TAD Range King schematic  [traced]
Postby apollomusicservice » 26 Mar 2018, 18:55
The Tube Amp Doctor - Range King power booster
For this message the author apollomusicservice has received thanks: 9
blackbunny (18 Apr 2018, 11:02), dv8r601 (26 Mar 2018, 20:26), fuzzbunny (27 Mar 2018, 16:31), Intripped (27 Mar 2018, 08:35), karul (27 Mar 2018, 02:47), Manfred (26 Mar 2018, 22:39), modman (28 Mar 2018, 14:00), sixthfloor (28 Mar 2018, 10:32), Zokk (28 Mar 2018, 10:08)
apollomusicservice
Has thanked: 65 times
Have thanks: 769 times
Re: TAD Range King schematic
Postby dv8r601 » 26 Mar 2018, 20:27
Looks like intestines on the part behind the dpdt switch. Thanks for your degoop work. Very good
dv8r601
Has thanked: 397 times
Have thanks: 18 times
Postby fuzzbunny » 28 Mar 2018, 01:20
R1 & R2 are both 100k? Is that verified?
Thx.
fuzzbunny
Have thanks: 10 times
Postby Manfred » 28 Mar 2018, 09:33
fuzzbunny wrote:R1 & R2 are both 100k? Is that verified?
Thx.
I ran a simulation of this circuit and found the collector voltages as follows:
Using R2 = 100kOhms : 1.8 Volts DC
Using R2 = 10kOhms: 7.7 Volts DC
A collector voltage of about 7 Volts is common in the known Rangemaster circuits.
IMO the Value of R2 must be 10kOhms.
For this message the author Manfred has received thanks:
dv8r601 (29 Mar 2018, 00:04)
Manfred
Has thanked: 987 times
Have thanks: 532 times
Postby Manfred » 13 Apr 2018, 22:52
I made an an approximative PCB layout of the analog part for retracing the circuit.
The resistor which is labeled with the question mark is marked as R1 in the schematic.
At this point in the shot a resistor with following rings is shown:
yellow - violet - black - ? - braun.
The colour of the fourth ring looks like yellow.
Makes this sense because in this case the resistor would be 4.7 Megohms.
Which is the right colour?
Manfred
Postby Manfred » 15 Apr 2018, 02:46
The symbol of the DC jack is wrong in the schematic, sleeve and tip have been mixed up.
Manfred
Postby fuzzbunny » 15 Apr 2018, 04:34
Thx.
I did a quick breadboard with Apollo's schematic values but subbed a 10K in the R1 position.
I used a variable resistor in the R3 position ( collector) and biased by ear.
The circuit sounded best with approx. 4.5v on the Collector, R3 around 50k.
The sound was ok but I think something is not quite right with the schematic/details as they are presented. I had a good look at the photos and it doesn't quite add up.
Don't get me wrong, I appreciate the great contributions Apollo makes to the forum! I just wanted to pass,on my findings for others to build on..
For this message the author fuzzbunny has received thanks:
Manfred (15 Apr 2018, 08:58)
fuzzbunny
Postby Manfred » 15 Apr 2018, 09:24
Thanks for your work, I appreciate it very much.
I ran a simulating using with R3 = 50k which confirms your results.
Don't get me wrong, Don't get me wrong, I appreciate the great contributions Apollo makes to the forum! I just wanted to pass,on my findings for others to build on..! I just wanted to pass,on my findings for others to build on..
I think, to pass findings is one of the most important things here.
I appreciate the great contributions Apollo makes to the forum too.
Manfred
Postby apollomusicservice » 16 Apr 2018, 15:06
Manfred wrote:The symbol of the DC jack is wrong in the schematic, sleeve and tip have been mixed up.
There is nothing wrong with DC jack in my schematic
apollomusicservice
Postby Manfred » 16 Apr 2018, 17:25
http://www.tubeampdoctor.com/en/shop_TAD_Equipment_Other_TAD_equipment/RangeKing_Power_Booster_667
In the Specifications of the TAD Rangeking you can find;
- jack for external 9VDC power supply (tip: ground, sleeve: 9VDC)
In your schematic the sleeve is connected to ground and the tip to +9VDC
Manfred
Postby apollomusicservice » 16 Apr 2018, 19:13
Manfred wrote:http://www.tubeampdoctor.com/en/shop_TAD_Equipment_Other_TAD_equipment/RangeKing_Power_Booster_667
Still I don't understand, in my schematic Tip (or Pin) is on the ground.
apollomusicservice
Postby Manfred » 16 Apr 2018, 20:56
Sorry, now I understand, you using an another drawing symbol for the DC-jack like I do, then the schematic is of course correct.
I use this drawing symbol, that was the point of confusion for me.
Manfred
Postby Manfred » 18 Apr 2018, 22:32
I bought a Rangeking for a very favourable price yesterday.
I measured the passive components and some voltages too.
For a proper measure of R2 it was necessary to interrupt the conductor after its lead,
because I want not degoop the PCB.
I found:
R1 = 470 Kiloohms
R2 = 2.2 Megaohms
The calculation with the read values gives a DC-gain of about 430 for the transitor.
For this message the author Manfred has received thanks: 4
287m (19 Apr 2018, 04:03), fuzzbunny (21 Apr 2018, 03:47), nickthemen (18 Apr 2018, 22:45), snofla1900 (19 Apr 2018, 09:52)
Manfred
Postby rs » 19 Apr 2018, 18:55
From looking at the photos, R1 looks like 4M7 to me (yellow-violet-black-yellow-brown) but i could be wrong.
rs
Has thanked: 88 times
Have thanks: 6 times
Postby Manfred » 19 Apr 2018, 21:21
rs wrote:From looking at the photos, R1 looks like 4M7 to me (yellow-violet-black-yellow-brown) but i could be wrong.
Indeed, I measured R1 with 470k an R2 with 2M2.
I ran a simulation with the new values which confirm the read voltage values.
rs (20 Apr 2018, 17:00)
Manfred
Postby Manfred » 20 Apr 2018, 02:52
I ran the simulation with a BC548C transistor because a BC550C is not available, but both Types have nearly the same values.
Here a shot of the simulation.
rs (20 Apr 2018, 17:01)
Manfred
Postby apollomusicservice » 20 Apr 2018, 17:30
Thanks Manfred but here is another one photo, R2 is still questionable. Unfortunately, the pedal is no longer with me.
apollomusicservice
Postby Manfred » 20 Apr 2018, 20:41
Thanks, for the another photo, I would say that the fourth ring is orange.
Manfred
Users browsing this forum: himers, snofla1900 and 17 guests
