MI Audio - Blues Pro  [traced]
Postby tonymcbony » 07 Jul 2015, 12:48
Hi folks, I was just building a blues pro up on vero and I have the weirdest issue.
All the knobs work (Gain does *something*, tone and vol work as they should) but it doesn't amplify the signal, but instead cuts out every second, like a slow tremolo. I changed out all the power caps just in case that was the problem but no dice.
I was using this http://tagboardeffects.blogspot.co.nz/2 ... s-pro.html layout.
Things I did differently; I did not include the fuzz or fat switch. I instead put a jumper between that trace that both switches connect to and the + of the 22uF cap going to ground. I also used a 51pf in place of the 30pf
Voltages on the IC are:
1 bounces around
2 0.07
3 0.01
4 0
5 0.65
6 0.09
7 bounces around
8 9.02
I've changed IC's no difference too. Something weird is happening though!
tonymcbony
Has thanked: 21 times
Have thanks: 18 times
Re: Blues Pro - weird pulsing and no gain?
Postby DrNomis » 08 Jul 2015, 08:16
tonymcbony wrote:Hi folks, I was just building a blues pro up on vero and I have the weirdest issue.
1 bounces around
2 0.07
3 0.01
4 0
5 0.65
6 0.09
7 bounces around
8 9.02
That basically suggests to me that the circuit is motor-boating (oscillating) at a low frequency rather than amplifying, somehow the output-signal is being fed back into the input, have you tried turning the volume pot right down to zero and seeing if the voltage on pin 1 stops bouncing around?, if it does stop bouncing around then that suggests that the fault involves the volume pot.... :thumbsup
Have you made sure that all the copper track-cuts have been made in the correct places?, also, check to make sure that you haven't made any unintended short-circuits between the tracks while soldering the components.... :thumbsup
Hope that helps.... :thumbsup
Has thanked: 123 times
Have thanks: 399 times
Postby tonymcbony » 09 Jul 2015, 01:12
Yep, that fixed the pulsing; I had 300k resistors instead of 330k.
Still doesn't actually raise the volume past unity for some reason.
tonymcbony
Postby DrNomis » 09 Jul 2015, 06:03
tonymcbony wrote:Yep, that fixed the pulsing; I had 300k resistors instead of 330k.
Hmmmm....a 300k resistor shouldn't have affected the operation of the circuit enough to cause the pulsing..... :hmmm:
Glad you fixed it though..... :thumbsup
MI Audio Blues Pro  [traced]
Postby animalejo » 06 Mar 2018, 21:50
Hi !!
This is the MI Audio Blues Pro, i took the Tagboardeffects Rev 2, wich have the Fat Mode, and add to the premedit schematic:
Cheers ! :horsey:
For this message the author animalejo has received thanks: 5
karul (07 Mar 2018, 01:44), Manfred (06 Mar 2018, 23:22), marcao_cfh (06 Mar 2018, 22:44), modman (29 Mar 2018, 23:51), Nocentelli (07 Mar 2018, 06:33)
animalejo
Have thanks: 12 times
Re: MI Audio Blues Pro
Postby michael_ibrahim » 07 Mar 2018, 00:52
:roll:
michael_ibrahim
Users browsing this forum: jongwong, Stymie13 and 9 guests
