems overkill.
Also the PCB mentions a "trails" function next to the 2 DIP switches and at the bottom of the PCB.
But this is not implemented as far as I can see.
floris
Postby Boba7 » 08 Mar 2018, 09:23
Is the 3pdt latching or momentary?
Boba7
Postby floris » 09 Mar 2018, 14:41
Boba7 wrote:Is the 3pdt latching or momentary?
It is a latching switch.
floris
Postby floris » 14 Mar 2018, 19:06
Some picts with IC1 TL074 quad opamp removed:
Opamp B has minus input and output connected together so it is a buffer.
Opamp C has a resistor between input and output and works as an amplifier or mixer.
Opamp D is not used.
In my pedal, the signal was very soft.
Measurements on the IC1 TL074 pins showed that the opamps were not working properly: Output pins were not at V-bias of 4,5V DC.
I replaced IC1 with a new TL074, and all is working again. :thumbsup
For this message the author floris has received thanks: 2
bmxguitarsbmx (16 Mar 2018, 21:18), modman (29 Mar 2018, 23:38)
floris
Users browsing this forum: No registered users and 21 guests
