Ctech - Sonny Boy
Ctech - Sonny Boy
Postby drbob1 » 15 Jun 2018, 01:39
This is a strange one from the 90s. It appears to be a similar concept to the Sansamp Classic, using multiple op-amps and transistors to "model" amp sounds. Unlike the Sansamp the sounds are labeled by the songs they're supposed to be like. Since none of them are really clean, think of them as different flavors of overdrive/distortion. Unlike the Sansamp, also, they don't use a dip switch matrix, they use a switching IC controlled by a rotary knob to set the particular character of the overdrive. Lots of really nicely installed, TINY components in a weird trapezoidal box! (I shrank the files a bit, but didn't want to make them too hard to see. If you right click and "Display in another Tab" you can see them complete).
https://uwmadisonmedicalschool.box.com/ ... ecjc5n.jpg
https://uwmadisonmedicalschool.box.com/ ... aaoos4.jpg
https://uwmadisonmedicalschool.box.com/ ... y0rl32.jpg
https://uwmadisonmedicalschool.box.com/ ... vwqgs9.jpg
https://uwmadisonmedicalschool.box.com/ ... 22onkd.jpg
https://uwmadisonmedicalschool.box.com/ ... asxu6b.jpg
Anyway, if anyone is interested, have at it. I can help with values if they're hard to see, but I'm not much for the tracing thing!
For this message the author drbob1 has received thanks: 3
bajaman (17 Jun 2018, 08:01), dv8r601 (15 Jun 2018, 22:44), modman (29 Jul 2018, 21:01)
drbob1
Have thanks: 47 times
Re: Ctech - Sonny Boy
Postby Belanger88 » 15 Jun 2018, 12:06
Definitely well built and the Semiconductors are of decent quality as well! Kemet, NSC and Mirco Electronics are some of my favourites , I think it could be a fun project for sure.
BJT or Fet?
drbob1 wrote:This is a strange one from the 90s. It appears to be a similar concept to the Sansamp Classic, using multiple op-amps and transistors to "model" amp sounds. Unlike the Sansamp the sounds are labeled by the songs they're supposed to be like. Since none of them are really clean, think of them as different flavors of overdrive/distortion. Unlike the Sansamp, also, they don't use a dip switch matrix, they use a switching IC controlled by a rotary knob to set the particular character of the overdrive. Lots of really nicely installed, TINY components in a weird trapezoidal box! (I shrank the files a bit, but didn't want to make them too hard to see. If you right click and "Display in another Tab" you can see them complete).
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
Belanger88
Has thanked: 104 times
Have thanks: 33 times
Postby dv8r601 » 15 Jun 2018, 22:46
there's at least 1 philips 2N3904 below the lower right opamp (looking at front of board)(
, cant see the one on the side
dv8r601
Has thanked: 400 times
Have thanks: 18 times
Postby dv8r601 » 15 Jun 2018, 22:51
That LMC660 looks really badass from looking at the data sheet:
http://www.ti.com/lit/ds/symlink/lmc660.pdf
CMOS Quad opamp
dv8r601
Postby bajaman » 17 Jun 2018, 07:38
Here is a preliminary trace - just needs some capacitor values - or codes printed on them :wink:
Also the diode values or codes :wink:
For this message the author bajaman has received thanks: 4
Frank_NH (18 Jun 2018, 14:46), Manfred (17 Jun 2018, 08:40), modman (29 Jul 2018, 20:26), Nocentelli (17 Jun 2018, 08:27)
Has thanked: 446 times
Have thanks: 1519 times
Postby Manfred » 17 Jun 2018, 15:41
I have started to make a PCB-Clone.
Here the component side layout, but it may be helpful to fill in the missing values.
I cannot see the audio jack pin layout, any idea which type it could be?
For this message the author Manfred has received thanks:
modman (29 Jul 2018, 20:27)
Manfred
Has thanked: 990 times
Have thanks: 542 times
Postby bajaman » 17 Jun 2018, 22:11
Manfred wrote:I have started to make a PCB-Clone.
i have already done a clone for the board too :lol:
I am just waiting on drbob1 to confirm the capacitor and diode codes :wink:
Postby drbob1 » 18 Jun 2018, 00:24
Hope to get to that tomorrow or Tuesday.
For this message the author drbob1 has received thanks: 2
bajaman (18 Jun 2018, 02:18), Manfred (18 Jun 2018, 06:23)
drbob1
Postby Manfred » 18 Jun 2018, 06:23
Thanks Bajaman, in this regard it is not longer necessary from my side. :thumbsup
bajaman (18 Jun 2018, 07:28)
Manfred
Postby Frank_NH » 18 Jun 2018, 14:50
This looks cool 8) and something I would like to build on a vero layout.
Bajaman - I think the rail for the IC non-inverting inputs should be at the middle of the 10K voltage divider (Vbias), with the 100uF cap in parallel to the lower 10K to ground? I'm also puzzled at how the switching works with this, but I guess I'll learn as the circuit trace evolves. :D
Frank_NH
Has thanked: 18 times
Have thanks: 67 times
Postby bajaman » 18 Jun 2018, 22:35
No - the trace is correct - there are two 10k resistors as a voltage divider between +ve and ground, BUT there is a 10k resistor fed in series with the 100uf electrolytic from the midpoint of the divider. the three 10k resistors are immediately below the LMC660CN and the 100u electro is just to the right of the 4066 quad bilateral switch IC . the switching is achieved by connecting +ve voltage to one or more of the 4 control pins of the quad bilateral cmos switch via the 10 position rotary BDC encoder switch. Two of these switches control the gain of the second LMC6660CN opamp section and the other two switches control the post gain tone filtering and output level of this gain stage depending on which of the 10 preset sounds are selected :wink:
Frank_NH (19 Jun 2018, 03:52)
Postby Frank_NH » 19 Jun 2018, 03:51
Thanks Bajaman. OK, I get it now - odd Vbias arrangement, but it apparently works - current draw must be low. I also understand the switching, and I suppose you could use 4 SPST switches if you didn't want the complication of the rotary switch.
Frank_NH
Postby bajaman » 19 Jun 2018, 06:06
Yes the bias arrangement is unusual, but according to the data sheet the LMC660CN is designed to run from a single supply rail and is a pin for pin replacement for the LM324 (also designed for single supply operation) - perhaps the bias supply (which i would have thought unnecessary ) is designed to allow asymmetrical operation of the op amp gain stages :scratch: . In any case, i would not expect a device such as the TL074 to work correctly in this particular circuit configuration :wink: :hmmm:
yes - you could simply use four single pole switches in place of the rotary encoder switch - you could even leave out the 4066 cmos bilateral switch :lol:
I would certainly use a heavier duty footswitch, if I was building one of these :wink:
Postby bajaman » 21 Jun 2018, 08:46
Hmmmm - while we anxiously await capacitor and diode codes, does anyone have a C-Tech Red Rooster pedal that they are willing to share gut shots and component values with us here :hmmm:
Postby drbob1 » 26 Jun 2018, 05:02
Promise I'll get to the cap values!
I've never even heard of the Red Rooster! I wonder how many of those they made?
bajaman (26 Jun 2018, 05:12)
drbob1
Postby Frank_NH » 26 Jun 2018, 05:24
drbob1 wrote:Promise I'll get to the cap values!
Looks like the Red Rooster was the Rock version of the Sonny Boy... 8)
http://www.effectsdatabase.com/model/ct ... r#pictures
Frank_NH
Postby drbob1 » 28 Jun 2018, 01:29
Yeah, knowing it existed and ever having seen one are very different. There's none for sale, no links except for one review on Harmony Central from years ago. It's kind of a ghost!
Anyway, here's the best I can do with the components. A couple of problems came up:
1. No markings I can see on the small caps, at all
2. The slightly larger mustard colored caps each have 4 markings on them: 2 codes of 3 letters and 2 codes of 3 numbers. Anyway, I captured all I could see. With these old eyes, though, it's a little iffy if they're perfect!
3. Transistors I think I got fine, but I couldn't read a blessed thing off the diodes
4. Corrected a few components-a cap marked as a resistor, a diode marked as a resistor, and one extra cap that wasn't there
To get a better read on things, I suspect you'd have to take it apart, and I know I'm not capable of neat enough soldering to put it back together properly. I guess if someone wants to do it badly enough I could send it to them, but that isn't super exciting to me...
Manfred (28 Jun 2018, 08:17)
drbob1
Postby bajaman » 03 Jul 2018, 10:28
some of those capacitor numbers are strange - 735? 744? :scratch:
Anyway thanks to drbob1's diligence, we now have the switch BCD encoder deciphered and here are my best guesses so far for capacitor and diode values based on simulations - i have a pcb ready to roll that will fit in a Hammond or similar 1590BB enclosure - buffered or true bypass with a second footswitch to engage the 50s/60s boost. Cast your eyes over this latest schematic and let me know your thoughts :)
modman (29 Jul 2018, 21:00)
Postby Gearslob » 10 Jan 2019, 06:22
drbob1 just led me to this post and forum. I just picked up one of these today, and I love the sounds, but cannot use it (live) as is.
Does anyone see the possibility of a multi-footswitch option in place of the rotary?
1 footswitch 50s/60s boost
1 on/off
presence/gain/volume knobs as existing
10 footswitches to select existing presets
Gearslob
Postby The Rotagilla » 12 Jan 2019, 00:43
Not that this helps, but I used to live about 10 minutes away from where they were made. It's been years since I've played one but I want to say I remember it being decent.
The Rotagilla
Have thanks: 57 times
Next
Users browsing this forum: dade1960, Ferrit37, holm and 11 guests
